Best Suspension lift for a budget.
Discussion in 'Suspension' started by Js1287, Apr 21, 2015.
  1. Apr 21, 2015 at 1:13 PM
    Js1287
    Js1287 [OP] Member
    Josh
    San Antonio, TX
    2015 TRD Sport 4x4
    What's up guys? I just bought my 2015 TRD Sport 4x4 yesterday. I am looking to put a suspension lift on my truck and I would like to run 33" tires without having to do any cutting or grinding.
    I am not looking to spend a lot of money because I do not do any major off-roading, really just want a good look on the truck and have a bit more ground clearance.
    Does anyone have a recommendation on a lift kit that is good but not expensive that will allow me to run the tires that I want?
    Thanks.
  2. Apr 21, 2015 at 1:14 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    OME suspension, wheelers has the best customer service and I highly recommend them.
  3. Apr 21, 2015 at 1:16 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    33 will still require cutting and grinding.
  4. Apr 21, 2015 at 1:18 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    X2
    If you want to go cheap get 5100s set to 1.75 on stock springs and 2" blocks...should be enough to run 285s at least but please don't complain about the ride
  5. Apr 21, 2015 at 1:21 PM
    Js1287
    Js1287 [OP] Member
    Josh
    San Antonio, TX
    2015 TRD Sport 4x4
    Thanks. I would like to have something with a decent ride since it will be my everyday vehicle.
  6. Apr 21, 2015 at 1:23 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    No you can not run 285's with 5100s set at 1.75 plus it will ride terribly (i had a set for a few months, hated it). OME will ride the best, if you don't want to cut very much go with 887 coils and Dakar spring pack so you don't have any bro lean. OME will ride the best for a budget lift
  7. Apr 21, 2015 at 1:24 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Leave it stock then.
    Step up to a better tire in a C or D load range for comfort, E range will be a harsher stiffer ride.
    If you must lift it for the look, since only tires give you actual ground clearance then lift the front 1-2 inches to level the truck out with some quality gas struts and maybe a lift spring.
    Quality is not cheap.
    Budget suspension equals budget ride comfort.
  8. Apr 21, 2015 at 1:26 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    OP, what is your budget? Might help us out a bit..
    x3..285 you will have to cut and trim..
  9. Apr 21, 2015 at 1:32 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
  10. Apr 21, 2015 at 2:34 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    That is only true for solid axles. With independent front suspension you can do a suspension lift (kings/OME, just not drop bracket) and gain true ground clearance.
  11. Apr 21, 2015 at 2:38 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    minimal in front and nothing in rear.
    Larger tires are the best way for ground clearance.
