Best Suspension/Lift To Compliment 265/75/16
Discussion in 'Suspension' started by IrishPilot, Jan 1, 2010.
  1. Jan 1, 2010 at 2:01 PM
    IrishPilot
    IrishPilot [OP] Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    From what Ive read, it seems like 5100s with an AAL in the rear is the most common setup for a light lift for 265/75/16s. Are there better/other options for a guy who does minimal off-roading and would really like a decent ride?
    Im not thinking much of a lift, just something a little higher than stock to pair with the new tires to give a bigger look. Any suggestions would be greatly appreciated.
  2. Jan 1, 2010 at 2:33 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Depending on if you have the budget Fox 2.0's with the adjustable reservoir and not much preload.
  3. Jan 1, 2010 at 2:35 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    265s will fit on your stock suspension... if that's what you want, there's no need to lift... :)
  4. Jan 1, 2010 at 2:40 PM
    Jason'sLawnCare
    x2. But I was saying what would give him a great ride quality.
  5. Jan 1, 2010 at 2:41 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    stock ride baby! :D :D :D
    :laugh:
  6. Jan 1, 2010 at 2:42 PM
    Jason'sLawnCare
    Ok. You win. :D
  7. Jan 1, 2010 at 2:51 PM
    IrishPilot
    MN
    Yeah I know she will fit stock, but from looking at peoples pictures, it seems some lift really helps the look of the truck in my opinion (I know...how shallow right?) Case in point:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/67688-my-taco-complete.html
    I was thinking 5100s at 1.75 and AAL in the rear would do the trick...but figured I would poll the masses just in case. Im pondering whether or not to go 5100s in all 4 corners as well or just the adjustable fronts.
  8. Jan 1, 2010 at 3:01 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    I'm not a fan of the 5100s... however, they're a good way to lift your truck in the front at a decent price.
  9. Jan 1, 2010 at 3:04 PM
    Jason'sLawnCare
    If you only want a little lift I would do adjustable fronts and if possible get the leaf spring tsb to bring the back up.
  10. Jan 1, 2010 at 4:32 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    With that size tire I would just leave the suspension alone. Maybe use a 1/2 inch spacer on the driver side and a 1/4 inch one on the passenger side, then you can keep your factory ride.
