best gear oil - manual?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Feb 7, 2021.
  1. Feb 7, 2021 at 10:55 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    currently running a manual 6spd 4x4
    RA60F
    what is the best gear oil?
    I can't find any listed as compatible from known good companies such as Ravenol, Fuchs, and so on
    I will check Castrol
    I don't see why other good companies wouldn't work, if the weights are similar (75w80, 75w90, etc.) because at the end of the day, I don't see why other brands are any different.
    If you take another brand vehicle with a 6-speed, it still has gears.
    It still has brass synchros that the fluid must not corrode, and high pressure that the fluid must handle.
    If anything, it should have some thinness to have good cold shift properties.
    Motul and Redline suck
    Amsoil says they offer this to fit the RA60F
    I might try it
    Who knows if it's good, time will tell
    often times, companies will say their product is The Best Ever
    even if it's really Hot Garbage
  2. Feb 8, 2021 at 2:44 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
  3. Feb 8, 2021 at 5:27 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I just put redline MT90 in my new-to-me truck. I noticed a slightly smoother shifting experience?
    specter208, Sna and Grossomotto like this.
  4. Feb 8, 2021 at 6:08 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Redline MT90 is a fan favorite, many use it across all brands and manual trans owners.
    specter208 and Sna like this.
  5. Feb 8, 2021 at 8:07 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Open the Owner's Manual (OM). Look up the specs for your tranny.
    Go buy an oil that meets those specs. You need to consider more than just the viscosity of the oil. There are API GRADE specifications like GL5 or GL4 which need to be matched with OM specifications.
    Many good brands are readily available.
    What is "best" will be loaded with opinions and anecdotal experience.
    In short, the OM will have the API Grade and the Viscosity specifications. Match the OM and all will be good.
    ZColorado likes this.
  6. Feb 8, 2021 at 8:15 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    6MTPro and jkuniverse like this.
  7. Feb 8, 2021 at 8:17 AM
    wrightme43
    Just read the reviews on Amazon.
  8. Feb 8, 2021 at 8:24 AM
    Knute
  9. Feb 8, 2021 at 8:41 AM
    JCzerosixtaco
    JCzerosixtaco Well-Known Member
    KY
    2006 SUPER WHITE ACLB MT, TRD OR, TP, SR5
    Total stereo replacement, TRD Exhaust, Fox 2.0 coilovers, 2.0 reservoirs with an AAL in rear for about 2.5 inch lift, gunmetal TRD 4Runner wheels wrapped in K02
    Another vote for redline MT-90
    Grossomotto and Sna like this.
  10. Feb 8, 2021 at 9:07 AM
    wrightme43
  11. Feb 8, 2021 at 9:08 AM
    wrightme43
    Description
    Motorcraft Full Synthetic Manual Transmission Fluid is a premium-quality SAE 75W-90 gear oil recommended by Ford Motor Company meeting warranty requirements. It is particularly recommended for 1995-2011 MTX-75 and IB5 transmissions, and is also recommended for older transmissions including rear wheel drive that recommend GL-3 and GL-4 type gear oils
  12. Feb 8, 2021 at 9:10 AM
    Knute
    Adding comments to quotes........interesting tactic.
    The Amazon link does not cite viscosity or API Grade. Even the label pictures, magnified, don't indicate.
    Thanks just the same. Still prefer the description on the label over some market typed description.
    Your truck, your choice, your cash.
  13. Feb 8, 2021 at 11:07 AM
    wrightme43
    Dude it just didn't post right. I have no idea why it posted like that. I am holding a baby, and he is kinda grabby on the phone.
    Seriously look.
    Description
    That or just remain intentionally ignorant. Your mind, your choice.
    The spec is available to anyone. It has been the go to performance fluid for bronze syncro transmissions for scca for years and years.
    Doghouse61 likes this.
  14. Feb 8, 2021 at 11:10 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Yeah, I thought redline was the go to gear oil for this truck?
  15. Feb 8, 2021 at 11:36 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    I ran redline MT90 in a x runner for at least 50 thousand hard miles but what do I know?
    specter208, EdgemanVA and Sna like this.
  16. Feb 8, 2021 at 4:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I use a nice blend of MT-90 and MTL
  17. Feb 9, 2021 at 9:06 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I'm still running Redline in my 2008 X-Runner's diff and transmission. I think it's GL-4 in the transmission, and GL-5 in the diff.
  18. Feb 9, 2021 at 11:57 AM
    TacoTuesday1
    FL
    i wouldn’t call revving through the gears on a paved road in 2 wheel drive “hard”
    see post 1
    Redline MT90 sucks
    carve it in the wall
    TireFire and 6 gearT444E like this.
  19. Feb 9, 2021 at 4:38 PM
    Saffa
    Saffa Well-Known Member
    Victoria, British Columbia
    2015 TRD Sport DC 6MT
    I got my truck October last year, and I could not believe how notchy the shift was, trying to shift smoothly to third gear was hard and don't even try to downshift
    After filling the transmission with Redline MT-90 it got better and after using it for about 2000km it got really quite good compared to what it was
    Sna and RHHousehold like this.
  20. Feb 9, 2021 at 4:49 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I thought this was eye opening.....
    "Conclusion
    As the testing indicates, AMSOIL Severe Gear ranked highest among all gear lubes tested. It was the only gear lube to score a 4 or better in all performance categories. The high ranking of AMSOIL Severe Gear clearly points to a well-balanced formulation capable of delivering effective, long-lasting lubrication protection to all differential components. Most notable is the superior performance of AMSOIL Severe Gear in the critical areas of extreme-pressure protection and viscosity and oxidation stability. Based on the performance testing, the slightly higher than average price of AMSOIL Severe Gear would be offset by the cost savings achieved through reduced maintenance, longer lasting differentials and extended lubricant life. Some gear lubes tested well in some areas but scored low marks in others. Torco SGO Synthetic scored highest in viscosity index and cold-temperature Brookfield viscosity but sheared out of grade, failing the SAE J306 requirements for SAE 75W-90 gear lubes. Mopar and Royal Purple scored well in the 4-Ball EP Weld Test, but failed the Copper Corrosion Test and GM, with a good 4-ball EP score, foamed badly after oxidation. This would indicate that too much emphasis in one area of formulation can detract from performance in others. A gear lube is only as good as its weakest link. A well-balanced gear lube formulation, therefore, is critical for differentials in all types of vehicles, both standard and high performance. With more horsepower, more towing capacity, higher hauling limits and changes in vehicle design, more stress than ever is placed on differential gears. High-quality lubrication is essential, and awareness is now necessary to ensure maximum differential performance and to avoid costly repairs. When purchasing gear lube the decision is left to the consumer, yet based on the facts reported in this document, AMSOIL Severe Gear is the logical choice. Note: To further verify the findings, additional testing was performed on AMSOIL Severe Gear. The L-37 Axle Rig Test evaluates load-carrying, wear protection and extreme-pressure properties of gear lubricants. The severity of the test was increased to challenge AMSOIL Severe Gear to the absolute limits in gear lube performance......"
