Best bang for the buck headlight upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorcalBlue, Nov 24, 2022.
  1. Nov 24, 2022 at 7:05 AM
    NorcalBlue
    NorcalBlue [OP] Active Member
    Eric
    Hello All,
    I'd like to upgrade my headlights on my 2019. I have done a little research on the site, but there's just so much info - and I really don't have the time at the moment. Quite frankly I'm looking for the cheapest/easiest upgrade that will provide the most improvement and lowest amount of risk. Just don't have the budget for 1k upgrade at the moment. I'd say $300 is my limit. Any thoughts would be greatly appreciated. Thank You and Happy Thanksgiving.
  2. Nov 24, 2022 at 7:07 AM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Just wait and save for new/used Oem led headlights. It’s by far the best headlight upgrade I’ve seen
    Tacos4Runnin likes this.
  3. Nov 24, 2022 at 7:08 AM
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    I have Hikari Ultras (Eye of Megatron) and no issues. They are one of the 2 drop in LED recommended in that long headlight testing thread. You can grab from Amazon for around $90 a pair
    VaToy, jwcox72 and Puppypunter like this.
  4. Nov 24, 2022 at 7:09 AM
    NorcalBlue
    Eric
    Thank you. Do you know the cost (ballpark) to have that done?
  5. Nov 24, 2022 at 7:10 AM
    NorcalBlue
    Eric
    Thank you.
  6. Nov 24, 2022 at 7:11 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Buy a pair of Phillips H9 bulbs (same as high beam bulbs) and pop them in your low beams.
    <$20 and <5 minutes of modifications and you’ll out perform any possible “upgrade” besides oem led.
    This is the only upgrade for halogen housings recommended by the resident lighting expert @crashnburn80, author of the sticked lighting thread. All the info you need is updated regularly in the very first couple of posts
    OldSchlPunk, vivid02, Chew and 3 others like this.
  7. Nov 24, 2022 at 7:13 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Honestly the lights at that price point are going to leak and be trash.
    if I had to do it over I’d find the whitest halogens you could to use temporarily and start saving for the oem leds
  8. Nov 24, 2022 at 7:13 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    Diode dynamic ss3 fogs are an upgrade and they are on sale.
    Chew likes this.
  9. Nov 24, 2022 at 7:23 AM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    There is a thread that will help with a number of options available.
    https://www.tacomaworld.com/threads...11-projector-headlights.589465/#post-19689308
    I have these H11 bulbs which are brighter than stock and are a direct fit.
    https://www.amazon.com/gp/product/B08B8Y259H?ie=UTF8
    You can also convert to H9 bulbs like are in the high beams with some simple modification. Also it is not a good idea to use LED bulbs in the stock housing as the reflector is designed for a filament light source. See the thread above.
    OldSchlPunk and eurowner like this.
  10. Nov 24, 2022 at 7:24 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    For $300 you can't get much of an "upgrade" for headlights. Most units in that price range are very much a downgrade. You're best saving up and going for a name brand or retrofit
    Chew and TS4x4 like this.
  11. Nov 24, 2022 at 7:31 AM
    NorcalBlue
    Eric
    Thanks for all the replies so far - really appreciated. A really great forum.
    RushT likes this.
  12. Nov 24, 2022 at 7:35 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Leave it alone and happy thanksgiving.
    Tacomaryan18 likes this.
  13. Nov 24, 2022 at 7:56 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Yep.
    Every single thread about lights should be that post and the thread locked. It would save pages and pages of stupid bickering.
    Tacomaryan18 and adamceckhardt like this.
  14. Nov 24, 2022 at 8:02 AM
    NorcalBlue
    Eric
    Okee Dokee. Just the info I was looking for - Thanks
  15. Nov 24, 2022 at 8:16 AM
    mysubiewasalemon
    You can find the lights used from 700 and up with a damaged tab or you can get them new from the 1300 range . Plus 90 for the conversion harness
  16. Nov 24, 2022 at 8:36 AM
    Tacos4Runnin
    Tacos4Runnin Well-Known Member
    Okanagan…eh
    2021 TRD-Sport AG/MT
    I would echo this advice. The non LED headlights are still a great set stock from the factory compared to other vehicles on the road
    Saving up for a set of the OEM LED’s is the way to go. Also, you are in luck as black friday deals will be popping up soon for different part venders. I got lucky and scored my set of new OEM LED headlights for 1100 American shipped. Being up in Canada, this was a rocking price at the time compared to the normal 2000
    Dont compromise if you can, save up, and get what you really want for your expensive/awesome truck
    My 2 cents, good luck
    BJK1280, Chew and musicisevil like this.
  17. Nov 24, 2022 at 10:55 AM
    BillyE
    BillyE Well-Known Member
    Any suggestions on where to find OEM LEDs at a good price?
  18. Nov 24, 2022 at 11:02 AM
    BJK1280
    BJK1280 Well-Known Member
    Brandon
    SE Wisconsin
    2023 MGM OffRoad
    They can be purchased on the Lewis Toyota website right now for $591.57 each with the 15% off sale right now. Free shipping on orders over $75 as well.
    Left: 81150-04300
    Right: 81110-04300
