BF Goodrich all terrains for my tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoSauce116, Jan 4, 2012.
  1. Jan 4, 2012 at 2:43 PM
    TacoSauce116
    TacoSauce116 [OP] Member
    Blake
    Florida
    00' Tacoma Prerunna
    None..... yet.
    Hi guys I just recently got my tacoma and I'm new to the forums. So last weekend I found out the hard way that the tires on my truck are not gunna cut it for offroad at all. And like an idiot I didn't let any pressure out of the tires even though it was deep sand.
    My truck doesn't have 4x4 but it does have trd with the diff locker. I was told by my offroading buddies that I need to get a set of BF goodrich all terrains on there and let all the pressure out, and as long as i keep speed up I will glide over the sand fine.
    The problem is it doesn't seem like they make the tire in the proper size for my wheel. So what should I do? look at another tire or can I use bigger BF Goodrich all terrains? The truck is stock ride height so I don't know if it would be a problem or not.
  2. Jan 4, 2012 at 2:45 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    31x10.5-15's should work for your truck.
    Run about 12 psi and keep the speed up, you'll be fine. Just don't get stuck though, 2wd's don't do well in sand at low speed.
  3. Jan 4, 2012 at 2:46 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    is your tire size 265/70/16?
  4. Jan 4, 2012 at 2:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    no he has 15's
  5. Jan 4, 2012 at 2:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  6. Jan 4, 2012 at 2:49 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    oh. cause i was going to say that with stock suspension you could go up to 75's from 70's... at least that's what I've heard
  7. Jan 4, 2012 at 2:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    you can.
    with some trimming he could fit 32x11.5-15 BFG A/T's, but the stock size is 31x10.5-15
  8. Jan 4, 2012 at 2:51 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    they have em in your size. if your on a 16 get the stock 265/70/16 BF Goodrich T/A KO tires. and yes there is a thread about the correct tire pressure for sand.
    http://www.tirerack.com/tires/tires...AKORWLV2&vehicleSearch=false&fromCompare1=yes
    if your on a 15" wheel get some 31x10.5x15 tires. There are other tire brands out there that are just as good as BFG's. for example Toyo AT's, Goodyear Duratracs, Hankook ATM's, or Nitto Terra Grapplers. good luck with your tire search.
  9. Jan 4, 2012 at 2:55 PM
    TeenTaco
    TeenTaco Well-Known Member
    New Mexico
    01' Reg Cab 4Cyl
    Oh and hey a tip is when you post pics of your truck, you may wanna cross out your license plate.
  10. Jan 4, 2012 at 2:57 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    meh, people see it every day anyway. I don't bother.
    ThunderOne likes this.
  11. Jan 4, 2012 at 3:02 PM
    TeenTaco
    New Mexico
    01' Reg Cab 4Cyl
    Yeah personnally i don't care, but some people refuse to show on here.
  12. Jan 4, 2012 at 3:13 PM
    TacoSauce116
    Blake
    Florida
    00' Tacoma Prerunna
    None..... yet.
    Yeah I don't really care either, hundreds of people see my license plate when I go to work everyday lol. I found a better pic of the tire anyways so you guys can see what kind of tires are on there now.
  13. Jan 4, 2012 at 3:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yup those are 31x10.5-15's for sure. (should say this right on the sidewall).
    BFG makes the exact same size for the all terrains. I posted a link to them earlier.
  14. Jan 4, 2012 at 7:03 PM
    TacoSauce116
    Blake
    Florida
    00' Tacoma Prerunna
    None..... yet.
    Those will fit on my truck without rubbing?
  15. Jan 4, 2012 at 7:04 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yes.
    Go look at your sidewalls for yourself. The tires on there right now are likely the same size, and don't rub.
    32's would rub though, make sure and get the 31's if you don't want issues.
  16. Jan 4, 2012 at 7:09 PM
    TacoSauce116
    Blake
    Florida
    00' Tacoma Prerunna
    None..... yet.
    Okay appreciate it Steve.
  17. Jan 4, 2012 at 7:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    no problem
  18. Jan 4, 2012 at 7:12 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    will not rub for you as you have 6 lug suspension............just put 31x10.5x15inch on my truck on old 4runner rims...pic below
  19. Jan 4, 2012 at 7:12 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    You can run 31X10.50 15s on your truck. I had the same set up and I ran the 31X10.50 15 BFGoodrich a/t. on mine. You will be fine..
  20. Jan 4, 2012 at 7:16 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    your rims may be 16 inch....if so.... go with the size quoated above for 16in....both tires exact same height...30.7 inches
