Best Timing belt kit?? Recommendations pls
Discussion in '1st Gen. Tacomas (1995-2004)' started by LAL00O00, Jun 21, 2015.
  1. Jun 21, 2015 at 9:03 PM
    LAL00O00
    LAL00O00 [OP] Well-Known Member
    Jorge
    San Diego, CA
    2001 TRD Taco
  2. Jun 21, 2015 at 9:51 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I would avoid autozone/pepboys altogether unless you know exactly what brand you are going for. I get everything from www.bmaparts.com, just send them and email and ask for avaliable options.
    Being said, Contitech it good, so is Victor Reinz, or OEM. Any OEM replacement will be fine. Be sure to do the tensioner, and anything else that's easy to get to while in there.
  3. Jun 21, 2015 at 9:56 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    I got my Toyota kit from eBay... Only thing not Toyota was the water pump it was asini brand, but from my understanding its Toyota oem anyway.
  4. Jun 21, 2015 at 9:56 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    $188.56 - Aisin TKT-025 Engine Timing Belt Kit with Water Pump (Amazon)
    I believe Aisin is Toyota's OEM waterpump manufacturer. I can say this from personal experience when I ordered an Aisin waterpump kit for my wifes 99 camry. It looked exactly the same as the original toyota waterpump. The only difference between the Aisin waterpump and the original one was that the Aisin one had the "Toyota" name grinded down (for legal reasons I assume... I imagine the pump was cast in the same mold). I just did a timing belt on a 99 civic hx and used an Aisin timing belt kit. It has a Mitsobushi timing belt, koyo idler pulley, and a Honda tensioner spring in the original Honda bag. The waterpump was different from the original honda one but appeared to be of good quality.
    I recommend getting front engine seals for the camshafts and crankshaft as they are not part of this kit. Try amazon or rockauto. The kit on rockauto is about $8 cheaper and you can get seals there too for cheap. I would get a bunch of stuff youll need later. Spark plugs, Air/fuel filters, wipers, brakes, etc...
    Much cheaper then $322.52 from advanceauto -- and you can get more parts.
  5. Jun 22, 2015 at 4:05 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    MindFork likes this.
  6. Jun 23, 2015 at 9:48 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
  7. Jul 10, 2015 at 4:27 PM
    LAL00O00
    Jorge
    San Diego, CA
    2001 TRD Taco
    awesome but how do i now if my truck came with an oil cooler from the factory?
  8. Jul 10, 2015 at 4:45 PM
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    From my understanding if it came with the towing package with a different clutch fan(orange or green).
  9. Jul 10, 2015 at 4:55 PM
    LAL00O00
    Jorge
    San Diego, CA
    2001 TRD Taco
    Clutch fan is green
  10. Jul 10, 2015 at 4:58 PM
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    are you asking because the timing kit reads for engines with oil cooler? FYI all v6 have engine oil cooler.
  11. Jul 10, 2015 at 5:00 PM
    LAL00O00
    Jorge
    San Diego, CA
    2001 TRD Taco
    Yea thats why im asking but all v6 engines come with an oil cooler than?
  12. Jul 10, 2015 at 5:03 PM
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    engine oil cooler - all v6
    transmission oil cooler - option
  13. Jul 11, 2015 at 9:55 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yep, Aisin also makes the automatic transmissions in these trucks as well. They are a big contractor for Toyota and they make great stuff.
    Ceddingermtb likes this.
