Betterbuckleup's 2000 taco build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by betterbuckleup, Nov 27, 2018.
  1. Apr 6, 2021 at 10:54 PM
    #401
    betterbuckleup
    betterbuckleup [OP] Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Yea that's a good point. Bypasses would be tits.
    My plan was to run the typical setup that a lot of people do with just the added crossmember and inboard of the frame.
    and I would rebuild my own shocks, but I don't have a nitrogen setup and spring compressor for the front CO's.
  2. Apr 7, 2021 at 12:14 AM
    #402
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nitrogen setups only go for $200 or so and a quality spring compressor would be nice, but not necessary if you can get by with widow makers or find a shop to remove them while you work on them.
    https://classifieds.race-dezert.com/FOR-SALE:2.5x10-2-tube-bypass-175411
    You could find a nicer pair, just a case in point ^^^^
  3. Apr 7, 2021 at 10:37 AM
    #403
    betterbuckleup
    Ian
    Concord, CA
    Still more than i'm currently wanting to spend on gear for rebuilding. Other things are higher on the priority list for me currently. Maybe further down the line. I still have a free rebuild/tune from accutune to use from when I bought my from CO's.
    I've tried with the windowmakers and the ones you rent from auto parts stores don't fit or work really because of the 2.5 shock body. The clamps protrude too far into the coil and hit the shock body. I was able to make it work, but at the cost of kinda marring up the cans.
    I bookmarked both of those pages, so I'll definitely keep an eye out for some bypasses.
  4. Apr 7, 2021 at 12:09 PM
    #404
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah I just was going off of your link to Fox 2.5 smoothies from Accutune at $900 or so with tax as a ballpark.
    Making your own spring compressor would probably work if you got some beefy 3/4 all thread and 3/8 plate
  5. Apr 7, 2021 at 12:19 PM
    #405
    betterbuckleup
    Ian
    Concord, CA
    Out the door was like 1800 or so iirc for a pair, but yea if I can find a used set of decent bypasses I'll definitely spring for those.
    I was thinking about doing the same thing last night. Maybe once I've used up my free rebuild and need to do it again after I can give the DIY route
    I've got almost 22k on them now and not really sure when I should send them in. I'm thinking 35k or sooner if they start to weep? It's not my daily anymore, but I'm also not romping on them super hard in the whoops or anything. I think I remember reading that some guys get 50k out of them but with like 95% street.
  6. Apr 7, 2021 at 5:28 PM
    #406
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Very true. It's just a matter of how much motivation do I have after I all this work done to my truck. The answer for the time being is going to be very little. :^)
  7. Apr 8, 2021 at 12:02 PM
    #407
    betterbuckleup
    Ian
    Concord, CA
    Don't blame ya. I'm with you there.
    I'm trying to knock things out that I've been putting off all winter to get ready for this summer.
  8. Apr 8, 2021 at 12:31 PM
    #408
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I’m about ready to do a relocation and get some matching ADS. The 9” bilstein 5125s I have right now don’t dampen enough and I get this little rear bounce going.
  9. Apr 8, 2021 at 2:46 PM
    #409
    betterbuckleup
    Ian
    Concord, CA
    Yea I remember you saying that when you went to the billies.
    I think I'm gonna try and get some used bypasses for the rear. That would be bitchin and would be a good bit cheaper too
    Dan8906[QUOTED] likes this.
  10. Apr 8, 2021 at 3:01 PM
    #410
    Dan8906
    Daniel
    Concord, California
    Yeah, I think the ADS with resi and click compression is like $1200
  11. Apr 9, 2021 at 11:37 AM
    #411
    betterbuckleup
    Ian
    Concord, CA
    ADS smoothies or the ADS bypasses like that one guy runs?
  12. Apr 9, 2021 at 8:02 PM
    #412
    Dan8906
    Daniel
    Concord, California
    My initial thought is smooth body’s. But the click compression is a custom order. I haven’t looked into the bypass very hard tho.
  13. Apr 10, 2021 at 4:54 PM
    #413
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. Yea I'd be curious on the ADS bypasses and the cost for those in comparison.
    It really comes down to the extended and collapsed length of the shock. That's the problem I'm running into with finding any used 10" travel bypasses/smoothies. @Dalandser Those ADS bypasses are a custom "short body" to accommodate the much shorter extended length to fit under the bed. Hence why a lot of people get welded rod ends in order to shorten the extended length so that they can be more vertical under the bed
  14. Apr 10, 2021 at 5:10 PM
    #414
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check out this item on OfferUp. https://offerup.co/WD9s7T53lfb
  15. Apr 11, 2021 at 8:08 PM
    #415
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  16. Apr 11, 2021 at 11:27 PM
    #416
    betterbuckleup
    Ian
    Concord, CA
  17. Apr 12, 2021 at 7:06 PM
    #417
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That’s exactly the plan.
    I just drove a shit load of dirt through Mojave Preserve, North Rim of the Grand Canyon, up to Kanab and somehow ended up near Parowan. I need an upgrade bad.
    Also I’m in the Utah area until at at least the end of April if anyone wants to meet up.
  18. Apr 13, 2021 at 2:49 PM
    #418
    betterbuckleup
    Ian
    Concord, CA
    Good shit. Yea it'll be well worth it for what you use the rig for.
    Wish I could make a trip to Utah right around now. I need more Moab in my life.
    otis24[QUOTED] likes this.
  19. Apr 19, 2021 at 9:43 PM
    #419
    betterbuckleup
    Ian
    Concord, CA
    Finally got my passenger seat installed.
    Fought with the slider a bit since there aren't any instructions for it, but just needed a washer between the slider and seat to space it away enough so they didn't contact each other.
    Relocated the seat belt buckles from being mounted on the brackets to the seats themselves so that they move with the seat and are more low profile. That way I have more room between the seats to make a center console.
    Original mounting location:
    Modified buckle brackets. Original on top, modified on bottom
    Final mounting location:
    otis24 and cbechtold like this.
  20. Apr 19, 2021 at 9:49 PM
    #420
    betterbuckleup
    Ian
    Concord, CA
    Here are some pics of the details on the seats. Great craftsmanship. Always good to support a made in USA product too.
    Suspension part of the seat. Don't see this getting worn out anytime soon.
    Ordered the passenger without adjustable lumbar support, but with a back pocket.
