Best axel coating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ano'ai808, Nov 16, 2017.
  1. Nov 16, 2017 at 1:39 AM
    Ano'ai808
    Ano'ai808 [OP] HoloHolo Kalaka
    Ano'ai
    Kahului
    2019 TRD sport
    2.5 fox 3-4in front/rear Dirt king fab LCA/UCA Locked rear bumps OME leaf pack ARB air 15%-5%tints
    So i just recently put a U bolt flip kit.i took the old u bolt perch off. Under it after years i guess it rubbed off the paint. So i wanna get it sanded down and covered so it dosent rust my axel. I was gonna do a smooth bed liner in just the section that is bare metal. What should i do?
  2. Nov 16, 2017 at 3:03 AM
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    I would just scuff it, clean it really well, and use some rattle can chassis paint.
    Ano'ai808[OP] likes this.
  3. Nov 16, 2017 at 3:05 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    You must be retarded bc you actually tried to read it hahah
    Rambo54 likes this.
  4. Nov 16, 2017 at 3:08 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    Thank bro think that’s what I’m gonna go with I’m just gonna keep checking up on it
  5. Nov 16, 2017 at 3:33 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Rustoleum contractor/proffessional matte black enamel is what I use for touch ups, when I rebuild stuff that's going to be appart for a while I'll strip it, etch it, prime it, and use POR-15.
    The Rustoleum holds up pretty damn good though, easy to match and UV stable. Most of my frame, my sliders, and a few other odds and ends are coated in it. Lay it on thick.
    I've also had very good luck with their bedliner in a can stuff, it kinda has a crinkle texture to it. I wouldn't use it as a true bed liner but as a paint it holds up well it just has a gloss sheen from the polyurathane in it. It goes fast though so it is a more expensive option.
  6. Nov 16, 2017 at 3:59 AM
    badger
    badger Well-Known Member
    07 SR5
    Duplicolor wheel paint is good stuff. It dries fast and holds up very well. The satin black would look good.
  7. Nov 16, 2017 at 6:31 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Says the person who started the thread, for other people to read. o_O
    Ano'ai808[QUOTED][OP] likes this.
  8. Nov 16, 2017 at 6:43 AM
    Taco'09
    Taco'09 Well-Known Member
  9. Nov 16, 2017 at 6:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Actually your axle isn't even visible, and it's safe in a lubricated environment. :D
    But seriously, paint the axle housing with whatever durable product you have readily available. BBQ grill paint even works.
    It's not like you are rolling a Riddler entry here, right?
  10. Nov 16, 2017 at 7:23 AM
    Pigpen
    Dan
    Northwest Montana
    I laughed so hard!!
    Thanks for the entertainment guys.
  11. Nov 16, 2017 at 10:39 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    Yes and I can see you can read retard as well! Great gob! Let me no when your hungry I can feed you to!:)
    blu92in99[QUOTED] likes this.
  12. Nov 16, 2017 at 11:03 AM
    blu92in99
    Justin
    Elk Grove, Ca
    Read it, yes. Speak it, no. You bring enough retard to this forum all on your own. Good job! :)
    All kidding aside, thread jack! I'll be in Hawaii in January. It's been 21 years since I was last there. Saw the touristy crap on Oahu last time. Any recommendations for cool stuff to do? Staying on Maui, but planning on island hopping...no surfing this time around though.
  13. Nov 16, 2017 at 11:07 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    I’m retarded I can read
  14. Nov 16, 2017 at 11:09 AM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Painted mine with Rustoleum oil based primer then oil based flat black. Then fluid film. Seems like it will hold up forever
  15. Nov 16, 2017 at 11:11 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    I just don’t wanna put the Ubolts back on and tourqe them down and just cause it to go bare again. I only have an hour dry Time but I as gonna try and heat dry it to force it
