Best motor oil???!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Patrickd, Oct 28, 2009.
  1. Jun 24, 2011 at 7:07 AM
    #361
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    So they are betting that your truck won't make it to 300K on their oil...:eek:
    And this makes me feel good about using their product... why??:cool:
  2. Jun 24, 2011 at 11:29 AM
    #362
    Rowski
    Rowski Active Member
    Martin
    Phoenix
    TRD 4x4
    are we good to use rotella t synthetic on these trucks? i know its for diesel but it's a lot better in my car compared to mobil 1
  3. Jun 24, 2011 at 12:51 PM
    #363
    JBGKing
    JBGKing Member
    Plantation, FL
    Guys, Look on the bottle. Royal Purple, Mobile One, Valvoline, Castrol Oil, all say full or fully synthetic on the label. Thur research I have found that this means they are 75% synthetic. I checked Amsoil and thier bottles say 100% synthetic. One guy said that Amsoil is more expensive but on a recent check at Pep Boys Davie Speed Shop, Amsoil top tier 100% Synthetic is cheaper than all of them. Anyone that is not predigest knows the best oil on the market is Amsoil... The cheapest place I have found Amsoil is at AmericanLubes.com
    I have been using Amsoil on all my lubes for the last six months and not only have improved gas milage but have better pickup. If anyone finds a better price let me know.
  4. Jun 24, 2011 at 1:01 PM
    #364
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Damn I hit the wrong one. My vote is Mobil one synthetic
  5. Jun 24, 2011 at 2:53 PM
    #365
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    75% synthetic is 100% fine. Actually, I think 0% synthetic is most likely fine as well if you change the oil often enough.
    In other words, there is IMO no real life difference between the Amsoil and say the Mobil 1.
    Sorry, but I don't buy this. I have switched from Dino to synthetic on many cars in the past, some of them while living in Europe (supposed to be better synthetic oil over there). I have never seen better mileage, let alone "pickup". Maybe on a 2hp engine the (supposed) difference in friction would make a difference?
  6. Jun 24, 2011 at 3:25 PM
    #366
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Here in Texas it's so hot...............................How hot is it??
    It's so hot I saw a dog chasing a cat and they were both walking!
    Therefore I use Castrol 5w50 year around. 127K and no rod nuts in the drain pan yet!
  7. Jun 24, 2011 at 3:35 PM
    #367
    Rowski
    Martin
    Phoenix
    TRD 4x4
    in the subaru world (i know that subaru does not make the tacoma), mobil 1 is a bad oil. i'm surprised it has such a following.
  8. Jun 24, 2011 at 3:41 PM
    #368
    JKD
    JKD Well-Known Member
    What oil temperatures do you see? 5w50 is awfully thick at normal operating temperatures compared to 5w30.
    I used to run 20w50 in a really worn Dodge 383 to eke a few more miles out of it before the engine was done.
  9. Jun 24, 2011 at 4:04 PM
    #369
    Dave333
    Dave333 Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    I voted for Amsoil. Started using years ago and never looked back. I've also had my oil changes documented with Blackstone Labs. The two most recent are on the forums here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/122295-blackstone-tech-oil-report-amsoil.html
    To those who say that most synthetic guys would still change their oil every 5k, then they probably shouldn't be running synthetic. The whole point of a synthetic oil is to have a slower breakdown resulting in longer use. Looks like for daily driving in Atlanta heat, traffic, etc. 15k will be about all you can get out of Amsoil 0W30. Filter changes are every 7,500.
    I think most engine oils produced today are fine and engines last longer because of the technology going into building them. I still have a 67 Impala with a 396 running just fine with no rebuild. Tore it down and it looked good. I doubt whoever owned it the first 196k miles used synthetics and ran lab tests.
    I use Amsoil because it allows me to go almost a year in my Tacoma and yearly in my non-daily drivers without an oil change. I pay $7 a quart which for $42 (extra for topping off throughout the year) isn't bad for a 15k change interval. About the same price as someone putting cheaper stuff in at $20 a change and changing every 7500 miles.
    I plan on keeping the Taco until it dies, then dropping a new engine and transmission in it and going some more.
    Whatever you choose if you complete the proper preventative maintenance on your vehicle it should last a lifetime, literally. Minus that stupid temp gauge solder...but that was a 5 minute fix.
    Good luck.
  10. Jun 24, 2011 at 4:10 PM
    #370
    sechsgang
    Not necessarily. Synthetic oils can withstand much higher temps without coking, making them a necessity in some turbo charged engines. The Turbo can get so hot that sludge produced by conventional oil will kill the engine in no time.
    Does not really apply to the Taco though.
  11. Jun 24, 2011 at 4:34 PM
    #371
    sechsgang
    I use M1 5W30 most of the time, mainly because it's inexpensive and it makes me feel good because it says "fully synthetic" on it. :)
    I just bought 6 quarts at Costco for $24 or so. I use the OEM filter, just bought 4 of them @ $3.50 each. I change my oil every 5K miles, which translates to around every 6 months. Works for me. Well, under $25 per oil change.
  12. Jun 24, 2011 at 5:02 PM
    #372
    buddywh1
    Philly PA
    07 DC SR5 4x4
    research some more...
    100% synthetic means exactly the same as fully synthetic... nothing. They are both marketing terms with no strict definition.
  13. Jun 24, 2011 at 5:12 PM
    #373
    sechsgang
    For some this oil stuff seems more serious than their religion, lol.
  14. Jun 24, 2011 at 5:12 PM
    #374
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I don't think it matters all that much as long as the oil is changed very regularly.
  15. Jun 24, 2011 at 5:27 PM
    #375
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2. I was thinking of sending it out to Blackstone but at $35 plus postage it's cheaper for me to just change it more often so that's what I do. I use synthetic every 5,000 and whatever is on sale usually Shell from BJ's.
  16. Jun 24, 2011 at 5:45 PM
    #376
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Maybe not a religion... but hobby? yeah, I think that would cover it.
  17. Jun 25, 2011 at 12:16 AM
    #377
    george3
    New Jersey
    Oil has to meet standards. As long as they meet the standards and you change it on regular basis you are OK. The standards are represented by letters on the oil label - which I'm not going to take time to go look at now - If the letters are the same, one oil is as good as the other, just buy the one on sale unless you have $ to burn and it makes you feel better to pay more then go ahead - why not ?
  18. Jun 25, 2011 at 6:18 AM
    #378
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That's sorta true and is a real problem with turbo'd VW's, especially their 1.8T engines. But it's not the engine that ends up ruined... it's the turbo charger. When shut down the cooling water flow stops, as does oil flow to the turbo bearings. Already red-hot turbo temperatures bloom and cokes the oil in the turbo's oil passage restricting flow so the bearings go bad early and often.
    Same diff though 'cause the repair is super expensive, lending credence to the saying "if you can afford to pay for it with pocket change, you can afford a VW".
    Using synthetic or frequent oil changes helps but caring owners drive real gentle before shutdown allowing the turbo to cool or have an electric oil pump installed that circulates oil after shutdown.
  19. Jun 25, 2011 at 12:23 PM
    #379
    JKD
    Those are minimum standards.
    Like, set standards that every car has to be able to carry at least two people and go 60 mph. Both a Smart Car and a Lamborghini Aventador meet those minimum standards.
    I prefer the Lambo.
  20. Jun 25, 2011 at 12:31 PM
    #380
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Ryann Dunn preferred a Porsche... makes make me think the standard's good enough...
