Beware changing LSD lube!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, May 17, 2010.
  1. May 17, 2010 at 10:05 AM
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    My 07 dc 4x4 sr5 just hit 100k so I decided to changed oil in diffs, transfer, tranny etc. Everything had been running perfect no problems.
    Switched rear end to Mobil 1 LS and sure enough, now I have a soft shudder sound when turning. So I bought some LSD additive, no better.
    Anyway I noticed when draining old oil from rear diff, the fluid appeared reddish, almost like ATF and looked pristine, compared with dirty, nastiness typical 90w look in front.
    So I call the stealership and sure enough they have Toyota GL5 LSD oil for a bargain price of $62 per quart. They say I need 2, manual says 3 quarts, and I drained about 2.75 quarts out.
    I'm considering trying some Royal Purple or Amsoil before coughing up the $180 to Toyota.
    Any thoughts or past experiences with this would be appreciated. The diff felt pretty warm to touch after 40 mile round trip as is. I hope I'm not frying the mechs in the meantime.
  2. May 17, 2010 at 10:11 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    IMO, synthetic gear oils are too slippery for lsd clutches. I would use a high quality 80w90 with a 4oz bottle of lsd additive. Change it every 30,000 miles like Toyota says and you shouldn't have any problems.
  3. May 17, 2010 at 10:11 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    I had the same problem when I changed my diff with mobil 1 with lsd additive. switched to royale purple with autozone additive and haven't had any problems
  4. May 17, 2010 at 10:12 AM
    oldsman71442
    oldsman71442 Well-Known Member
    Jeff
    oahu HI/ Redding CA
    10 DC 4x4 TRD Sport
    Your best alternative is Redline oil. call them direct and tell them what you have and see what they say will work in it. I don't believe in royal purple personally but it is all personal opinion. If you were going to go with a synthetic oil I would use redline in all my transmissions and gear boxes but Mobile one in the engine. Like I said personal opinon but I have found that Redline usually has a list of OEM specifications and what oil they make that is comparable. Don't laugh - the jetta i used to own (i sold it) said it needed dealer specific trans fluid but I called redline and they had one that was a replacement and no one else did.
  5. May 17, 2010 at 12:32 PM
    Airun
    Aaron
    Show Me State
    Hey guys, great input, I really appreciate the opinions and ideas.
  6. May 17, 2010 at 12:41 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    REALLY?? I have Royal Purple now and it studd-dd-eres. Royal Purple already has the lsd additive that's what it says on the bottle:rolleyes:
    So you have NO studder, shudder feeling in the lsd now or after the "extra" additive!!??
  7. May 17, 2010 at 12:46 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Even if you use synthetic I believe you still need the friction modifier. Your probably better off using Dino oil with the LSD additive and change it at recommended intervals.
  8. May 17, 2010 at 12:56 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    You will need to add some additive. The included amount is very small in comparison to what most manufactures require.
  9. May 17, 2010 at 12:58 PM
    MC1983
    MC1983 Well-Known Member
    Mark
    Indianapolis, IN
    2005 DCLB
    I had royal purple in mine and it was fine for a bit then it started to bind and make noise. I switched out to Castrol dino 80w90 and some FORD LSD additive and everything works great. I just don't think our truck likes the synthetic in general. I know some GM cars/trucks actually say don't use synthetic. Wonder if toyota uses the same company as GM for their LSD.
  10. May 17, 2010 at 1:00 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I plan on using Amsoil LSD formula when the time comes.
    Rambo54 likes this.
  11. May 17, 2010 at 1:00 PM
    wlmuncy
    William
    Knoxville, TN
    I am sure it's all Dana. On Jeep LSD, the synthetic is fine, but just add more additive.
  12. May 17, 2010 at 1:03 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    You can use synthetic in the GM auto locking diffs (in fact the trucks come with it from the factory) , but if you have limited slip like in the Trailblazer SS or the Corvette, GM uses Dexron LS fluid. It's basically dino oil with the proper amount of additive mixed in. At about $23.00 a quart, it's kind of pricey, but it works great.
