best place to buy/mount tires on long island
Discussion in 'North East' started by Reptarthe2016taco, Jan 13, 2018.
  1. Jan 13, 2018 at 1:57 PM
    Reptarthe2016taco
    Reptarthe2016taco [OP] Active Member
    New York
    2016 ORD Taco
    Hey guys I am in the market for some new tires for the taco. Im thinking falken wildpeaks atw but not quite sure whats the biggest size I can get away with without rubbing and on a stock suspension and no spacers.
    Second part being where would be the best place to mount them, any shops on long island that specialize in it and maybe have road force balancing? I don't mind travelling so any help would be much appreciated!
    2016 TRDOR
  2. Jan 14, 2018 at 5:34 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    265/75/16 is the largest size you can go without rubbing. And go with the shop that is known for quality work and has a fair price.
  3. Jan 20, 2018 at 5:36 PM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Hey. As @MadRiverTaco mentioned 265/75/16 (32") would be the largest* size you can fit without cutting. I'm not from LI, so unfortunately I'm unable to recommend any shops... I installed my Coopers at Mavis in SI without any drama , they have shops in LI as well, but as mentioned before about recommendations.
    You could ask that question on Long Island thread Long Island, NY Tacos .
    Good luck!
    *some Taco owners are also using 255/85/16 (skinny 33") tires without cutting. Unfortunately not many tire choices in that size
    MadRiverTaco likes this.
