best moderate lift for 2nd gen reg cabs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xwillx93, Jun 18, 2011.
  1. Jun 18, 2011 at 7:31 AM
    xwillx93
    xwillx93 [OP] Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    2009 Tacoma 4X4 2.7l 4 banger. I've been researching lifts forever and this will be my last post bfore i buy it! I'm looking into the 5100' from downsouth, then upgrading from 265/70/17's to 275/75/17's. Once i made a little more cash im gonna buy the Toytec 3" lift from toytec. Any opinions/comments on the lift will be appreciated and id like to see your setups too. so bottom line; whats your favorite moderate lift for the regular cab? Here she sits now; stock suspension
  2. Jun 18, 2011 at 7:53 AM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
  3. Jun 18, 2011 at 9:38 PM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
  4. Jun 19, 2011 at 2:03 AM
    fdizz
    fdizz Active Member
    frank
    lake tapps, wa
    Tacoma 4cyl
    5100's, volant intake
    my lil brother! haha... im thinking about the 3 in toytech coils with 2.5 OME leafs in the rear.... any opinions?
  5. Jun 19, 2011 at 6:59 AM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    :woot: whats up big brother!
    What are you running now? looks great!
  6. Jun 19, 2011 at 7:11 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I vote for the 5100's as the best low budget lift. And, these shocks are a nice upgrade as well. :cool:
  7. Jun 19, 2011 at 7:24 AM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    and so ive heard :cool:
    im lookin forward to it!
  8. Jun 19, 2011 at 7:25 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Why are you going to purchase the 5100s to only change them out to a toytec lift? Thats a waste of money. Just save up until you can buy what you really want.
  9. Jun 19, 2011 at 7:28 AM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    im going to buy the 3" toytec lift; it comes with coilovers, spacers and 2" AAL's. but at the same time im buying the 5100s
  10. Jun 19, 2011 at 7:30 AM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    2wd only... spindles!!
  11. Jun 19, 2011 at 7:33 AM
    Hardwater
    Hardwater Well-Known Member
    Great Falls, MT
    2011 MGM TRD AC
    1.5" Add-A-Leaf, Toytec Coilover kit @ 2", LR UCA's, Bilstein 5100's all the way around, ProComp 7032's, 265/75 16 Duratracs, bed mat, Weather Techs Digital Fit Floor Mats, Wet Okole Seat Covers, Satoshi
    If you really want to lift now and still upgrade later, you are probably best off going 5100's first and then getting the Toytec front coil over kit and purchase add a leafs. That way you can still use the 5100's.
  12. Jun 19, 2011 at 7:37 AM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    exactly what im looking to do! :bowdown:
  13. Jun 19, 2011 at 8:53 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm not sure 275/75R17 is a tire size that exists.
    Your stock size was either
    245/75R16
    Or
    265/70R16
    Or
    265/65R17
    While 265/70R17 is an oversize 32" tire.
    From there, you could go to 275/70R17 or 285/70R17 assuming you're running a 17" rim.
  14. Jun 19, 2011 at 9:00 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i vote ome for lift if you offroad alot. 5100s are good too but i think they dont handle the weight of offroad equipment like bumpers/winch as good as having a stiffer spring rate. unless you get 5100s set at 0 with ome coils
  15. Jun 20, 2011 at 10:44 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I agree, if an aftermarket bumper/winch combo are in your future, you will need springs at that point, and if a 3" lift is what your after as well, straight to the OME might be the better option for up front. I like the idea of using the 5100's set lower with an upgraded spring, so maybe all you will need to do then is change out the springs when you do the bumper/winch upgrade down the road if you start now with just the 5100's. Do some research, there are some who claim to have had issues with fitment with the OME springs and the 5100's. The OME springs were designed to fit with thier own shock line. Good products, proven around the world... Someone may chime in on this fitment issue...
    Both good entry level options for our trucks...
  16. Jun 20, 2011 at 10:57 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  17. Jun 20, 2011 at 11:04 AM
    Yoytoda
    Roland
    completely stock
    ithink 885s are good for a reg cab even with a bumper and winch. Especk has a full 3" of lift with the 885s and he has a bumper and winch on his reg cab
  18. Jun 20, 2011 at 11:07 AM
    fdizz
    fdizz Active Member
    frank
    lake tapps, wa
    Tacoma 4cyl
    so i have 5100s all around right now, i know i can use them in the front with the toytec coils, but will the 2.5 ome springs in the rear be too much lift for the 5100s back there?
  19. Jun 20, 2011 at 11:12 AM
    OZ-T
    Peter North
    British Columbia
    You are correct , I somehow missed the reg cab part
    I edited my earlier post
  20. Jun 20, 2011 at 11:16 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