  13. May 17, 2010 at 1:08 PM
    rob1
    Robert
    South Texas
    Thanks for the info guys!!:):cool:
  14. May 17, 2010 at 1:25 PM
    Madtown Taco
    Madtown Taco Well-Known Member
    Madison, Wisconsin
    05 TRD Sport SR5 DC LB 4x4
    Gun Metal FJ Cruiser TRD Wheels, Black Head Lights, I-pod Patch Cable for Stock Head Unit, In-Cab 115V outlets, Aries Bull Bar, 12V outlets in Bed, Snug Top Super Sport Topper, Hard-Wired Valentine 1 Radar Detector, Disabled Automatic Air Conditioning for Windshield Vent Setting, Additional D-Rings in Bed, 12-Volt Pop-N-Lock Solenoid in Tailgate Handle, TRD Front Seat Covers, WeatherTech Floor Mats
    Last week I got done reading a ton of posts on this site in regards to changing out the rear differential fluid. The absolute best way to go, from a number of people's recommendations, is to use straight up dino (dinosaur) or NON-synthethic in this case. Buy 3 quarts of dino oil, plus some Limited Slip Differential additive, and you'll be good to go. I know everyone wants the very best for their ride, but in this particular case Synthethic oil is not the way to go. It's fine to use it in the transfer case, the front differential, your engine, etc., but if you have an LSD on your truck, you'll most likely end up with chattering problems. I've heard of chattering issues with Mobil one, and shearing issues with Royal Purple. The only ones I haven't heard anything bad about on this site are Redline and AMS oil. There's a pretty big write up on this site about all this. Do a search on here and you should come across it. Toyota Nation also has a real nice write up on doing all three fluid changes....Front, transfer, and rear diff. In this rare instance, the write up on the Nation is better than what we currently have going on Tacoma World.
    I found the LSD additive at Autozone if you have one of those near you.
    Here's the link to the sticky on this site. It does a real nice job. You can read through it...be sure to read it all, and make up your own mind on what type/brand of oil you want to use. Within the posts I personally put a link to the write up that was done on Toyota Nation, which will walk you through doing all three fluid changes...front, transfer case, and rear differential. Good luck!
    http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
  15. May 17, 2010 at 4:26 PM
    Airun
    Aaron
    Show Me State
    ok, dropped mobil 1 and added some dino 80w-90 and a 4oz. tube of lsd additive. mucho bettero, the shudder is gone but still seems to be a mild hum with turning. this is after doing several tight and slow figure 8s. any ideas guys? I'll probably ride this set-up a few days and see how it does. what do yall think about adding more additive? anyway its better
  16. May 17, 2010 at 4:32 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    FWIW, When I changed my LSD diff. oil on my 07 prerunner about 3 months ago, I went and bought the LSD diff oil at Frank Toyota here in SD. I figured that if that's what they use, I shouldn't have any problems... and I haven't.
    I bought 3 quarts that already come with the LSD additive included & it was definitely under $60 for everything. Are you sure Toyota is charging you $60 PER quart?
    I have the invoice at home but it for sure wasn't more than $60 for the three quarts.
  17. May 17, 2010 at 4:33 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Use the FORD stuff...Motorcraft oil and Motorcraft friction modifier
    You will have no issues
  18. May 17, 2010 at 5:08 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  19. May 17, 2010 at 5:09 PM
    Airun
    Aaron
    Show Me State
    I'm pretty sure the parts guy said $62 per quart, but I'll call to double check. I searched online and found zilch.
    No Ford product will ever go near my Toyotas. (automobile racism????????)
  20. May 17, 2010 at 5:19 PM
    Airun
    Aaron
    Show Me State
    interesting Asgard, I'll have to look into that. I wonder if it would be ok to add to the 2 products currently in place.
