best light bulbs
Discussion in 'Lighting' started by tntacoma, Jan 22, 2010.
  1. Jan 22, 2010 at 10:29 PM
    tntacoma
    tntacoma [OP] Well-Known Member
    tn
    What are the best and brightest light headlight bulbs I can buy at my local parts store. Auto zone, advance auto, Orielly's..etc.
  2. Jan 22, 2010 at 10:53 PM
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
  3. Jan 22, 2010 at 10:58 PM
    Hambone805
    Hambone805 Well-Known Member
    Aaron
    San Diego, California
    2015 4x4 Tacoma TRD
    STOCK :(
    i have those sylvania silverstars on my truck, there alright. definitely brighter then stock but nothing amazing like HIDs. if your looking at local part stores the silverstars would be your best bet.
  4. Jan 22, 2010 at 11:16 PM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    harbor freight has some cool blue bright headlights
  5. Jan 22, 2010 at 11:39 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    These 3 words should never be put in a sentence. Blue actually means less light. The bluer you go the less light output you're going to have. To the OP, if you're set on only buying bulbs from your local store then get the SilverStars, won't last long though. Are you afraid of purchasing the bulbs online?
  6. Jan 24, 2010 at 12:37 PM
    tntacoma
    tn
    No, I am not afraid to purchase online, Just locally I would be able to go get them now instead of waiting. I am really interested in some HID's. I just don't know enough about them or what even is involved to convert over. Any info on this would be helpful.
  7. Jan 24, 2010 at 12:43 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I'm looking for replacement bulbs as well. After some reading in the internet, I decided to go for Philips Vision Plus instead of Sylvania Silverstar.
    You can find Vision plus for $12 to $26 in ebay. The SS cost $39 in Autozone.
  8. Jan 24, 2010 at 10:26 PM
    Hambone805
    Aaron
    2015 4x4 Tacoma TRD
    STOCK :(
    HIDs are the way to go. check out ddmtuning or a member on here named slimcubby does a group buy about once a month. i have never done an installation but it seems pretty easy. just a simple plug and play install.
  9. Jan 27, 2010 at 9:51 AM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    Not really. Kelvin is the scientific standard measure of temperature - it's the temperature in Celcius, plus 273. So, 4000K is really 4000 degrees (ish) centigrade... pretty damned hot. The temp of the sun (at the surface, not center) is about 6000 degrees centigrade, which is 6273 Kelvin.
    And higher does NOT equal sun like. 4000-6000 K is in the "white" range. Higher than that startes to go blue, and 10-13K is something in the purple range. Under about 4000K is orange/red/yellow ranges.
  10. Jan 29, 2010 at 8:40 AM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    Holy crap, so it is.
    Well, maybe they've appropriated the term "kelvin" for their own industry use?
    Anyway, from Wikipedia (look up "Kelvin" and the temperature definition comes first):
    "The kelvin is often used in the measure of the color temperature of light sources. Color temperature is based upon the principle that a black body radiator emits light whose color depends on the temperature of the radiator. Black bodies with temperatures below about 4000 K appear reddish whereas those above about 7500 K appear bluish. Color temperature is important in the fields of image projection and photography where a color temperature of approximately 5600 K is required to match "daylight" film emulsions. In astronomy, the stellar classification of stars and their place on the Hertzsprung-Russell diagram are based, in part, upon their surface temperature, known as effective temperature. The photosphere of the Sun, for instance, has an effective temperature of 5778 K."
    Guess Kelvin means a lot of things. Glad to see that I was right, if in the wrong context.
