Best OBD Scanner for 98 Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tonybobo, Feb 1, 2021.
  1. Feb 1, 2021 at 6:00 PM
    Tonybobo
    Tonybobo [OP] Member
    1998 Tacoma
    Looking for advice on what scanner to buy for a 98 Taco. Need one that will read SRS and ABS codes. I’m overwhelmed by the online scanner descriptions, especially the number of negative reviews for each product. Don’t mind paying high $$$ if it works and is reasonably user friendly.
    Thanks
  2. Feb 1, 2021 at 6:32 PM
    jbrandt
    jbrandt Made you look
    Justin
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    Nic98Tacoma likes this.
  3. Feb 1, 2021 at 7:36 PM
    Tonybobo
    1998 Tacoma
    Thanks JBrandt. I bought an Autel ML 629 which was advertised as compatible but wasn’t. I believe on 98s the a 22 pin connector (on the engine block) is the plug in location and Autel’s cable is a 16 pin. Maybe it would’ve worked if I bought an adapter cable but I sent the Autel back anyway because its software wouldn’t download. From what I’ve read, many manufacturers of scanners say their products are compatible, and they might be for specific model years, but for older models and especially for ABS and SRS codes, these guys are either stretching the truth or don’t test their products on all years and just make BS marketing claims which is why I posted my question. Will Torque Pro work on a 98 Taco?
  4. Feb 1, 2021 at 8:14 PM
    treyus30
    treyus30 Well-Known Member
    Trey
    Mesa / AJ, AZ
    '99 5VZ Twin Turbo Pre-Runner
    Ask for a PDF
  5. Feb 1, 2021 at 8:34 PM
    Tonybobo
    1998 Tacoma
    Thanks treyus30. Looks like consensus is building for Torque products.
  6. Feb 1, 2021 at 8:38 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Ask for a PDF
    Yep, I have 4 vehicles and that combo has worked well for all of them.
  7. Feb 1, 2021 at 8:41 PM
    jbrandt
    Justin
    Sacramento, CA
    You want the plug under the drivers right knee for most obdII functions.
    Wyoming09 likes this.
  8. Feb 2, 2021 at 4:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I heard some of the older Trucks do not support the ABS or SRS codes there was a thread sometime back .
    Since I don`t have ABS I never worried .
