Best Tires (?)
Discussion in 'Wheels & Tires' started by TacomaMan07, Aug 6, 2010.
  1. Aug 6, 2010 at 12:02 PM
    TacomaMan07
    TacomaMan07 [OP] Well-Known Member
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    Black Toolbox; Bed Mat; BFG ATs 265/75/16
    I plan on upgrading from the stock Dunlops in the near future. I want to go larger from 245/75/16 to 265/75/16. So I need some help on choosing the right tire. I drive 98.99999% on paved roads. But I would really like some A/Ts. Im thinking (not sure) that A/Ts dont last as long as reg. highway tires? The main reason for A/Ts is the look/stance and I would like to start going off-road eventually. :notsure:
  2. Aug 6, 2010 at 12:03 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Michelin LTX M/S
  3. Aug 6, 2010 at 12:06 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You are correct, usually an A/T tire will not last as long as a H/T tire due to the tread pattern. Some people also see fuel efficiency drop off slightly with the heavier, more aggressive tire.
    I'm running Cooper Discover ATR's and they get my vote.
  4. Aug 6, 2010 at 3:35 PM
    TacomaMan07
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    How much mpg would you lose? Thanks for your inmput
  5. Aug 7, 2010 at 5:04 AM
    Pugga
    Massachusetts
    That is the million dollar question and you'll get different answers depending on who you ask. I went from the 245/75-R16 Dunlops on the Baja wheels to 265/65-R17 Cooper ATR's on the TRD Sport wheels. I lost about 2 mpg (mpg loss is more apparent on the highway, around town I'm pretty close to where I was before). The overall diameter change was about 3/100 of an inch. Tires are noticably wider, but have a solid centerline so they're not loud on the road. My new tires also have a higher load range which plays into this also. The higher the load range means more plys on the tire which equals a heavier tire. If you go to a higher load range, your mileage will suffer a little also. Your Dunlops are a SL or standard load or roughly a B range tire. People go to a higher load range (C or higher) if they haul a lot of weight (so the tires don't squat as much) or off-roaders because of the thicker sidewall (puncture resistance is greater). They also ride a stiffer. For a point of reference, you'll typically you'll see D-range tires on 3/4 ton stock pick-ups.
    Sorry for the overload, hope this helps!
  6. Aug 7, 2010 at 8:55 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Cooper Discoverer ATRs and Toyo Open Country ATs were both great tires I had on my 2005.
  7. Aug 7, 2010 at 8:56 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Everyone is going to have their own favorite. Just do a lot of searching and come up with an informed decision that best fits your needs.
  8. Aug 7, 2010 at 9:20 AM
    TacomaMan07
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    Thanks for all the imput.
  9. Aug 7, 2010 at 9:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo.
  10. Aug 7, 2010 at 9:30 AM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Have you looked at the Nitto Dura Grappler?
  11. Aug 7, 2010 at 10:00 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Had these on my last truck and am in the process of dumping the tires that originally came on my rig ot get another set.
    Living in the Northwest the Geolanders were a great compromise for an all around tire. They handle great in the wet, very good in icy/snowy conditions, very well in light mud, excellent highway, and are quiet. They don't look half bad for an all terrain tire (similar to Bridgestone Dueler Revo tread pattern). They are quiet on the highway and most importantly for those of us on a budget can be had pretty reasonably. (Tire Rack)
    265/70R17 113S Load Index 113 = 2561lbs (1164kg) per tire
    Speed Rating “S” = 112mph (180kph) $114.00 (ea.)
    Good luck in what ever tire you chose. Everyone has a personal preference so do your research and chose the best tire for your needs.
    Just my thoughts. Ken ;)
