Best way to get a lift
Discussion in 'Suspension' started by blacktaco08, Jul 2, 2012.
  1. Jul 2, 2012 at 11:07 PM
    blacktaco08
    blacktaco08 [OP] Member
    Brian
    WA
    I've been thinking about getting a 3 inch lift for my 2008 Tacoma DC LB. I spent countless hours on researching the best lift. I am just going for more aggressive look and I don't want to sacrifice the ride. After all this research, this is what I came up with. Bilstein 5100s in the front and AAL in the rear. I am also thinking about getting a eibach springs. Please let me know if this will work. Thanks guys!
  2. Jul 3, 2012 at 7:53 PM
    blacktaco08
    Brian
    WA
    Under 500. I don't do any off roading
  3. Jul 3, 2012 at 9:52 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    I dont think you can get 3" with 500 and not sacrifice the ride sir, pick two.
  4. Jul 3, 2012 at 9:58 PM
    blacktaco08
    Brian
    WA
    @ truknight, I'm talking about 5100s and AALs. Can u put an aftermarket coils with the 5100s in the front?
  5. Jul 3, 2012 at 10:04 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    yes you can, and should. Eibach coils or ome coils, and a small top plate spacer (1/4'' ish)to get 3'' and then get a 1.5'' AAL to sit level, or 2" AAL if you want some rake.
  6. Jul 3, 2012 at 10:20 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    You can get a lift with that setup yes, but at 3" I dont think youll be happy with the ride quality based on what ive read about it.
    Just avoid things like spacers, blocks and body lifts like the plague.
    Are you a pre runner or a 4x4 btw? it matters.
  7. Jul 4, 2012 at 7:15 AM
    blacktaco08
    Brian
    WA
  8. Jul 4, 2012 at 7:32 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Just aim for 2.5 in instead of 3, then you can avoid a diff drop, a sway bar relocate and probably a new set of UCArms, and possibly new brake lines. There seem to be nothing but draw backs for getting that extra .5 in that not many people will notice.
    For 2.5 you just need 5100s, an AAL, and maybe new coils, that should keep you under $500 if you do the work yourself.
