Best motor oil???!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Patrickd, Oct 28, 2009.
  1. Jul 12, 2012 at 8:31 PM
    #481
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    Schaeffer's 5w30 9000 full synthetic with Toyota Factory filter. Deeelicious.
  2. Jul 12, 2012 at 9:17 PM
    #482
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Just wanted to quote this.....
    Dead-nuts on the mark.
    Castrol or Pennzoil regular old "bought at the Stop & Rob" 5w30 changed every 5,000 is a "better" oil than a $10/qt custom made Group-25 unobtanium-infused synthetic that is left in for 25,000.
    Change it often and your engine will thank you.
    Change it often with Mobil-1 or Amsoil and your engine just MIGHT last another 100,000 or so... if you intend to keep your Tacoma that long.
  3. Jul 16, 2012 at 7:53 AM
    #483
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    Ask Utard. :stirthepot:
  4. Jul 17, 2012 at 3:28 PM
    #484
    rolltyd
    rolltyd Well-Known Member
    Jay
    Overland Park, Kansas
    2013 Off Road 4x4 Hankook Dynapro ATM
    Eneos. Good stuff
  5. Jul 23, 2012 at 10:47 AM
    #485
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    I've seen so many of the best looking used oil analysis wear metal numbers with Valvoline full synthetic or OEM, and I think a close second would be Pennzoil or Castrol synthetics. I run Valvoline Synpower or the Toyota OEM oil.
  6. Jul 30, 2012 at 9:29 AM
    #486
    nfowler
    nfowler Member
    Mid-coast Maine
    Tacoma SR5 4x4
    Stock
  7. Sep 2, 2012 at 11:01 PM
    #487
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    That's why I use Mobil 1 full synthetic Walmart sells the big jug for 26 bucks can't go wrong with that
  8. Sep 3, 2012 at 4:46 AM
    #488
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Whatever is on sale. As long as it has the API starburst logo you're good to go.
  9. Nov 25, 2012 at 7:42 PM
    #489
    taylorf16
    taylorf16 Well-Known Member
    Noah
    Salt Lake City, UT
    02 Double Cab 5-speed SAS
    Solid Axle 5-speed Chevy 63s 3 in lift front leafs Grey wire mod
    A buddy of mine did a ton of reasearch regarding the detergents, metal make up, wear, and longevity of oils and although Mobil 1 did great, the real winner was ROTELLA T6.. It's a synthetic motor oil made by shell and only sold at shell stations of wal mart for about $21-$26 for a 5 quart jug.
    A lot of friends run them in turbo trucks, subarus, and race bikes too... I used it and it's cheater than mobil 1, and the taco seems to like it.. I use the Mobil 1 extended performance filter and Rotella T6.. The taco can go 8,000 miles and still have good looking oil.
    /$0.02
  10. Nov 29, 2012 at 4:26 PM
    #490
    Helta
    Helta I am the Stig
    St. Louis, MO
    2012 Spruce Mica AC TRD Sport 4x4 V6 6spd
    I club baby seals and squeeze them directly into the crankcase.
  11. Nov 30, 2012 at 12:55 AM
    #491
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    AFAIK T6 only comes in a 5w-40 or 15w-40... I'm sure you can run it but it's not 5w-30, which is what Toyota specs.
  12. Nov 30, 2012 at 1:01 AM
    #492
    Cadha13
    Cadha13 初音ミク #1 Fan, and Bacon Wrapped Hot Dog Cook
    David
    Albuquerque
    2022 TRD OR DCSB 6MT
    OEM Bed Lights
    I just like opening a quart of fresh oil in the morning.
    Time for work tomorrow. This goes well with home brewed beer, or your favorite drink, I won't judge.
  13. Nov 30, 2012 at 1:10 AM
    #493
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    How much did that end up costin' ya? if you don't mind me asking
  14. Nov 30, 2012 at 6:06 PM
    #494
    Rich91710
    Rich
    Los Angeles
    08 Base
    And why are there two different types of ATF?
  15. Nov 30, 2012 at 11:08 PM
    #495
    Cadha13
    David
    Albuquerque
    OEM Bed Lights
    I am a Amsoil Dealer and that would set you set you back around a good $350. I got a OK price for it. :D
    I found some interesting things when I changed it all. First I found it had Denso's on the 1-3 bank and NGK's on the 4-6 bank. The truck was at 60K and still had the F-ing factory plugs. :mad: Also the diff chirped occasionally and found it had some red oil inside. Talk about a rip off, this is a Toyota Certified Used vehicle. Also found out that someone put regular PS fluid, not ATF for the PS.
    Changed it all, the truck runs smoother, shifts better and does not chirp at all. I call that good.
  16. Dec 10, 2012 at 10:33 AM
    #496
    ManMan
    ManMan Well-Known Member
    It actually comes in 1 gallon jugs (4qt) NOT 5qt jugs... Making it the same price as pretty much every other synth oil. Don't get me wrong.... Good stuff, I use it in my bikes. But no cost savings
  17. Dec 10, 2012 at 12:00 PM
    #497
    sunruh
    sunruh Member
    2013 DCSB PreRunner SR5
    without a UOA you guys are just typing a lot:
    here is one i did way way back
    The oil was in use for 5109 miles, 11925 on the truck.
    Sample date of 03/25/06.
    INSOLUBLES: 0.3%
    WATER: 0.0%
    ANTIFREEZE: 0.0%
    FUEL: <0.5%
    FLASHPOINT IN F: 375
    SUS VISCOSITY @ 210 F: 58.6
    ALUMINUM 3
    CHROMIUM 1
    IRON 8
    COPPER 2
    LEAD 5
    TIN 0
    MOLYBDENUM 92
    NICKEL 0
    MANGANESE 0
    SILVER 0
    TITANIUM 0
    POTASSIUM 1
    BORON 35
    SILICON 22
    SODIUM 169
    CALCIUM 1766
    MAGNESIUM 108
    PHOSPHORUS 690
    ZINC 758
    BARIUM 0
    that was Mobil Clean 7500 5w30
    and i ran that kind of oil till 25495. then switched to Pennzoil Platinum for the next 50,000 miles and finally to Pennzoil Ultra from 74819 till i sold it last week. at 101,500
    steve
    i have run both 5w30 and 5w20. with 5w20 the vvt kicks in a little easier so you kinda have to watch the right foot a little bit.
  18. Dec 10, 2012 at 12:06 PM
    #498
    ManMan
    With a UOA you're still just typing a lot!
    I've never had nor worked on an engine failure related to oil brand
  19. Dec 10, 2012 at 12:34 PM
    #499
    sunruh
    sunruh Member
    you may not have, but other things can be observed.
    like if you have a headgasket leak and coolant is in the oil.
  20. Dec 11, 2012 at 5:43 PM
    #500
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    sunruh,
    You "look" familiar . . . ThumperTalk? Welcome to TW!
