best brake pad rotor combo
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Apr 18, 2010.
  1. Jan 26, 2012 at 9:01 PM
    #41
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Ya'll must be driving like jackasses if yall are going thru brakes as quick as you say
    I've got 130K miles on my truck, and have replaced the rotors ONCE because I got a good deal on the power slots and i've replaced the pads ONCE because I wore the originals out
    I changed that stuff somewhere around the 90K mark
  2. Jan 26, 2012 at 9:04 PM
    #42
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Didn't read through the whole thread but if someone hasn't already mentioned Autozone (if you have it in your area) just go with their Durlast pads and rotors with the life time warranty.. Yes brake pads too.
  3. Jan 26, 2012 at 11:37 PM
    #43
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Different driving conditions can durastically change how long pads/rotors last. A person could have a 300 mile round trip commute and use their brakes much less than another person with a 10 mile commute with a lot of hills and high speed stops.
  4. Jan 26, 2012 at 11:42 PM
    #44
    JimBeam
    JB
    2015 Tundra
    agreed but 20K compared to 90k is a BIG difference
  5. Jan 27, 2012 at 11:28 AM
    #45
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    im running tundra s13we calipers, brembo blanks, and akebono ceramics. if you're looking to replace pads and rotors spend the extra 50-100 on tundra calipers.
  6. Jan 29, 2012 at 1:58 PM
    #46
    shampoop
    southwest WA
    Exactly. A person could live out in BFE with no hills, and could have hundreds of miles and only touch the brakes once. Or you could live on top of a mountain and use your brakes 100x more in one mile than the guy out in flat BFE.
    20k miles can stretch 5-10 years for some people.
  7. Apr 16, 2016 at 5:24 PM
    #47
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    OEM rotors are brembo's :cool: I have nearly 180k on my current OEM replacement rotors. (53k by me)(252k on the truck) I just ordered stuff to swap to 05 tundra s13WL brakes and rotors...calipers are getting old although they work ok, I would feel better with new ones as I'm not sure when they were last replaced (if ever), lines are new -ish with the frame recall, the pads are quite gone, and the rotors are rusted horribly in the fins and while not warped they are a fair bit less than the minimum recommended thickness...
    so for roughly the same amount of time and $$$ spent either way well why not!
  8. Apr 17, 2016 at 7:01 AM
    #48
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    As far as wearing goes. Depending on where you are the snow/salt will create a layer of rust evertime you park for more than a few hours. That takes its toll after a while.
  9. Apr 17, 2016 at 3:27 PM
    #49
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    My browser is not showing any rotors at your website, only brake lines.
  10. Apr 18, 2016 at 7:54 AM
    #50
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Looks like this thread was revived from 2012. We are no longer offering any brake components other than the upgraded/extended brake lines.
  11. Apr 18, 2016 at 9:29 PM
    #51
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    Just about to order a set from you guys, YotaDan.. Dang, I thought my shopping around was done.. Wrong!
    LOL!
  12. Apr 23, 2016 at 8:56 AM
    #52
    CStoy
    for the record, my stock banjo bolts fit the tundra calipers perfectly with no modifications. stopping is very much improved... the extra 13 pounds of unsprung mass gained per side is not so great tho...
    Sicyota04 likes this.
  13. Apr 23, 2016 at 9:15 AM
    #53
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    Gonna throw in another vote for the 231mm/13WL Tundra brakes. One of the best mods I've done, by far, especially with all the mountains around here.
    This is the writeup I used; straight forward swap, significant braking improvement.
    Sicyota04 and CStoy like this.
  14. Apr 23, 2016 at 9:35 AM
    #54
    CStoy
    I will second. i now have 250 miles on mine and as they are getting broke in I am amazed at the difference in stopping power when towing my little trailer (about 3400lbs) with no trailer brakes around. 10x better than stock!
    for reference; our trucks GVWR is less than a stock tundra's wet curb weight is...
  15. Apr 23, 2016 at 9:46 AM
    #55
    CodeTaco
    CodeTaco Well-Known Member
    HB, CA
    2008 Tacoma Access Cab 4x4 TRD
    Bilstein 5100s (f @ 1.75); 5100s rear; All Pro Expedition Springs; PowerStop slotted discs; Akebono ceramic pads; Wheeler's braided brake lines; Prodigy trailer-brake system; heavy duty towing set-up (for off-road trailer); WeatherTech mats (awesome); 5% Ceramic Tint; matching Snug Top (mid) with racks; Thule racks; dipped badges; 17" 2014 OEM 5-spoke 4-runner rims; 265/70/17 Bridgestone Desert Duelers (for now); Siriusxm radio; more on the want list...
    Non-centric cross-drilled/slotted rotors and Akebono ceramic pads here. 100% satisfied.
  16. Apr 25, 2016 at 9:19 PM
    #56
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I have been using Brembo and Akebono - couldn't be happier. This time around I want to try the Brembo coated - don't expect a huge difference but want to try them.
  17. Nov 29, 2016 at 9:01 AM
    #57
    Kirvine07
    Kirvine07 Member
    Kyle
    VA
    08 4x4 Access Cab
    Wider set tires.
    Where do you guys buy these name brand Auto Parts?
    All I got is a damn Autozone with Duralast stuff.
    Should I not be using that?
  18. Nov 29, 2016 at 9:02 AM
    #58
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    x2
  19. Nov 29, 2016 at 9:23 AM
    #59
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I got my WL 231mm Calipers and rotors off of a 2005 Toyota Tundra DC Limited 4x4 w/ the 4.7 V8. And got Wheeler's brake lines in the front. I have 16x8 rims w/ 4.5" of BS. And it all fit fine on my 04 Tacoma
  20. Apr 23, 2017 at 1:21 PM
    #60
    Tacohago
    Tacohago Well-Known Member
    Jake
    2009 Toyota Tacoma TRD
