Best paint to use in sliders.
Discussion in 'Armor' started by tacotruck93, Jan 23, 2020.
  1. Jan 23, 2020 at 5:39 AM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    Just got sliders back from the sandblaster and I'm looking for something that will hold up to the winter weather. Trying to find a place that sells steel-it near me (Akron,Ohio) but haven't been successful. Was just wondering if there are brands that you prefer.
    lynyrd3 likes this.
  2. Jan 23, 2020 at 5:41 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Mine are powder coated but I wish I sprayed them with bed liner on top of powder coat . Not even a year and I have some small chips and surface rust .
    tacotruck93[OP] likes this.
  3. Jan 23, 2020 at 5:45 AM
    tacotruck93
    Zach
    Akron,Ohio
    I think I want to stay away from a bed liner type as well. Once you scratch that off and salt gets under it's game over.
    lynyrd3[QUOTED] likes this.
  4. Jan 23, 2020 at 5:45 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Rustoleum in a proper primer then paint (and not the 2-in-1) has always been good to me. Three coats of primer then about half a dozen coats of paint. 3M grip tape on the top side to prevent wear from people using them as a step and you can just sand and use the 2-in-1 as needed for touch-up on the bottom - just stick some cardboard on top of them to protect the truck.
    The bedliner texture looks great but it has the same downfalls as powder minus the chipping from road debris. That's one area where a line-x or similar is superior to any other option but it doesn't handle sliding very well over time... it tends to come off in chunks and it doesn't reapply easily.
  5. Jan 23, 2020 at 5:46 AM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Do the sliders get used as sliders? If so, simple flat black spray paint or powder coat will work great. If not, bedliner will work great if longevity is more important. Some bedliners can actually be too abrasive, flaky, and grippy for the purpose of sliding on, if that makes sense. Easy to touch up though.
    tacotruck93[OP] and lynyrd3 like this.
  6. Jan 23, 2020 at 5:46 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Mine are rusting pretty bad again. I’m going to buy some Enrust. I’ve tried everything else. I work on ships and once it converts the rust it’s on there for life! The only thing is it’s $75.00 per gallon but you get what you pay for.
  7. Jan 23, 2020 at 5:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    www.monstaliner.com
    Use one of their other products as the base and/or finish coat. If you want a bit of texture (but no rubber chip stuff) use one of their bed liner products as a top coat.
  8. Jan 23, 2020 at 6:08 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    If a slider is used as intended, you'll be recoating from time to time. May as well use the product that you're most comfortable with. I love Raptor Liner and either pull the sliders off and recoat with a spray gun or touch up on the truck with a foam roller.
    nat103 and tacotruck93[OP] like this.
  9. Jan 23, 2020 at 5:34 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    VHT chassis paint or rustoleum
