Best TRUE 3in Susp. Lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by aellerbe2354, Jun 18, 2012.
  1. Jun 18, 2012 at 7:20 PM
    aellerbe2354
    aellerbe2354 [OP] Member
    96 tacoma
    After about a week of searching and research, im ready to pull the trigger on a lift. I dont want to spent alot of money on a lift so im guessing a spacer lift is the best way. I want to get the most lift for the money. This truck is a daily driver and is not going to see much off road. The kit im leaning towards is the toytec 3in spacer with aal. Is this going to give me a full 3ins? truck is a 2000 4wd trd.
  2. Jun 18, 2012 at 7:25 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    "Spacer lift" and "best way" don't belong in the same sentence. I'd wait a bit and save a few more bucks and get some 5100s if I were you.
  3. Jun 18, 2012 at 7:35 PM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    ^^this.
    a spacer lift is not really a "suspension" lift anyways, as you are not increasing the length or travel, just keeping the OEM shock fully extended and .5" below the coil bucket
    even on the street this is a bad idea as the shock itself will become your bump stop. speed bumps and pot holes = broken shocks
    AAL in the rear won't be too bad, as long as you don't haul heavy loads or use it off road. The AAL will just flatten out over time with aggressive use, but of course there are guys here that run stock rear setups on front LT kits....
    IMHO, saving your money and buying a lift that won't break your truck is best, even for a mall crawling pavement queen
  4. Jun 19, 2012 at 12:34 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    the best basic setup to go will run about 500 or less. you can save up for that.
  5. Jun 19, 2012 at 12:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm calling BS... there's no way you researched for a week and came to the conclusion that a spacer lift is the best bang for your buck. :cool:
  6. Jun 19, 2012 at 3:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Spacers are complete shit man.
    5100s/eibach coils are the best 3'' lift
  7. Jun 19, 2012 at 3:45 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    or OME!
  8. Jun 19, 2012 at 3:47 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    this sorry man...hell if you type the word spacer on this site ur half way banned...jk
  9. Jun 19, 2012 at 5:36 PM
    aellerbe2354
    96 tacoma
    yeah i guess i do need to save up a bit more. Im just ready to get one ASAP! since most everybody seems think 5100s are the best way, is this going to give me the full 3ins? Wheres the best place to shop so i can get an idea of what the price range is going to be.
    --Sorry for the stupid ?s...im a tacoma noob lol
  10. Jun 19, 2012 at 5:44 PM
    Pugga
    Massachusetts
    Downsouth Motorsports for the 5100's, Toytec Lifts for the Eibachs.
  11. Jun 19, 2012 at 5:50 PM
    Revtek
    Revtek Member
    Oregon
    Revtek Tacoma TRD
    3" Revtek Lift, Revtek Behind the Grille Mount, Revtek Light Bar Mount, Mamba Wheels, Trail Grappler Tires, Bed Slide, Trex Grille, Piaa Lighting
    Check out Revtek's 426A. Your ride and performance will be practically equal to the coil over conversions. I have had this setup on mine since 2005 and everyone with the coil over's that compared it to mine cannot tell the difference...
  12. Jun 19, 2012 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Old Man Emu is the best 3" lift.
    5100's, with Eibach, or OME springs would be the best budget lift.
    Not including any coilovers such as Fox, King, Icon
  13. Jun 19, 2012 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your refering to the spacer kit from revtek, there isnt much out there that rides worse. And lift blocks increase axel wrap, which will wear out the leaf springs faster.
  14. Jun 19, 2012 at 7:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well..technically OME doesn't lift 3''..not with out the 10mm spacer anyways.
    Eibachs are like 3.5'' or so.
    Granted the OME stuff with also ride better.
    And CO FTMFW!
  15. Jun 20, 2012 at 5:15 AM
    Pugga
    Massachusetts
    Beat the hell out of a spacer lift on a Tacoma and you run the risk of breaking your shocks. You can't break the spacers themselves, they're just a chunk of metal. They do nothing to help improve the ride and carry risks of breaking other suspension components. I said they're not the best bang for your buck because they do nothing to improve the vehicle. I'd rather go with 5100's and an AAL than spacers and blocks. I understand that the OP's truck is a daily driver and won't be off road but I still think there are better ways to spend money on a lift. FWIW, the OP's use is similar to mine, mostly pavement and rarely off road and I went with 5100's, Eibach coils and the Icon 3-leaf AAL and am very happy with the results (2nd Gen though). OME would also be a great option.
    There's a lot more to a lift than travel. Any standard travel coilover will not increase suspension travel, that's what extended travel coilovers are for. To gain lift, you lose downtravel and gain uptravel. The difference is how the shocks are valved, some can be custom valved, how they are able to soak up bigger hits or have a remote oil reservoir to keep the shock from getting too hot and losing performance. Much more to a lift kit than shock travel.
  16. Jun 20, 2012 at 7:55 AM
    defleppardsg
    defleppardsg Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    Spacers are fine man- they're not dangerous and they're not going to ruin your truck... a million people run them on Tacomas and other trucks without any problems. I had one on my taco for a year, and ive used them on a jeep before. Like most of the guys on here, I'm a suspension fanatic, and I upgraded pretty quickly to OME springs and 5100's, but I didn't NEED to.
    The problem with a 3" spacer though, is that you're going to max out your stock shock, which IS a problem. The reality is, though, is that if you're getting new shocks, you might as well just get the 5100's, and set them at 3". That way you wouldnt have to buy a spacer OR a spring, and you'd still get a propper 3" lift.
    I always hear about the 5100's being on backorder for life, but when i ordered mine from Wheelers, they had em.... that was last fall though.
  17. Jun 20, 2012 at 2:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many trucks Ive install the OME 885's on, got right at 3" lift.
  18. Jun 20, 2012 at 3:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    2nd gen stats don't mean much in this forum or to the OP and his 1st gen.
  19. Jun 20, 2012 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Didnt see the OP had a first gen./
  20. Jun 20, 2012 at 3:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
