Best lift for stock rear but inch higher in front
Discussion in 'Suspension' started by Tacoma414, Dec 6, 2012.
  1. Dec 6, 2012 at 11:43 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    So here we go, I'm not on a king or fox budget, but Im going to keep my back stock maybe with 5100s to replace stock cause I'm at 96k on them, but I want the front at most an inch higher, I like the look, so what should I get for the front, I'm running 2" spacers right now and I want to offroad a little but 75% is onroad what should I get? I found a guy selling camburg 2.5s for 550 used with about 7k on them, downsouthmotorsports said that its worth getting but the fact they are used and I don't know the owner or past owners makes me nervous about getting them, sorry it's long but that's the situation I'm in, thanks for the input
  2. Dec 6, 2012 at 11:47 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Get em and re-build them when you can save up a little more......or learn to re-build yourself for cheaper!
    5100's set at .85 or 1.75" would be you cheaper option!
  3. Dec 6, 2012 at 11:50 PM
    Tacoma414
    Cody
    Agua Dulce
    I wouldn't even know where to start on how to rebuild, but billies at .85 have always been an option
  4. Dec 7, 2012 at 8:31 PM
    Tacoma414
    Cody
    Agua Dulce
    Any other input? Bump
  5. Dec 7, 2012 at 8:41 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    5100 at .85 was perfect with my stock rear when i had it that way. Let me know if you need fronts or rears, I still have them in the garage. PM me if interested.
    ~M
  6. Dec 7, 2012 at 8:42 PM
    SconnieHailer
    Marc
    ^ That being said, I really love my coilovers for off road but since your not a ton off road it wont really matter.
  7. Dec 7, 2012 at 8:45 PM
    Tacoma414
    Cody
    Agua Dulce
    Do you have any pics of that setup of when you had the billies on your truck? But I have a guy by has camburg 2.5s used with about 7k on them for 550 so I'm not sure on what to do
  8. Dec 7, 2012 at 8:51 PM
    SconnieHailer
    Marc
    I'm pretty sure this was billies at .85 in front and stock rear...
  9. Dec 7, 2012 at 9:11 PM
    Tacoma414
    Cody
    Agua Dulce
    So did it sit even? Cause I have 2" spacers and it is maybe a half inch higher in the front
  10. Dec 7, 2012 at 10:02 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Stock rear is 1.5" higher than front....usually!
    You'll be fine at .85!
  11. Dec 7, 2012 at 10:14 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    I'm confused OP... do you want the front 1" higher than you have it now (i.e. 3" total), or 1" higher than stock? Cause if you want 3" total, Billies plus spacers is not a good option.
  12. Dec 7, 2012 at 10:38 PM
    Tacoma414
    Cody
    Agua Dulce
    No I want to get rid of the spacers completely and just have a coil over but it sounds like it will be level but yeah wouldn't I need 2.5" lift in the front to make it an 1" higher then the rear?
