Best on road suspension for 2006 TRD Sport?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrFixit420, Jan 22, 2020.
  1. Jan 22, 2020 at 6:59 PM
    MrFixit420
    MrFixit420 [OP] Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    We are looking for a smoother ride than what we are getting from this truck. I just drove the Off Road version and the ride was much smoother. That is what we are looking for a smoother ride. So what is the best way to go?
    We want a little lift, 2 to 3 inches at most, but mostly a ride that absorbs the rough roads and smoothes them out without breaking the bank.
    Any suggestions from those in the know?
  2. Jan 22, 2020 at 7:29 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Lots of almost new off road factory take-offs go on Craigslist when people lift their OR. A 3rd gen takeoff will get you a 1 inch higher in the front.
    MrFixit420[OP] likes this.
  3. Jan 23, 2020 at 1:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Lots of posts on this so do a search for all.
    I put OEM Dakars on the rear and it went up about 2.5-3" and 5100s.
    Front 5100s set at 2nd from top got me about 1.75-2" with stock springs.
    Have full skids and allows alignment with stock control arms so saves that cost.
    I run stock size tires and the Falken Wildpeak A/T3W 265/70R16 clears the upper ball joint with about an 1" so be careful on bigger tires - again lots of posts on tires.
    Have chains for rear for ice and clay mud so even rear clearance can become an issue if you ever need to chain up.
    Rides well on highway and not too stiff. I do drives out west and AK so put mileage on.
  4. Jan 23, 2020 at 5:05 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    From your listed build, are you sure you are not experiencing the rough ride from your current 2" lift? What type of lift, tire size, and psi are you running ? Although the sport suspension is tuned more for street vs offroad, I wouldn't consider the sport rough by any means. If you want a 3" lift with smooth riding qualities, you will have to spend more to accomplish it. That will likely include front CO's (maybe UCA's) and a rear leaf pack. Running an AT tire at an acceptable psi(28-30) also factors in the ride quality.
    jackn7 and MrFixit420[OP] like this.
  5. Jan 23, 2020 at 6:40 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    Budget is everything when it comes to suspension, my toytec 2.0 rode nice, but my Fox set up is pretty darn smooth
  6. Jan 23, 2020 at 3:59 PM
    MrFixit420
    Portland Oregon
    Same kit on both trucks, Spacers front and rear, Front diff drop, rear shocks.
    I have owned sports cars and that is the difference I feel. The sport model is tighter and more like a sports car in feel. I haven't checked the tires but they are stock size on both. The Sport being 17's and the Off Road being 16's.
  7. Jan 23, 2020 at 4:01 PM
    MrFixit420
    Portland Oregon
    I wish I had the money to go all out but budget is not really there.
  8. Jan 23, 2020 at 4:03 PM
    MrFixit420
    Portland Oregon
    I was thinking something along this line. Don't want to go all out but want something smoother that absorbs the bumps better. Are the shocks up front the key? I think that is really where I am feeling the difference.
  9. Jan 23, 2020 at 8:53 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Spacer lift...I think we found your poor ride quality issues. Front spacers and I'm assuming rear blocks are the worst combo for a 2" lift you could possibly run on a tacoma.
  10. Jan 24, 2020 at 5:43 AM
    MrFixit420
    Portland Oregon
    Ok I have to ask why? I realize a spring and shock system is better but why do spacers make the ride worse?
  11. Jan 24, 2020 at 5:52 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Read through this a little. I found a 3rd TRD Off Road suspension locally and it improved the ride tremendously. I've seen most sell for around $200-$250 in my area. Very easy install, maybe a couple hours in the driveway with pretty basic hand tools. Make sure to get ones that are still completely assembled, that way you don't have to worry about assembling anything. I got an alignment done afterward, but there were no changes that needed to be made, still recommended to do it anyways. I don't know why Toyota made the Sport model so stiff.
    https://www.tacomaworld.com/threads/review-3rd-gen-suspension-on-2nd-gen.542843/
  12. Jan 24, 2020 at 5:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Go with a recent take off from an OR and forget the lift stuff since you don't off road.
    That will offer a very budget friendly and compliant ride.
    MrFixit420[OP] and TacoFergie like this.
  13. Jan 24, 2020 at 6:53 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Not sure which spacer lift you have but if it's a preload spacer, then it compresses the OEM springs more causing the stiff ride. The top plate spacer arguably rides like factory but you are extending the LCA and overextending the shocks which likely will bottom out destroying them before hitting the bumpstops.
    Rear blocks will cause premature wear to the factory leafs and also axle wrap, which seems common with those experiencing clunks with blocks(I've been there).
    Spacer lifts and rear blocks are the cheapest route for a reason but I guess if the truck stays on road and doesn't haul often, then this route is okay for those on a budget. I just don't agree with spending so much on a truck to cheap out on the suspension.
  14. Jan 24, 2020 at 9:22 AM
    MrFixit420
    Portland Oregon
    Makes sense. I wouldn't have done the spacers myself but they were on it when I purchased it. Definitely thinking getting 3rd gen. removed from a newer truck.
  15. Jan 24, 2020 at 9:24 AM
    MrFixit420
    Portland Oregon
    I like this idea. Does everything from the 3rd generation just bolt on? Rear springs included?
  16. Jan 24, 2020 at 9:24 AM
    TacoFergie
    Iowa
    If you get the 3rd gen suspension you may end with some cali-lean/carolina-squat/dog crapping in the yard stance if you add the spacer on top. Just an FYI
  17. Jan 24, 2020 at 9:25 AM
    MrFixit420
    Portland Oregon
    THANK YOU. That sounds like a great way to go.
  18. Jan 24, 2020 at 9:26 AM
    MrFixit420
    Portland Oregon
    No spacers will be used on new suspension.
    TacoFergie[QUOTED] likes this.
  19. Jan 24, 2020 at 9:31 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Check your tire pressure. Inside the door of a tacoma it states 29psi. Some tire shops could have you up near MAX psi for a P tire and i can cause a much rougher ride. Or you have Load range E rated tires this could also be part of it. I know suspension will do a lot more but this could be a simple way to help.
    I also have OR suspension on my Base model. won an ebay auction for $125 with leafs and everything.
  20. Jan 24, 2020 at 10:03 AM
    MrFixit420
    Portland Oregon
