Best UCA’s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TanzTacoma, Mar 1, 2020.
  1. Mar 1, 2020 at 12:34 PM
    TanzTacoma
    TanzTacoma [OP] Well-Known Member
    Tanner
    Boise, Idaho
    2009 TRD Sport Tacoma
    I’m going to be putting my 3inch lift on my Tacoma in the next 2-3 weeks and am going to put new UCA’s on. What are the best brands out there that provide great performance without costing “too” much?
  2. Mar 1, 2020 at 12:40 PM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Don’t fall into the hype of buying the best. Buy a tig welder, a cnc machine and design your own.
    cdub0451 and DaveInDenver like this.
  3. Mar 1, 2020 at 12:41 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    2020 Tundra
    JBA. They’re about $450 and a lot of people on here run them.
    Dye22 and TanzTacoma[OP] like this.
  4. Mar 1, 2020 at 12:42 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    When you ask which is best it'll probably be the ones the person answering has. So Camburg!
    TanzTacoma[OP] likes this.
  5. Mar 1, 2020 at 12:49 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Are new lower control arms ever necessary for lifts or no?
  6. Mar 1, 2020 at 12:50 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    2020 Tundra
    Nope
  7. Mar 1, 2020 at 12:55 PM
    shutupmeg4x4
    shutupmeg4x4 Well-Known Member
    norcal
    18 DCSB V6 4x4 MGM
    tinted windows, scs ray 10's, wrangler duratracs 265/75/r16, eibach pro truck lift, bhlm, rigid fog, RCI sliders, c4 hybrid front
    I like my dirt kings, company has great customer service ... First you have to decide if you want ball joint or uniball though
  8. Mar 1, 2020 at 12:56 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Which is best out of the two? Ball joint or uniball? From what I’ve read it would be uniball..?
    & sorry for the dumb questions, suspension is not my strong suit lol!!
    shutupmeg4x4 likes this.
  9. Mar 1, 2020 at 1:01 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    None provide "great" performance, they'll just make alignment easier for your alignment people.
    There no such "best" brands, they are all made similar.
    What is "too much" for you?
    Your answer is withing your question.
    This is a classic tacomaworld.com rhetorical question.
    Ncska21, YumaTRD and jeff b like this.
  10. Mar 1, 2020 at 1:01 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    From a pure performance standpoint uniballs are going to be better in that there's no binding possible within the window of our IFS. But for mid travel use just to help correct alignment and add clearance for 3" coils ball joints can still be used with the benefit of less maintenance. Uniballs can get squeaky and if you live in place with winters the road salt can cause them to wear and pit faster. I went with Camburg OEM ball joint type. JBA uses GM 1 ton ball joints so those are kind of an upgrade, SPC has their own proprietary ball joints and Icon Delta joints are specialty ball joints.
  11. Mar 1, 2020 at 1:02 PM
    ShowstoppersUSA
    ShowstoppersUSA ShowStoppers Offroad
    Glendale, Ca
    The "best" would honestly be relative to a couple factors to the intended use, along with your budget. We offer Icon and SPC uca's.
    As an example, if someone wishes to correct their alignment and wants a balljoint for their environment, we would recommend the SPC 25470 uca.
    If an individual wishes to truly a higher end uca, such as a billet offering with adjustable heims to truly dial in their alignment, we also carry Icon 58550DJ
    We also do strongly recommend Icon's tubular UCA, 58450DJ.
    Both Icon offerings offer their delta joint, combining the durability of a ball joint with the performance characteristics of a uniball that is offered in other ucas.
  12. Mar 1, 2020 at 1:03 PM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    It depends your application... Uniballs are great for high performance but with that performance comes added cost and maintenance... Check out filthy motor sports on youtube his video breaks it down so that even i could understand it lol
  13. Mar 1, 2020 at 1:03 PM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
  14. Mar 1, 2020 at 1:04 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Sorry for being so dumb lol. Wasn’t trying to exceed 7-800 really. And didn’t know how to word the post that’s why I said performance. I knew they helped out with alignment issues
  15. Mar 1, 2020 at 1:10 PM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    7-800 for ucas? Or entire lift?
  16. Mar 1, 2020 at 1:10 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    UCA’s
  17. Mar 1, 2020 at 1:14 PM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    What suspension are you going with?
  18. Mar 1, 2020 at 1:17 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Personally I ran "built right" UCAs for years without a single issue and paid back then close to $300 less than the trendy TC, Icon and Camburg. Nowadays "baja kits" and "dirt king" exist. Once again, it depends on how much you want to spend. If you want "off road performance" go with lowers and uppers from the same manufacturer.
  19. Mar 1, 2020 at 1:18 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    I’m just going with a simple Bilstein lift. Nothing impressive whatsoever but gives it that lifted look. 5100’s in the front and rear. My buddy has it and I liked it! I wanted to go with Icon or King but not wanting to spend all that as of now. Maybe in a couple years once it’s payed off I’ll go big
  20. Mar 1, 2020 at 1:20 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    I don’t do HEAVY off roading so not necessarily looking for “total off road performance” just some minor dirt trails and dirt roads that take me out to where I hunt or fish
