Best oil filter choice.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Aug 2, 2018.
  1. Aug 2, 2018 at 12:18 PM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
  2. Aug 2, 2018 at 12:19 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Toyota filters are cheap I'd go with those. Don't get a fram.
  3. Aug 2, 2018 at 12:36 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Is Toyota spin-on fitting on Baxter adapter?
  4. Aug 2, 2018 at 12:37 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    YZZD3
  5. Aug 2, 2018 at 12:54 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I got a ten pack of the oem toyota filters at some point - should be good for awhile. Can't remember where but I recall reading some study where they came out to be as good if not better than most of the aftermarket ones. Significantly better than some of the cheap aftermarket ones.
  6. Aug 2, 2018 at 12:56 PM
    BillsSR5
    bill
    2014 SR5
    I think the OEM filters contain more filtering media than all the aftermarket versions=better filtering, its the same for OEM paper air filters they have 3 layers of media whereas the aftermarket usually have only 1 layer
  7. Aug 2, 2018 at 1:02 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  8. Aug 2, 2018 at 1:31 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Just be careful with filters longer than the WIX. You will be that much closer to the skid plate. I use WIX all the time
    htxbrute likes this.
  9. Aug 2, 2018 at 2:58 PM
    Dacon
    Danny
    Gilbert, Arizona.
    As long as is not touching the skid plate I will be fine. Mall speed bumps are small enough.
    9TRDTCO likes this.
  10. Aug 2, 2018 at 4:04 PM
    Xena1
    Ron
    You will be happy with the set up. With the filter totally vertical you can fill it with oil prior to threading it on which will be around .2 quarts and then put 6 quarts in crankcase. Low oil pressure light will not even come on when you start it up. Lastly I would advise a few drops of loctite blue on the nipple prior to threading it in. This is not specified in Baxter instructions but will keep nipple from threading out when you change filter. A one inch 6 point deep socket will allow you to access adapter flange even with nipple in place. When you loosen spin on filter oil will pour down the side of the filter for a few seconds but it is very easy to catch it in a drain pan. Just some points which I have learned since I installed the adapter.
  11. Aug 2, 2018 at 4:09 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    i wish they just left the oil filter where it was on top of the motor.
    MannyS, bigmw and 02Duck like this.
  12. Aug 2, 2018 at 4:28 PM
    Dacon
    Danny
    Gilbert, Arizona.
    So far in 15000+ miles on it I have used only OEM cartridge filter.
    Did you see any improvements moving to Baxter and spin-on Toyota filter?
  13. Aug 2, 2018 at 5:49 PM
    Xena1
    Ron
    I changed to the spin on for convenience. Much easier to do oil changes and filters are less expensive. My first oil change with the cartridge was a bear. Cartridge was over tightened and a PITA to change. Oil changes now are a breeze and completed in one half the time.
    1bad2k likes this.
  14. Aug 3, 2018 at 1:47 PM
    Xena1
    Ron
    Got under the truck today and measured around 2" between the bottom of the WIX 51348 filter and the skid plate. Also watched the videos on the different filters and would agree the Toyota one appears to be the best, but WIX appeared to be right up there as well. The Toyota filter looks about 1" taller so it will work with 1" to spare. My concern would be if you hit something and damaged the skid plate. For me, I probably will stay with the WIX.
  15. Aug 3, 2018 at 2:04 PM
    FlyFisherCJ
    FlyFisherCJ Well-Known Member
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    By chance do you have a part number for the baxter adapter?? this sounds like a great idea!!
    Thanks!
  16. Aug 3, 2018 at 3:43 PM
    Dacon
    Danny
    Gilbert, Arizona.
  17. Aug 3, 2018 at 3:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Tullie D and nphagert like this.
  18. Aug 3, 2018 at 3:55 PM
    Xena1
    Ron
    This is not correct. The spin on filter has more filter capacity.
  19. Aug 3, 2018 at 3:56 PM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
  20. Aug 3, 2018 at 3:59 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Toyota 90915-YZZD3 spin-on filter is a bit longer and has IDENTICAL filtering element inside like the cartridge AND it has a by-pass valve that the cartridge type (on tacos now) does not have.
    Also the spin-on type has an anti drain back valve to keep more oil in the engine for easier and "wetter" start-ups that the cartridge also does not have.
