Best UCA’s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TanzTacoma, Mar 1, 2020.
  1. Mar 1, 2020 at 1:21 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Go with the cheapest option, save $ for some other mods. IMO
  2. Mar 1, 2020 at 1:22 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If you're staying within the factory travel window (e.g. not going with extended travel coil overs) and not using larger than stock diameter shocks and coils then aftermarket UCAs and uniball pivots are not critical. The only benefit you might get is making it easier to align. Old Man Emu (OME), which is similar to the 5100s you're considering, is designed to work with stock UCAs.
  3. Mar 1, 2020 at 1:24 PM
    TanzTacoma
    TanzTacoma [OP] Well-Known Member
    Tanner
    Boise, Idaho
    2009 TRD Sport Tacoma
    Yeah I’m just looking to keep it mid travel and I don’t do hard off roading whatsoever. Idaho doesn’t have any cool places to do that LMAO! But maybe in the future I’d like to upgrade and get a nice ass suspension kit and maybe long travel it then. But for now I’m perfectly content with what I do off roading wise. Just been reading that UCA’s are a MUST when you exceed 3” of lift.
  4. Mar 1, 2020 at 1:26 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Bilstein 5100s are not mid travel, they are stock travel. Mid travel means you're using a "racing" shock (FOX, King, Icon, Radflo, etc) that has about an inch more travel than stock and will therefore exceed the travel limit of a stock UCA. Watch that Filthy Motorsport video, he talks about this.
  5. Mar 1, 2020 at 1:28 PM
    shutupmeg4x4
    shutupmeg4x4 Well-Known Member
    norcal
    18 DCSB V6 4x4 MGM
    tinted windows, scs ray 10's, wrangler duratracs 265/75/r16, eibach pro truck lift, bhlm, rigid fog, RCI sliders, c4 hybrid front
    Dope! 5100 are a solid choice ... I went with eibach for the same reason, i went with dk's moog style uca's because they are completely rebuildable so I'll have them the life of the truck and they allow for added down travel so if i upgrade my shocks I'll be all good
  6. Mar 1, 2020 at 1:28 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Oh... see what I mean I’m noooo expert on suspension, my bad dude!! Therefore I’m keeping it stock travel! Oops
    bluedevils9 likes this.
  7. Mar 1, 2020 at 1:29 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You also mention long travel, that's a completely different thing. If you plan to maybe go that way then definitely don't spend money on UCAs now. Long travel upper and lower arms are actually longer so you couldn't re-use a mid travel UCA anyway. Stick with the stock UCAs and maybe think about them if you find it can't be aligned (like the steering is really twitchy or you're wearing tires). That's about the only issue you might have with a 5100 lift.
  8. Mar 1, 2020 at 1:30 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    :rofl:
    TanzTacoma[OP] likes this.
  9. Mar 1, 2020 at 1:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    To tack onto this, the ball joints in a jba can be found at damn near any auto parts store for $30 and is stupid easy to swap out if needed. So that’s a plus.
  10. Mar 1, 2020 at 1:33 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    I’ll just see what the shop says about how much room I have to play with. It’s a 3inch lift, and I preferably want to run 285/75/17s so we’ll see if they say if I need UCA’s for alignment purposes or not I guess
  11. Mar 1, 2020 at 1:35 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    :facepalm:
    :cheers:
  12. Mar 1, 2020 at 1:35 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    That went through my mind when I was considering how to go. I wanted a stock ball joint instead of a specialty SPC or Icon. Not that buying a spare set to stick on a shelf is a problem, but the principle. But at the time JBA was still dialing in their geometry so I decided on Camburg. If I was buying now I'd probably go JBA.
  13. Mar 1, 2020 at 1:41 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    If he wants 285/75/17's he will most likely need a regear also now we are really talking money. But, to each their own
  14. Mar 1, 2020 at 1:49 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    2.7 yes but I have no idea what he has. I really like the tire size but not the total price tag for something, for me, that would be strctly a vanity item. I need to find me a set of the 2.7 diffs I could swap in with an lsd in the rear
  15. Mar 1, 2020 at 1:55 PM
    #35
    TanzTacoma
    Tanner
    Boise, Idaho
    Was just reading where a 6lug v6 is 3.73 is that correct? That’s what mine would be if correct
    Casper66 likes this.
  16. Mar 1, 2020 at 1:57 PM
    #36
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    @TanzTacoma I pretty much have the lift you noted in your other thread. 5100's with Eibach coils, I have the 2.5" lift 600lb coils instead of the 620# 1.6" lift coils. It will be dequate for most anything you most likely want to do I have been pleased so far and it is teamed up with camburg ball joint uca's. I don't care for the idea of moving the 5100's to the second notch as when i did that on my 4cyl truck, which had the coils listed in your link it rode rough.
    Yes that is correct
  17. Mar 1, 2020 at 2:12 PM
    #37
    TanzTacoma
    Tanner
    Boise, Idaho
    Okay cool, good to know! I’m just reading what everyone’s opinions are when it comes to UCA’s because i want to replace mine either when I lift it or a month or 2 after! Depending on how fast I can save. If mine is a 3.73 will the 285’s still run at a high RPM? I’m not too knowledgeable on this stuff that’s why I’m on here lol
    Casper66[QUOTED] likes this.
  18. Mar 1, 2020 at 2:25 PM
    #38
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    A 285/75/17 s a 34x10.5 basically. It will raise your gear ratio because of the extra diameter lowering your rpms and robbing more power. The extra weight will also play into it but all this can be said of any tire over a stock size the effects simply compound the larger you go. I may be wrong but with a bilstin lift as you linked I don't see any real bennifit from anything more than a ball joint uca. Your greatest bennifit will be in a better aignment opportunity and clearance. The linked, delta jointed, or whatever you want to call them will help you if you went to a mid travel setup. You have recieved some good info in here from some good folks that know what they are telling you. All these uca's mentioned are of comparible quality with their own little independant differences. As @EatSleepTacos told you about the JBA's less cost and ease of pars availabillity and maintenance. Camburg ball joint ucas are the same way. @jeff b can led you in the right direction as well as many of the others. Tis is a confusing and daunting task to try and learn which we have all, mostly gone through. These guys are helping you through their experience.
  19. Mar 1, 2020 at 2:28 PM
    #39
    TanzTacoma
    Tanner
    Boise, Idaho
    Thank you it’s been much appreciated! You guys helped more than I ever could’ve thought!
  20. Mar 1, 2020 at 2:55 PM
    #40
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    For 3" lift, check out the suspension option @shouldveboughtajeep is running here with pictures here (Tuff Country UCA's for $300). He also goes into here, and at some point does a :notsure:
