Best way to replace a FUEL PUMP
Discussion in 'Toyota Trucks & SUVs' started by TACO4YOU, Oct 2, 2013.
  1. Oct 2, 2013 at 5:31 PM
    TACO4YOU
    TACO4YOU [OP] New Member
    James
    Newport News
    08 PreRunner
    any suggestion on what's the best way to remove and replace the fuel pump on a 08 TACO? Trying to this on my own since I'll cost me an arm and a leg if I take it to a shop.
    Thanks in advance
  2. Oct 2, 2013 at 5:40 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Drop fuel tank.
    Remove old pump.
    Replace with new pump.
    Are you sure you need a new pump?
  3. Oct 2, 2013 at 5:40 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    What I have done on other trucks is to simply undo the bolts that hold the bed down, disconnect the light harness in back, undo the fuel neck and just lift the bed up and slide back to get to the top of the fuel tank to replace the pump.
    You can also drain the tank and drop it to replace the pump but I have found the above way works a lil better.
  4. Oct 2, 2013 at 6:05 PM
    TACO4YOU
    James
    Newport News
    08 PreRunner
    thanks a lot for the suggestions. i'll give the bed a shot this weekend.
