Best CAI?
Discussion in 'Performance and Tuning' started by Pope953, Mar 29, 2010.
  1. Mar 29, 2010 at 11:43 AM
    Pope953
    Pope953 [OP] That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Ok so im sure that the whole which CAI to get question gets run in the ground. And I know that a lot of people say that they are pointless to have, but I just need some input on which CAI is the best in ya'll opinion. For the record I have a 93' Pickup, 3.0 V6 SR5, 5 speed manual.
    Thanks guys.
  2. Mar 29, 2010 at 11:45 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    well i was gona tell you to search but since you have a '93 I have no idea:notsure:
    edit: get a snorkle!
  3. Mar 31, 2010 at 4:18 AM
    KRS1
    KRS1 Active Member
    Windham, ME
    07 Tacoma 4X4
    6" Pro Comp Susp. Lift 3" Body Lift 35 x 12.50 Cooper Tires CAI (home made) Doug Thorley Long Tubes Flowmaster (44 series) mufflers 150'x3/8 Blue Steel syn. wire rope Wet Okole neo. seat covers
    not sure how machanicaly inclined you are and i mean no harm in saying that but i found for my 07 Tacoma V6.... the most cost effictive air intake and still produces improved throttle response and power..... was to build my own..... i don't care for buying things when i can build them...opposed to spending $400.00 on a CAI i spent $110.00 at home depot and got the same results..... so if you got a good imagination and some skill its not that hard... check out my pics for ideas... main things...
    1. vac. line
    2. MAF sensor... if you got it.... (note 1)
    3. crank case vent hose
    4. connection to throttle body
    those are the main things.... all the bends and everyhing are personal preferance on how you want it to look...the other thing is its not 100% a Cold Air Intake because it doesn't have a box around it that drawn cooler air but you'll be able to tell a diffrence
    (note 1)
    i busted apart the original air box and cut the MAF mount off the air box and screwed it into th PVC pipe.... then around all the connections i used liquid electrical tape to seal them......
  4. Mar 31, 2010 at 10:35 AM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    And yours works just as good you say??
  5. Mar 31, 2010 at 10:57 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    deck plate mod or just put a better drop in filter. Not worth the gains or losses IMHO.
