best diff lube?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChrisGralnic, Apr 4, 2013.
  1. Apr 4, 2013 at 11:24 AM
    ChrisGralnic
    ChrisGralnic [OP] Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    Replacing rear diff oil on Tuesday, best one to use? Dino or synth? I hear synthetic will cause leaks. Any experience?
  2. Apr 4, 2013 at 11:30 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    you have the LSD right???
  3. Apr 4, 2013 at 11:36 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    lucas is the best way to go
  4. Apr 4, 2013 at 11:37 AM
    ChrisGralnic
    Southern cali
    No its a base prerunner.
  5. Apr 4, 2013 at 11:53 AM
    ChrisGralnic
    Southern cali
    I use lucas upper cylinder lubricant. Love that stuff. Ill check it out.
  6. Apr 4, 2013 at 2:09 PM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    I'd be looking at Amsoil Severe Gear 75W90. Mobil 1 75W90 is easy to find and reasonably priced, as is Valvoline SynGear. Royal Purple got too big for their britches(man, my mom used to say that when I was a kid) in the last 5 years and their pricing is out of control, esp. their gear oil.
  7. Apr 4, 2013 at 2:13 PM
    ChrisGralnic
    Southern cali
    Thanks. I think I'll try the ams.
  8. Apr 4, 2013 at 2:19 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Jut sayin...I sell amsoil and use lucas
  9. Jun 3, 2013 at 11:41 AM
    ChrisGralnic
    Southern cali
    *update* I ended up using Royal Purple. Manual called for 1.6 in the rear and 2.7 in the gear box. Little did i know it would take 3 in the rear, and 3 and a half in the gearbox. i had to use a quart of a different brand of high performance synthetic cause i ran out of RP. Hope they are compatible.
  10. Jun 3, 2013 at 11:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm guessing you mis-read the manual... The 8.4" rear diff should take about 3 quarts. The 1.6 quart number I believe is for the transfer case amount for the 4wd models.
    Out of all the brands, you do realize you paid a premium for purple oil, right? Royal Purple is decent enough oil but it isn't anything special other than the color.
  11. Jun 3, 2013 at 11:51 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Truff
  12. Jun 3, 2013 at 11:55 AM
    ChrisGralnic
    Southern cali
    I am moving to the extreme cold and needed to switch to a synthetic. I wanted to use Redline, because my gearbox was getting a little crunchy and i hear good things. but the part wholesaler my dads buddies shop used didn't carry it. they had castrol, mobil or purple. Chose purple. I figured i would give it a go. I will change it again soon to Redline after about ten thousand miles. I wanted to see if royal purples claim to "Smoother Shifting" was true. and i did notice a difference. But i still wanna use redline.
  13. Jun 3, 2013 at 12:07 PM
    Pugga
    Massachusetts
    What are you considering 'extreme cold' and why does that warrant a 'need' to switch to synthetic?? Dino oils have been around for a long time and there have been vehicles in those 'extreme cold' environments running on dino oils for a long time also. If you truely are going to put the truck into an extreme cold environment, a change in oil weight would help more than the switch from dino to synthetic.
    If things are messed up in your gear box and you are getting 'crunchy' sounds, no oil is going to magically fix your gear box. Did you have metal shavings in the oil when you drained the transmission?
    Redline makes some good stuff. Out of the options at your dad's buddy's shop, I would have gone with the Mobil.
  14. Jun 3, 2013 at 12:28 PM
    ChrisGralnic
    Southern cali
    No metal shavings. the synchro's just don't like 1st thorough 3rd for some reason. when i said crunchy i didn't mean sound wise. i meant feel. Since i changed the fluid it feels easier to slip into gears. I use synthetic everything. where i am going is only very cold a few months of the year. Not sure how cold it will get because ive never been there. (going to school) 8,500 Elevation.
  15. Jun 3, 2013 at 12:38 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I buy my lubricants on API spec...and a non-lsd rear end should be a API GL-5...and should be available in the five gallon bucket at your local FLAP for under $75.
    I keep a bucket on hand and go through about two a year.
    I maintain three trucks, a jeep and 8 motorcycles...
    Howard
  16. Jun 3, 2013 at 2:50 PM
    CrsOne22
    CrsOne22 Well-Known Member
    05 Tacoma 4x4
    K&N intake,magnaflow exhaust,5 piece billet grill, sway away 2.0 coilovers, blacked out emblems.
    I heard lucas does the job quite well.
  17. Jun 3, 2013 at 2:54 PM
    Pugga
    Massachusetts
    Damn, you're lucky everything takes the same oil. I maintain 2 vehicles and a motorcycle and the oils don't overlap at all :(
  18. Jun 3, 2013 at 3:52 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Mobil 1 ftw.... This is a completely subjective topic though, honestly, the fact that you are changing it is probably the most important part!
  19. Jun 3, 2013 at 6:29 PM
    Huntsonora
    Huntsonora Member
    Windsor, CO
    Amsoil or Redline for me
  20. Jun 3, 2013 at 7:24 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Valvoline, Mobil, Shell, Castrol GL5 spec for the diffs, GL4 in the trans
    Syn is at your discretion, I stopped using synthetics and just doing more frequent intervals myself. Napa has 80w90 made by Ashland (valvoline) that I use. Redline MT90 in the trans.
