Best/Proper Way To Debadge????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by punkassprettyboy, Oct 26, 2009.
  1. Oct 26, 2009 at 9:18 AM
    punkassprettyboy
    punkassprettyboy [OP] President
    Tommy
    North Jersey
    2010 sr5 v6 4.0 trd SPORT
    tints, led interior lights, debadged, security system w/ auto start, 2 800w 10" woofers, rain guards and tow package so far.....
    I hear a heat gun, IN WARM WEATHER, with dental floss and Goof-Off?:confused:
  2. Oct 26, 2009 at 9:21 AM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    I did mine this weekend using a blow dryer and 6LB fishing line.
  3. Oct 26, 2009 at 9:24 AM
    punkassprettyboy
    Tommy
    North Jersey
    Tomonian, how careful were you with the heat being applied to the paint? also would the manufacture date of my truck being 9-2009 pose a problem? i know paint needs to cure, but unsure of about how long...
  4. Oct 26, 2009 at 9:28 AM
    tomonian77
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    I used a blow dryer so the heat was never an issue. Heat guns can get super hot so I wouldn't suggest using one. As far as the curing question I cant answer that. I painted my rims, the body emblems and grill emblem in one day. The most tedious part of the whole process was cutting the tape for the remount.
  5. Oct 26, 2009 at 9:29 AM
    punkassprettyboy
    Tommy
    North Jersey
    awesome brother! sounds like a sweet ride...appreciate the help man!
  6. Oct 26, 2009 at 9:32 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yeap,hair dryer and fishing line works great.
  7. Oct 26, 2009 at 9:33 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea definitely use fishing line instead of dental floss. Dental floss tears too easily. You can use Goo Gone(not Goof Off, I think that's for something else) to get any remaining adhesive off.
  8. Oct 26, 2009 at 9:39 AM
    punkassprettyboy
    Tommy
    North Jersey
    anyone know if its safe to debadge if the production date on the truck was only one month ago? or should i wait a little while longer?
  9. Oct 26, 2009 at 9:39 AM
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    Wolfpack_5150 and I debadged our trucks-here is what we noticed:
    Using a hair dryer helps out a ton....dont use a heat gun as they can get way to hot and all that heat is not needed. We used 20 lb test and it still broke on us a few times....so finesse is the key...just slowly work it back and forth and try not to get it hung up on things. We then rubbed off all of the left over tape with our fingers and then brought out the goo gone...even then you could still see where the badging used to be so we then buffed out the paint with some rubbing compound, scratch remover and wax
  10. Oct 26, 2009 at 9:43 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    go for it punkass,remember your just using a hair dryer,not heat gun.keep it away about 4" and move it back and forth on the emblem.dont hold it on on one spot. u should b fine.good luck.
  11. Oct 26, 2009 at 9:47 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    use superline, or fireline for the fishing string. It will not break, and is as skinny as 10lb test line. I did mine on a brand new truckand didn't have any problems, didn't even use a hair dryer or heat gun. As GEARAHOLIC said, you can roll the adhesive off with your fingers right after you pull off the emblems.
  12. Oct 26, 2009 at 9:50 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Fishing line and a good pair of leather gloves. You will regret it if you dont use the latter of the two. Just take your time and use a sort of sawing action while applying pressure to the line.
    If it is cold out side or your truck has not been in direct sunlight prior to the start of your debadging, use a heat gun or hair dryer.
  13. Oct 26, 2009 at 9:51 AM
    SC4333
    Grant
    FL
    Oh and the newer the truck, the better. The longer you wait, the harder it will be to get all the adhesive off from the paint.
  14. Oct 26, 2009 at 9:52 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I never use a hair dryer... Just leave it out in the sun all day, as soon as 3 o'clock hits, the badges come RIGHT off with ease with fishing line.
  15. Oct 26, 2009 at 10:03 AM
    punkassprettyboy
    Tommy
    North Jersey
    you guys are all awesome thanks!
  16. Oct 26, 2009 at 4:07 PM
    altarossco
    altarossco Active Member
    San Ramon, Ca
    2010 double cab pre runner
    I removed side badges the day I brought it home & because I installed door guards where the emblems were. Yes, newer the better for debadging.
