Best way to clean gauge cluster plastic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fjm0008, Feb 1, 2011.
  1. Feb 1, 2011 at 11:23 AM
    fjm0008
    fjm0008 [OP] Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    There are so many different answers on Google I can't figure out what to use. Has anyone cleaned theirs and had good success without scratching? Mine is dirty and not just dust and needs to be cleaned. Thanks.
  2. Feb 1, 2011 at 11:51 AM
    "OLYMPIC VIEW"
    "OLYMPIC VIEW" Well-Known Member
    WHIDBEY ISLAND, WA
    2011 TRD SPORT D/C LB...1987 SR-5 4WD XCAB
    I use a "micro-fiber" towel that I moisten with warm-water and dot of Dawn liquid soap...gently clean plastic and avoid circular motion...immediately dry off with dry micro-fiber towel...I've had good luck with this...don't use Windex and don't use a terry cloth towel/washcloth...mild non-abrasive detergent is key!!
  3. Feb 1, 2011 at 12:10 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Like he said .... micro-fiber....... you may not need any cleaner ........ I've done without and it works.
  4. Feb 1, 2011 at 12:22 PM
    c.morris89
    c.morris89 Well-Known Member
    Kingsport TN
    2021 PRO MGM 6MT
    A little
    Like others have posted, use microfiber cloth. Be careful cause the plastic is really easy to scratch.
  5. Feb 1, 2011 at 1:30 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    If you do get scratches in there, there are plastic cleaner/polishes out there that work well and don't scratch. Motorcycle shops have good stuff for bike windshields. I use Plexus spray, but McGuiar's makes plastic cleaner, as do others.
  6. Feb 1, 2011 at 1:38 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Sand paper and laundry detergent!
  7. Feb 1, 2011 at 1:41 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Be careful not to make eye contact either. The plastic scratches if you look at it wrong.
  8. Feb 1, 2011 at 1:42 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    x4
    I've seen this happen
  9. Feb 1, 2011 at 1:43 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    wire brush
  10. Feb 1, 2011 at 1:44 PM
    macgyver
    Brad
    Canton, GA
    Correction...A drill mounted wire wheel
  11. Feb 1, 2011 at 1:44 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Wire wheel its faster
    Edit: I think macgyver is watching me ↑
  12. Feb 1, 2011 at 1:44 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    I use McGuire's Plast-X with a micro fiber towel. Works great. I also use it to polish headlights and tail lights. makes them look great.
  13. Feb 1, 2011 at 1:47 PM
    macgyver
    Brad
    Canton, GA
    I am, I built a camera out of a campbell's soup can, some toothpaste, and electrical tape that I placed above your computer :spy:
  14. Feb 1, 2011 at 1:52 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Found it now I'm gonna use to clean my gauge cluster :D
  15. Feb 1, 2011 at 1:54 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    if you frequent detailing forums you'll learn that cheap microfibers can actually induce scratches, even though they feel soft.
    a high quality microfiber and a high quality protectant cleaner or instant detailer should be all you need. it will help keep any dirt or particles left over during cleaning from scratching during wiping.
    high quality MF - premium protectant cleaner - or
    ambiguousfrog likes this.
  16. Feb 1, 2011 at 2:03 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    X2
  17. Feb 1, 2011 at 2:12 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Worked great when I was tinting my tails. Gonna start using it on heads and tails once the weather warms up.;)
  18. Feb 2, 2011 at 7:12 AM
    fjm0008
    Jack
    Annapolis
    06 4x4 LB White
    Sandpaper, wire brush, laundry detergent and don't look at it directly. Thanks for the humor. I already use all of these to wash the outside so I don't need to buy anything additional. (put it in cheap mods?) I think I will try the micofiber, warm water and non abrasive soap and if it does not work I will break out the Makita cordless drill with the grinding wheel. If I can't produce enough heat I have the dremel for a backup.
  19. Feb 2, 2011 at 7:21 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    and a little paint remover:D
  20. Feb 2, 2011 at 8:04 AM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    Extang Trifecta, LED Console lighting, VentShades
    I just use my sunglass cleaning cloth. I keep it in the sunglass compartment. The key is to wipe it down often so the dust doesn't build up too much.
