Better way to fix bent gasket/ring on CV axle?
Discussion in 'Technical Chat' started by Spvrtan, Jul 25, 2016.
  1. Jul 25, 2016 at 2:27 AM
    Spvrtan
    Spvrtan [OP] "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    I was looking to score a cheap used CV axle from a totaled truck as a trail spare instead of buying a brand new OEM one for over $300. I managed to secure this one for $80. The boots, threads, and axle itself look fine. However, the gasket (correct term?) is bent. Can I just hammer/pry that back into place or should I send the axle in to get repaired somewhere? Attached are pictures.
    cgraner likes this.
  2. Jul 26, 2016 at 6:28 PM
    BamaToy1997
    Bill
    Navarre, FL
    That axle shield and seal are pretty messed up! Looks like someone was unhappy with it! lol. That is the end that goes into the spindle, so you need to be sure that everything seals correctly so that the wheel bearings do not get contaminated. This can be fixed, but will take some time. Using a pair of small needle nosed pliers you can carefully work the metal dust shield back into shape more resembling the rest of the dust shield. When you do that the rubber part of the seal should conform back to it's original position.
    cgraner likes this.
  3. Jul 26, 2016 at 6:34 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    or you can use a flat head screw driver and pound it out and replace just that cover.
  4. Nov 13, 2024 at 10:31 AM
    cgraner
    cgraner Member
    Did you get this bent metal shield resolved? I have a similar problem as you where I got a pair of CV axles from LKQ and the wrench monkeys that took them off beat them up and they didn't put them in a box with padding to protect them so between removal and shipping the shields bot beat up. Mine look like they could be salvaged if I can get the metal shields back in shape. How important is it to get the shield close to where it was? It looks like the most important part is the rubber seal part not being interfered with. Do you have any pictures showing how you straightened them back out, etc.?
  5. Nov 13, 2024 at 10:38 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If they're that bent, you should get replacements, Toyota P/N 90304A0001 (no aftermarket equivalent as far as I could find).
    cgraner[QUOTED] likes this.
  6. Nov 13, 2024 at 11:51 AM
    cgraner
    cgraner Member
  7. Nov 13, 2024 at 11:57 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  8. Nov 13, 2024 at 12:27 PM
    cgraner
    cgraner Member
    I noticed on this listing for CV axles https://www.amazon.com/Cruiser-2005-2017-Tacoma-2003-2017-Runner/dp/B07N9KBJMX/ that it shows that it includes inner and outer seals.
    It calls out in the description Outer Joint Hub Seals. Replaces National Seal Number 710477, 710573
    National Oil Seals 710477 Wheel Seal (Pack of 2)
    https://www.amazon.com/National-710477-Oil-Seal/dp/B0CDQK54MJ/
    National 710573 Wheel Seal
    https://www.amazon.com/National-710573-Oil-Seal/dp/B001UCMUEQ/
    The part I don't see is this large O-Ring. Does anyone know the part number for that and where it goes? It kind of looks like it might go on the 710573 Wheel Seal in the above.
  9. Nov 13, 2024 at 1:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^710477 goes between the hub and bearing. 710573 goes on the back of the spindle.
    The O-ring goes between the bearing and the spindle. It doesn't have an aftermarket equivalent P/N. (Like the CV joint seal, it's obviously offered in the aftermarket as part of kits, but no one lists it individually.)
  10. Nov 13, 2024 at 1:20 PM
    cgraner
    cgraner Member
  11. Nov 13, 2024 at 6:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Depends on the job. If you're only replacing the CV axle, the wheel bearing doesn't have to be separated from the spindle, therefore the O-ring is not disturbed. If you're replacing the wheel bearing due to wearout, the O-ring should be replaced. Toyota's O-ring P/N is 9030192003. Some aftermarket hub-bearing assemblies, for example Moog 515201, comes with a replacement O-ring.
  12. Nov 14, 2024 at 8:14 AM
    cgraner
    cgraner Member
    Are these parts equivalent parts or is the 710477 used somewhere else and if so where? It is included in that CV axle kit. It is a little confusing as to where they intend for the 710477 part to be installed.
    https://www.finditparts.com/products/409754/national-seals-710477
    Part Interchanges
    Fits Vehicles
    • Lexus GX460 (2011-2023)
    • Toyota Hilux (2004-2008, 2010-2013)
    • Toyota FJ Cruiser (2007-2014)
    • Toyota Tacoma (2005-2023)
    • Toyota 4Runner (2003-2023)
    • Lexus GX470 (2003-2009)
  13. Nov 14, 2024 at 11:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    710477 goes between the hub and bearing. Unless you're separating the hub from the bearing with a hydraulic press, that seal doesn't apply.
    BTW that O-ring is available from SKF under P/N 30192.
  14. Nov 14, 2024 at 12:43 PM
    cgraner
    cgraner Member
    Thanks!!!
    That is what I was starting to sort out from looking at the diagrams. Some sites diagrams are better than others.
  15. Nov 15, 2024 at 9:21 AM
    cgraner
    cgraner Member
  16. Nov 15, 2024 at 9:23 AM
    cgraner
    cgraner Member
    I am building a source list of all of the parts required to do a full CV axle rebuild. I think I have everything except for the CV Boots, grease, clamps kit. What are good cost effective but still quality sources. What options are there for small lifts like 2" to 2.5" and also for higher lift options on boots?
  17. Nov 15, 2024 at 9:51 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    No aftermarket P/N I'm aware of for 90304-A0001.
    The dust cover on the inboard side is a small sheetmetal shield. It doesn't contact anything in normal use and typically doesn't need to be replaced.
    For boots just use the Moog or Beck Arnly kits on Rock Auto. If you stretch the inner boot a little and cinch it down with a hose clamp, it will accommodate higher lift angles.
