Best portable air compressor that won’t break the bank
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CementTaco4, Feb 9, 2020.
  1. Feb 10, 2020 at 8:21 AM
    La_Steveaux
    La_Steveaux New Member
    2004 Black Tacoma 4dr Prerunner
    Hornblasters.com !!! onboard air plus train horns to get those crazy drivers out your way. cept' you may have to sell a kidney to get one. around $400 up depending on your needs.
  2. Feb 10, 2020 at 10:29 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    88p here. Make sure to run the engine while your using it. I like to run mine while it's on the floorboard with the cold air from the AC blowing on it.
    whatstcp and VE7OSR like this.
  3. Feb 10, 2020 at 11:31 AM
    BrianPVan
    BrianPVan Well-Known Member
    Brian
    BC
    2017 DCSB OffRoad
  4. Feb 10, 2020 at 11:35 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    VE7OSR likes this.
  5. Feb 10, 2020 at 12:07 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    $50 high pressure Bike floor pump. Sold everywhere.
    shane100700 likes this.
  6. Feb 10, 2020 at 12:19 PM
    Vlady
    Issy, WA
    That's some news....
  7. Feb 10, 2020 at 12:23 PM
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    same. i have a Milwaukee M12 tire inflator that works great and i have a ton of batteries for it.
  8. Feb 10, 2020 at 2:10 PM
    Blackwolf
    Blackwolf Well-Known Member
    Paul
    Northern VA
    2018 Inferno DCSB TRD Off-Road
    VE7OSR and nd4spdbh[QUOTED] like this.
  9. Feb 22, 2020 at 11:32 AM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    What size tires do you have? What's the most PSI you've had to add to get to spec pressure? And how long did it take?
    Curious because I have started investing in Milwaukee M12 tools and I have the inflator on my list of things to buy.
  10. Feb 22, 2020 at 11:45 AM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    This one does the job for me, fits behind the rear seat. Loud because oilless.
  11. Feb 22, 2020 at 12:06 PM
    killthehippies
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    i run Falkens in 265/70r17. i think i've gotten them from 20 to 34 in 10ish minutes. it's something helpful to have in a pinch or if you want to take the guesswork out of getting to an exact pressure.
  12. Feb 22, 2020 at 12:10 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  13. Feb 22, 2020 at 12:23 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I bought one of those mv50 from pepboys ages ago, it was $30, looks like they are double that now.
    If you can get an old scuba tank and regulator you'll be a lot happier.
  14. Feb 22, 2020 at 12:27 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  15. Feb 22, 2020 at 7:29 PM
    #35
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I will probably order one of these to get me started. Even if I upgarde it's compact enough to be a good backup. Thanks for posting and including the bag as well.
    Edit: seems like they are coming with a bag now per comment below this one... I also saw a video where someone unboxed a new compressor and it came in a zipper bag.
  16. Feb 22, 2020 at 8:53 PM
    #36
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    I bought a v88p in December and it came with a bag.
    TacoTim85 likes this.
  17. Feb 22, 2020 at 9:32 PM
    #37
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  18. Feb 23, 2020 at 4:25 AM
    #38
    Chap79
    Chap79 Well-Known Member
    Virginia
    2020 TRD OR DCSB
    Ironman 2” lift, CaliRaised Sliders, 255/80 Toyos, SSO bumper, dual batteries, solar, OBA
    If you have a storage setup to secure a Puma 12v compressor it’s a great system. 3/4hp, 135psi, 1.36CFM,1.5 gal tank. Runs at about 30 amps, startup peaks at about 60 amps. Had one in my Land Cruiser. It could air up the 37’s from 15 to 35psi in about a minute 20 per tire.
    whatstcp likes this.
  19. Feb 23, 2020 at 5:17 AM
    #39
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I think it depends on the model you buy. If you don't get a bag with it you can use the box for storage. Just a little tough getting it all back in the box. With the mechanics bag you have a little extra room to coil the hose up next to the compressor.
  20. Feb 23, 2020 at 5:17 AM
    #40
    TripleEight
    TripleEight Well-Known Member
    2016 Tacoma TRD Off Road DCSB Gray
