best gear oil - manual?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Feb 7, 2021.
  1. Feb 9, 2021 at 4:56 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I use a blend of Lucas 85w140 and Lucas heavy duty oil stabilizer.
    Green Jeans likes this.
  2. Feb 9, 2021 at 5:30 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've had good luck with Lucas and Royal Purple. And no, I'm not a Royal Purple fanboy.
    I've never tried the Redline stuff. Lucas and RP were both better than the stock fluid. I bought my truck with just under 12,000 miles on it so the Toyota flavored juice was not worn out and didn't look too bad when I changed it but it was noticeably better immediately and continued to smooth out over time. I can only imagine that the new fluid kind of 'seasoned' the wear surfaces over time.
    I use Lucas in the transmission and transfer case and something cheaper in the diffs.
  3. Feb 12, 2021 at 11:10 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Let us know when there's a premature gearbox failure using any brand oil, correct viscosity, with correct change intervals. Obsessing about this stuff and chasing after boutique brands is not worth the time. For a MT, it might be worth going for Redline for better shifting, but I wouldn't go further.
    wrightme43 and RHHousehold like this.
  4. Feb 12, 2021 at 11:21 AM
    digitalcarnivore
    digitalcarnivore Member
    06 TRD ACLB 4x4
    Agreed. I run Redline as its been suggested in many places on this forum, and I've personally had no issues. Theres a reason it's popular around here. Change it on time and you should be good.
    edit. If you choose to go with a unique option, post your results!
  5. Feb 12, 2021 at 11:29 AM
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    I buy whatever NAPA is selling, usually their branded stuff.
    Except that time I found bearing cage in my 2002 WRX gear oil. I replaced it with BG gear oil. Don't remember the trade name of it though. That transmission lasted another 100k miles before insurance bought the car with 337,000 miles on it.
  6. Feb 21, 2021 at 10:51 AM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    I recently switched to the Ford fluid from redline. Noticeably smoother shifts now. I’m happy with it and will continue to run it in the future. I wasn’t impressed with redline, I replaced the factory fluid with it and noticed no improvement.
    digitalcarnivore and wrightme43 like this.
  7. Feb 21, 2021 at 12:17 PM
    blur
    blur Well-Known Member
    digitalcarnivore and RHHousehold like this.
  8. Feb 21, 2021 at 12:48 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Redline makes excellent lubricants. Don't use the RACING synthetic oil in a vehicle with catalysts intact is the only thing I would offer, and then only the engine oil.
  9. Feb 21, 2021 at 12:52 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
  10. Feb 21, 2021 at 2:32 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Nah, it doesn't.
    digitalcarnivore likes this.
  11. Feb 21, 2021 at 2:48 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I’m pretty religious about spending way too much money on gear oil. Like every 30k religious. MT90 for the last 150k and no complaints.
    I run heavier 140 Redline in both boxes. Again, can’t complain.
