Better gas mileage with ETC Power button on. Anyone else?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wabio, Aug 27, 2016.
  1. Apr 30, 2017 at 7:12 PM
    1stGenDriver
    1stGenDriver Now 3rdGenDriver
    Nick
    New Hampshire
    '17 SR5 DCSB 4x4
    Late to the party on this one but I too have noticed the same thing. My theory is that with ECT PWR off, the engine shifts too soon and sort of bogs, prompting the driver to press the gas pedal further, which tells the engine to inject more gas into it. Whereas I noticed when ECT PWR is on, it stays in the lower gears longer so I barely need to press the pedal at all to maintain speed or even speed up. I will be driving with ECT PWR on full time now!
    Vmax540, VanGo3 and vprgts like this.
  2. Apr 30, 2017 at 7:16 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    This same conversation used to happen with 1st gens.
    +1
  3. Jan 12, 2019 at 10:03 AM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    For the sake of not starting a new thread, I tested this yesterday.
    (Edit for model: 2019 DCSB OR 4x4)
    Had a quick turnaround to AZ and back from LA. 250 miles each way. ECT off, I got 19MPG on the way there. Filled up in Parker AZ. ECT on I got 22MPG on the way back.
    Didn’t use the onboard monitoring for the numbers, did it the old fashion way with math.
    I couldn’t seem to find a definitive answer on the topic of using ECT full time, will this cause long term issues, or should I just hardwire the MFer on?
  4. Jan 12, 2019 at 12:20 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    I get a good 4mpg loss across the board with the ECT on. Which makes sense, since you are always running a gear lower and at higher rpm constantly over the non ECT map. Also the throttle response is touchy, using more fuel. 18/22 with ECT off and 14/15-18 with it on. Think of it as eco vs normal mode, with normal being the ECT on
  5. Oct 24, 2020 at 3:19 PM
    stevelockhart
    stevelockhart Member
    2020 barcelona red tacoma
    I tried this today. Took a trip only differences was on way back i had our 9yr old son. On the way non ect it used 12.3l/100km and on way back i had ect on and the gauge said 9.5l/100 so approx 4mpg more with more uphill on return. According to Toyota using ect will decrease. Opposite of what happened. I'm kind of considering putting in ect always on mod
    mud likes this.
  6. Oct 24, 2020 at 3:46 PM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    I definitely get better fuel economy with the ECT on, I also found running 91 helps and also idles way smother than with 87. My commute is 32 miles each way and I drive over an 1,808 foot mountain road everyday. ECT doesn’t let the engine bog as much and it’s literally the difference between my tank getting 20-22 if I somewhat baby it, to 18-19 with 87 and no ECT. I’ve tried it both ways and ECT and 91 I almost consistently get 2-4 mpg better per tank.
    PilotguyPA28 likes this.
  7. Oct 24, 2020 at 4:12 PM
    Nframe
    Nframe Active Member
    chris
    2019 SR5 Calv Blue
    I have noticed that with ECT on I get a touch better mpg as well, and I don't have to listen to the engine bog then wait to the transmission to down shift and send the RPM's way up just to get me moving on some of the hilly turns.
    My usual is 23 MPG (V6 2WD DCLB 245/75-16's) Im sure the tire size makes a big difference.
    Vmax540 likes this.
  8. Oct 24, 2020 at 5:19 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Haven't tried the ECT mode other than towing...got almost 19 mpg pulling my boat using S5 and ECT. Normally i get the best fuel mileage in the D mode using 87 fuel while keeping it around 50-60 mph with low rpms on our back roads here.
  9. Oct 24, 2020 at 6:40 PM
    VanGo3
    VanGo3 Modern vehicles are ugly.
    Northern California
    20 SX AC 4x4
    Mostly dust and dirt.
    Does the ECT only change the gearing or does it also change the fueling?
  10. Oct 25, 2020 at 5:31 AM
    Nframe
    chris
    2019 SR5 Calv Blue
    I'm pretty sure ECT only changes how the computer allows the transmission to shift and how that corresponds to the fuel management system.
  11. Oct 25, 2020 at 5:44 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Can't say I've had the same experience. Maybe I'll try it for my next round trip commute and update for sure. But I'm also not getting as bad of MPG as OP was getting. In the summer with my tire pressures higher (thanks to the dealership) I would get about 22-23 MPG at 70 MPH without ECT. I can see how ECT would make a difference if you're having to labor the engine though such as carrying a load, mountains/hills, or all that combined with higher speeds.
  12. Oct 25, 2020 at 5:45 AM
    zoo truck
    None
    As far as i know ECT just delays the transmission shifting points. Never knew it works with and conjunction with the fuel system. I've had ect in my 4 bangers way back when toyota started building these compact 4wd trucks.
    VanGo3[QUOTED] likes this.
  13. Oct 25, 2020 at 7:06 AM
    COOXDREAM
    COOXDREAM Well-Known Member
    David
    2016 Tacoma
    I just bought the truck not exactly sure of the mods.
    This has been an interesting thread so, I pulled out the manual. I don’t know you all are located but maybe the photo may give a bit insight. Now, I just got my Tacoma a week ago so I’m a newbie.
    No_Smoking likes this.
  14. Oct 25, 2020 at 7:17 PM
    VanGo3
    Northern California
    20 SX AC 4x4
    Yes.
    But that doesn’t answer most of the questions on this thread.
  15. Oct 25, 2020 at 7:24 PM
    #35
    zooyorkajd
    zooyorkajd Well-Known Member
  16. Oct 26, 2020 at 2:52 AM
    #36
    WDproTrd
    WDproTrd Active Member
    19 TRD PRO BLK
    what....no pics of etc button on....:smack:
  17. Oct 26, 2020 at 2:57 AM
    #37
    RedWings44
    Michigan
    I think it plays with the fuel mapping too. I'm pretty gentle on the pedal when leaving intersections (most of the time). This morning I tried ECT because of this thread. It definitely gets going a little quicker.
    As an update to my experiment, I got about 1 MPG worse today with ECT than I did yesterday without it. 45 mile commute and I use cruise control. I suspect that the speeds I was going though would be more than fine without ECT. If I was pushing 80, I'd probably see a difference in a positive way.
  18. Oct 26, 2020 at 6:14 AM
    #38
    zoo truck
    None
    I think the only reason it gets there quicker is your pulling higher rpm longer throughout the gears...which creates more power, (engine gets more into its power band), instead of the normal short shifting you get in the drive mode while having lower rpm.
  19. Oct 26, 2020 at 6:27 AM
    #39
    RedWings44
    Michigan
    I think normally, yes, but this was noticed from a dead stop. It seemed to "jerk" forward from the stop a lot more than without it. That's the only thing that leads me to believe fuel mapping is affected too, even if just barely.
    Newwt likes this.
  20. Oct 26, 2020 at 7:04 AM
    #40
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    I didn't like driving around with ECT on since it made the truck lurch/jerk when cruising around with no additional weight. But I once I started driving around in S5 I noticed my MPG go from an avg of 18ish to 20ish
