best exhaust for the 4 banger?
Discussion in '4 Cylinder' started by 99toyotaco, Jun 24, 2010.
  1. Dec 9, 2016 at 11:11 PM
    #41
    Frankie L
    Frankie L Well-Known Member
    Frankie
    2001 silver Toyota Tacoma
    Magnaflow exhaust, leveled with 32" tires and 14" american racing rims
    I'm about to delete both my cats ✂️
  2. Dec 10, 2016 at 10:45 AM
    #42
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Why would you do that?
    Frankie L[QUOTED] likes this.
  3. Dec 10, 2016 at 8:35 PM
    #43
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've thought about the same thing when it comes time to replace my exhaust. Since the 2.7 will never be a power house and the stock exhaust with the cats works just fine my opinion for deleting the cats is the cost. Those things aren't cheap and if you're in a state that requires no emissions testing like me it makes sense. The problem is, what happens if you move to one that does. Then you have a problem.
  4. Dec 12, 2016 at 5:48 PM
    #44
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    LCEngineering header opened up the top end of the revs a lot. It's a 4 into 1 long tube setup that promotes HP gains. After that, just get a full header back because the stock piping has a lot of restrictions, and is pretty small in diameter.
    Mikeybuck likes this.
  5. Dec 12, 2016 at 5:57 PM
    #45
    GDT
    The stock exhaust is pretty nice, it's all mandrel bent, I'm not sure what restrictions you're talking about. It's my understanding that going to a larger diameter might open up the top end but at the expense of low end torque- that would not be an improvement in my eyes.
  6. Dec 12, 2016 at 6:10 PM
    #46
    MrCrowntown
    Alyn
    Ky
    I have the LCE header and a 3in exhaust and have gained response everywhere in the rev range. The acceleration from off the line will always be crap but thats what you get for having a 4cyl. You won't be getting any torque benefits from anything for these motors.
    The joints to the cats are tiny and with 2 cats down there you have 4 different pressure changes on the way out the exhaust.
  7. Dec 12, 2016 at 6:19 PM
    #47
    GDT
    Well, that's just not true. The lce header is know for boosting torque, but you may have negated that effect by losing your back pressure with the 3" exhaust.
    This guy has done some dyno runs, with a few different configurations, with his main goal being to increase torque and lower the torque peak in the rpm range, the thread is worth a read:
    https://www.tacomaworld.com/threads/2-7-dyno-charts.285741/
    2.7taco likes this.
  8. Dec 12, 2016 at 6:57 PM
    #48
    MrCrowntown
    Alyn
    Ky
    I know about tooter.
    The nature of 4cyl is what will negate any initial off line torque. It will take a moment for enough combustion cycles happen per second to allow for adequate volumetric efficiency to be achieved. Then, the supporting mods will be utilized to their full potential. I'm in the process of putting a turbo on my motor because of the lack of bolt on torque and power for this platform.
    You can dismiss whatever you want, just know that I have been through all this already, a long time ago. Just trying to help out
    Bizquick, tacoburrito and boostedka like this.
  9. Dec 12, 2016 at 7:15 PM
    #49
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Yeah effen turbo!
    :burnrubber:
  10. Dec 19, 2016 at 6:18 PM
    #50
    snefo
    snefo Well-Known Member
    I gained 1 to 2 mpg by swapping out the stock manifold for an LCE header.
    One thing to keep in mind is, when you balance the flow with an equal length header, all cylinders get the same fuel mixture, which means no wasted fuel.
    With uneven flow, the ecu (using the O2 sensor) adds fuel to all cylinders until the leanest one gets enough fuel. This leaves some with extra fuel which gets burned by the catalytic converter.
    My engine also runs smoother than with the stock market exhaust. The engine will be easier on oil also.
    I like quiet and it still is. The stock pipe and muffler is more than big enough.
    Greenbean, tacoburrito, GDT and 2 others like this.
  11. Jan 17, 2017 at 6:51 AM
    #51
    Frankie L
    Frankie
    @GDT I alrdy did it and it sounds beast asf. Makes my 4 banger sound like a 6
  12. Jan 17, 2017 at 6:51 AM
    #52
    Frankie L
    Frankie
    Cat delete with dual magnaflow
  13. Jan 17, 2017 at 6:52 AM
    #53
    Frankie L
    Frankie
    Stock exhaust on a yota is lame
  14. Jan 17, 2017 at 7:17 AM
    #54
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I have awd eagle talon tsi..after upgrading to a bigger turbo, fuel rails ect..
    I did a Cat delete and borla pipes&muffler.
    It has been a chore to get inspected each year. lucky we do not have smog checks.
    I have heard (rumors) that removing catalytic converter is a felony?
    Is this true? I had a Mechanic a few years back that swore to me, that the police Could impound and or crush the car?
  15. Jan 17, 2017 at 11:37 AM
    #55
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Flowmaster 50 Delta is what i have on my 2.7L and i think it sounds great. I ran a Thrush turbo muffler for a while and its like all the sound came into the cab (drone) and not out the pipe. The FM has very little drone and sounds sweet outside.
    https://youtu.be/k1T0bFB7bkk
    TacomaMike25 and TacomaToasted like this.
  16. Sep 1, 2017 at 7:08 AM
    #56
    TacomaToasted
    TacomaToasted New Member
    2013 tacoma 4x4
  17. Sep 1, 2017 at 7:10 AM
    #57
    TacomaToasted
    2013 tacoma 4x4
    I don't know about all that, but if caught you could pay 10k in fines, I work at a muffler shop and I refuse to cut the cats out, now if you cut it off yourself and bring it to my shop I'll weld on a pipe , but I wouldn't do it to mine
  18. Sep 3, 2017 at 3:39 AM
    #58
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Dang that sounds pretty good IMO,
    Mind linking the exact part number, I might cut out my stock muffler or well have an exhaust shop do it and weld in one of these.
    I like the way that sounds. :thumbsup:
    Speaking of cats,
    years ago there was a web-site in business called www.testpipes.com, no longer there but they had a huge plethora of bolt in "test pipes" for offroad use only, you could easily remove your cat and install said "test pipe" with O2 bungs and have at it.
    Lets just say an RSX-S with a DC 4-1 header, "test-pipe" O2 sim and a T1R mid-pipe and Spoon muffler could hold bumper to bumper with a WS6 on the freeway up to an undisclosed speed over the limit.
    All was done on a closed section of an abandoned runway too!
  19. Sep 4, 2017 at 7:35 AM
    #59
    Mitch76
    Mitch
    San Angelo, TX
    I got mine off Amazon. Just search Flowmaster 50 Deltaflow. 2.5 in and out. I think mine was dual offset.
    Greenbean[QUOTED] likes this.
  20. Sep 5, 2017 at 7:59 AM
    #60
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    What is the best exhaust? The factory equipment works pretty good. Unless you have spare cash burning a hole in your pocket and nothing better to do, most people won't fix something that isn't broken. Maybe it's just me, not bitten by the mod bug.
    BillsSR5 likes this.
