Best Dash Cam For Off Roading? Need Advice!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GladiatorNOT, Dec 21, 2020.
  1. Dec 21, 2020 at 10:08 PM
    GladiatorNOT
    GladiatorNOT [OP] Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    Looking to purchase my first dash cam and am not sure what to look for. Mainly want to use it to record our off road adventures. Would like to mount it to the factory GoPro windshield mount.
    Was thinking about getting a GoPro Hero 9 but think a dedicated dash cam might be better? I’ve had luck with Garmin GPS products so was considering their mini dash cam but don’t know if that would be too basic. Just looking for a front camera. Nothing in the rear.
    Any recommendations and what to avoid would be appreciated.
  2. Dec 21, 2020 at 10:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I run a BlackVue DR590W (not the latest model) and it's been super reliable on- or off-road. With a 64GB card, it can record couple of days' worth of footage. It takes 12V directly (not 5V USB) so it's easy to tap into the rear view mirror's plug with a Mirror Wire 3005202 power cord.
    Various recordings on my Youtube channel: https://www.youtube.com/channel/UC0c0zTivlzKxple6pjfz0qA/videos Video quality isn't as good as Blackvue's latest models.
    You can download individual clips from the camera to your phone over wifi via the Blackvue app, or take out the microSD card and view the videos on a PC.
  3. Dec 21, 2020 at 10:33 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Dash cam and action cam (go-pro) serve different purposes. I run both. Go-Pro for fun times and dash cam all the time for insurance. Would have saved my ass 3 times over now if I had just got a dash cam.
    Picture quality is vastly different between a go-pro and a dash cam in my experience.
  4. Dec 21, 2020 at 10:54 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    So which do you think is better?
  5. Dec 21, 2020 at 10:57 PM
    NickFox
    NickFox Active Member
    Nick
    2019 Tacoma TRD Off Road
    Stock
    I'm debating pulling the trigger on the Garmin Dash cam mini. Certainly not cinema quality but not bad either imo
  6. Dec 21, 2020 at 11:17 PM
    Key-Rei
    Key
    Florida
    The dash cam if I had to pick one, it could save you thousands in a claim, on premiums, and in a law suit and in a pinch you might get a grainy 60fps or worse 1080p video of something cool you did I suppose but it wouldn't be great. The action cam is by far the better camera, they just make for a bad dash cam as they are higher profile more likely to be targeted for theft and use more power more expensive to replace if they break and often get really hot when loop recording and charging full time.
    This is kind of an apples to oranges question.
    What's better; a crop duster or a jumbo jet?
    Depends on what you're doing or why you want it.
    For what it's worth I have A go-pro hero 4 for fun excursions and I use an A129 Duo for my dash cam.
  7. Dec 21, 2020 at 11:47 PM
    CT Yankee
    CT
    Thanks for your thoughts. I get what you're saying about "Depends on what you're doing or why you want it.' For me it'd be mostly for damage claims and idiot drivers. I'm thinking dash cam over anything else, only forward facing 'cuz of the cap. Been pondering how to set one up in the cap's rear window. Could probably tap into the hitch wiring for battery power. I would want it tight to the top of the window and to the glass. I expect to film the glass in the cap so that it's mostly reflective from outside which should hide the camera quite a bit.
  8. Dec 21, 2020 at 11:58 PM
    Key-Rei
    Key
    Florida
    My A129 duo came with a LONG usb cable for the rear cam I could have run it out of the cabin and back into the bed under or in the load rail track and back up to the capper window if I had my cap on.
    That said most sources recommend a separate cam for the back instead of a "duo" set up.
    I have multiple powered accessories in the back of my truck I ran individual power wires originally but I have enough junk back there now that I have been thinking of running 2/0 wire to the back to a buss bar for shorter accessory runs and enough gauge to run my winch off the rear if I felt like it, the problem would be fusing that monstrosity.
  9. Dec 22, 2020 at 8:27 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Another Blackvue DR590 here, In my opinion the best part of a dash cam is forgetting it's there. It comes on and off (parking mode ftw) with the truck, loops the SD, doesn't beep or have lights, and no one needs to even know it's there. Unless something happens- and then you've got the footage.
    I'd hang a gopro on the mount if I were filming a run or what have you..
  10. Dec 22, 2020 at 8:31 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  11. Dec 22, 2020 at 8:39 AM
    CT Yankee
    CT
    Given the touchy nature of Tacoma's electronics, that is a sensible approach. I'd try to find a HD circuit breaker at the battery, run at least 2/0 wire to the bed, then individually fuse accessories off the buss.
  12. Dec 22, 2020 at 9:15 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    A winch can draw over 400 amps, so that changes the scope of the mod considerably vs. all the other accessories combined. A 500A weatherproof breaker is rather expensive, but a 500A fuse holder is only $8: https://www.amazon.com/Baomain-ANL-500A-Electrical-Protection-Holder/dp/B072PCPN1Q/ and there are better quality ones for $30: https://www.amazon.com/Thor-THANLFB-500-ANL-Fuse-Block/dp/B01M2DF03H/
  13. Dec 22, 2020 at 10:31 AM
    CT Yankee
    CT
  14. Dec 22, 2020 at 10:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Those Chineseium breakers typically trip at less than half their rated current, and the brand name ones (Eaton, Blue Sea) tend to be super expensive. More reliable at the low price points to have a separate fuse and switch.
    Skydvrr likes this.
  15. Dec 22, 2020 at 11:49 AM
    GladiatorNOT
    2017 TRD OR
    Looks like a singe lens Blackvue DR590 could be a good choice although I’ve never heard of that brand before. It does record 60FPS whereas the Garmin Mini only does it in 30. I’m guessing that might be a noticeable difference in video quality especially when viewing on a large TV?
    Thanks for all the input everyone!
  16. Dec 22, 2020 at 12:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Odd. Blackvue is usually the go-to brand for dash cams lol. The DR590 comes in 1-CH and 2-CH kits. The 2-CH kit includes a second slave camera you can attach to the rear glass. I set the camera to record in 30 FPS to reduce the file size (and get more hours of footage on the SD card).
    vicali likes this.
  17. Dec 22, 2020 at 12:25 PM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Dash cams on the windows are not ideal to record your offroading adventures. Maybe it's good while you're driving and it captures beautiful scenery in the distance, but it does not help capture your truck and what it's doing while wheeling.
    I have a dash cam recording at all times when driving for sole purpose of having proof to back up any claims for insurance and law enforcement.
    You can get a go pro with suction mount to stick on the side of your vehicle if that's what you want. (technically can use as a dash cam too)
    GladiatorNOT[OP] likes this.
