Best motor oil???!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Patrickd, Oct 28, 2009.
  1. Mar 4, 2012 at 3:56 PM
    #461
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  2. Mar 4, 2012 at 3:57 PM
    #462
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Disagree. You should definitely check out www.bobistheoilguy.com.
  3. Mar 4, 2012 at 5:27 PM
    #463
    Syncros
    Syncros Well-Known Member
    Switched to Castrol Syntec 0w30 for winter, back to 5w30 when spring rolls around. I was using GTX before, the truck loves the switch to synthetic.
    I don't care if it "can last _____" I change my oil every 5000km regardless, I do re-use it for things around my shop though.
  4. Mar 6, 2012 at 1:28 PM
    #464
    B.Radd.KO
    B.Radd.KO Well-Known Member
    Blanalin
    Prince George, B.C.
    2011 Tacoma DC TRD Std.
    HID Fog/Hi/Low 3000W RMS Stereo TRD Quickshifter TRD Supercharger TRD Exhaust JBA Headers
    My 2011 had Conventional Oil and they recommended that I switch to synthetic after 16,000 KM.
  5. Mar 6, 2012 at 5:50 PM
    #465
    Rich91710
    Rich
    Los Angeles
    08 Base
    No reason to wait unless you prefer to do more frequent intervals on a new engine.
    Synthetic is not "more slippery" and won't interfere with break-in. It is simply better in all aspects. It is more shear-stable due to reduced viscosity improvers, it resists sludge formation at high temperatures, and it provides better cold-flow performance upon engine start.
    There is no reason not to want all 3 of those and every reason to want them on any engine.
  6. Mar 10, 2012 at 9:29 PM
    #466
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    amsoil.
    what.
  7. Mar 11, 2012 at 8:17 AM
    #467
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    The regularly changed kind.
  8. Apr 8, 2012 at 10:30 AM
    #468
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    Red Line
  9. Apr 8, 2012 at 2:13 PM
    #469
    feyded
    feyded Member
    Whidbey Isle, WA
    2012 Toyota Tacoma TRD OR
    Amsoil all the way.
    As some jokingly say, "Royal Purple spends more money on the purple dye than the oil".
  10. Apr 14, 2012 at 3:15 PM
    #470
    crf69
    Ohio
    ummm yeah
    amosil duh.
  11. Apr 14, 2012 at 3:21 PM
    #471
    gsxrdoug
    gsxrdoug 2009 X-Runner
    Douglas
    Hawaii
    2009 X-Runner
    Stock
    Wow first post is a poll on oil. I think every forum on the internet has an oil debate. Good luck, cause the ford, chevy, nissan, whatever car forum will probably have a different view.
    The key is make sure you change it regularly whatever you use.
  12. Apr 22, 2012 at 5:12 PM
    #472
    JayDirt
    JayDirt I owe it all to little chocolate donuts
    Royal Purple w/cheese...go Lakers!
  13. Jun 28, 2012 at 8:12 PM
    #473
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  14. Jun 28, 2012 at 8:23 PM
    #474
    Rich91710
    Rich
    Los Angeles
    08 Base
    Useless as a consumer-added additive.
    Zinc levels have been reduced in API SJ and later oils, but adding it is not going to help.
  15. Jun 28, 2012 at 8:46 PM
    #475
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Why is that?
    The fork shop mechanic I worked under a few summers ago said he ran some non zddp oil in some of the 4 banger clarks when they switched over to low % zddp and the engines went early compared to others. So for that reason we ran 15w40 in all of em. We had a lot and they got run hard, and had a lot of hours in a DE processing plant and that shit is nasty.
    Anyway, I've always wondered about the stuff. I knew they pulled it out of gas engine oils for emission reasons.
    edited to explain more
  16. Jun 28, 2012 at 8:51 PM
    #476
    Rich91710
    Rich
    Los Angeles
    08 Base
    ZDDP is a very effective friction reducer, but a couple of things:
    It's a last line of defense - By the time the zinc is "working", the rest of the oil's additive package and film strength is no longer doing it's job.
    As a consumer additive... like most consumer additives... it's worthless.
    It needs to be properly added and blended when the oil is produced.
    Yes, it's been reduced on modern oils in decreasing levels for the last 10 years.
    No... running the non-ZDDP oil is not what caused those engines to go... they were on their way out already.
    Like you said... they get run hard.
  17. Jun 28, 2012 at 9:17 PM
    #477
    Natey
    Natey Member
    Natey
    Santa Cruz, Ca
    2012 4Runner Limited
    NEO in my Toyota and Idemitsu in my Mazda :)
  18. Jun 28, 2012 at 9:22 PM
    #478
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm not worried about the Tacoma at any rate. Just something to BS about.
  19. Jun 29, 2012 at 3:00 AM
    #479
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Other... which means whichever synth Advance Auto has with their "oil change special" that week. Mobil1, Valvoline, Pennzoil, Castrol... it's all the same to me (and my truck) as long as it comes with a decent filter.
  20. Jun 29, 2012 at 5:14 AM
    #480
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    Amsoil or Mobil 1
