Best replacement rotors and pads?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by caffiend, Jul 13, 2020.
  1. Jul 13, 2020 at 3:28 PM
    caffiend
    caffiend [OP] Well-Known Member
    2007 TRD Sport
    Is there a difference with TRD Sport? What has been best replacement for Rotors and Pads?
  2. Jul 13, 2020 at 3:31 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    OEM stuff is the best. It doesn’t cost much more and lasts for a long long time.
    DavesTaco68 and caffiend[OP] like this.
  3. Jul 13, 2020 at 3:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    How many miles on the rotors/pads you have now? Do you know what they are?
    OEM is generally just fine unless you are doing heavy braking from mountain driving or towing. Or towing in the mountains. Then upgrades may be worthwhile.
    caffiend[OP] likes this.
  4. Jul 13, 2020 at 3:46 PM
    doorsidedown
    doorsidedown Well-Known Member
    I installed hawk HPS pads & brembo blank rotors. Happy with them. Can’t argue with OEM recommendation either though.
  5. Jul 13, 2020 at 3:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Here is a good read.
    https://www.tacomaworld.com/threads/brake-upgrade-stoptech-rotors-trd-performance-pads.523829/
    I personally just went Ceramic form AdvancedAuto (Premium), New Rotors, and New Brake Hardware.
    No issues yet with almost 70k on them. I’ve never considered the 2nd Gens to be the best at stopping.
    I’m just to “cheap” to spend the extra money on “better” brakes.
    To really get better brakes, you could do a 4Runner swap. But like I said, I’m cheap.
    https://www.tacomaworld.com/threads...unner-bbk-upgrade-for-2nd-gen-tacomas.504234/
    MrFixit420 and caffiend[OP] like this.
  6. Jul 13, 2020 at 3:58 PM
    EZTacoma
    EZTacoma Well-Known Member
    Ezra
    Grand Rapids, MI
    05 TRD Sport AC 4x4 V6 6spd
    265/70/R17 Wrangler UltraTerrains
    NAPA stuff is good quality
    caffiend[OP] and TnShooter like this.
  7. Jul 13, 2020 at 4:32 PM
    caffiend
    2007 TRD Sport
    Original rotors with 148,000 miles.
    Pads about 30k
    Are both the same parts as a jon sport trd?
  8. Jul 13, 2020 at 4:36 PM
    Sharpish
    Brian
    Every 6 lug will be the same.
    caffiend[QUOTED][OP] likes this.
  9. Jul 13, 2020 at 4:52 PM
    caffiend
    2007 TRD Sport
    Why the difference between XRunner and Prerunner? Both are 6 lug.
  10. Jul 13, 2020 at 4:54 PM
    Sharpish
    Brian
    X runner is the fast and furious version of the taco lol. It has different part numbers for brake components? If so that would be interesting.
  11. Jul 13, 2020 at 4:55 PM
    caffiend
    2007 TRD Sport
    Looks like rotors have different part numbers.
  12. Jul 13, 2020 at 4:56 PM
    Sharpish
    Brian
    I think if it had better brakes the Interwebs would have been all over it for the cheap OEM brake upgrade.
  13. Jul 13, 2020 at 5:01 PM
    TnShooter
    Deogee
    STOCK
    XRunner is 5 Lug.
    EdgemanVA and Clearwater Bill like this.
  14. Jul 13, 2020 at 5:09 PM
    Sharpish
    Brian
    A 5 lug V6? I had no idea ...
    TnShooter[QUOTED] likes this.
  15. Jul 13, 2020 at 7:03 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Factory are best.
  16. Jul 13, 2020 at 7:21 PM
    caffiend
    2007 TRD Sport
    Is it a good time to replace the bearings too? 148K miles
  17. Jul 13, 2020 at 7:34 PM
    TnShooter
    Deogee
    STOCK
    If they have any play in them or make any noise. Yes, replace them.
    Other wise, I wouldn’t just yet.
    If you choose to replace them.
    You should replace BOTH inner and outer dust seals.
    Buy GOOD bearings, unless you want to risk doing them again in a couple years.
    Buy the WHOLE Hub Assembly. It’s much easier on you (or the mechanic)
  18. Jul 13, 2020 at 7:35 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    found this to be true !!
    good luck
    TnShooter and caffiend[OP] like this.
  19. Jul 18, 2020 at 9:35 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I just installed some Akebono ceramic pads on the front. Around $67.00 on the Amazon. It stops smooth.
  20. Jul 18, 2020 at 11:24 AM
    MrFixit420
    MrFixit420 Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
