BFG All Terrain TA KO Tire Pressure
Discussion in '1st Gen. Tacomas (1995-2004)' started by tr0gd0r, Oct 15, 2009.
  1. Oct 15, 2009 at 1:18 PM
    tr0gd0r
    tr0gd0r [OP] Well-Known Member
    Pullman, WA
    2012 Silver Streak TRD Offroad DCSB V6 4x4
    TRD Catback Exhaust - 265/75/16 BFG KM2s
    Can anyone tell me what the recommended tire pressure for my tires are?
    99 Tacoma with 31x10.5 R15 BFG All-Terrain TA KO Tires.
    Local tire shop set them at 40PSI, the tacoma manual says something like 30PSI.
    What do y'all run your tires at?
  2. Oct 15, 2009 at 1:18 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    It should say right there on the sidewall...
  3. Oct 15, 2009 at 1:19 PM
    Coastie Joe
    Coastie Joe Well-Known Member
    Andy
    NM
    16 TRD Off Road
    Mine say 80psi on the sidewall...
  4. Oct 15, 2009 at 1:20 PM
    98tacoma27
    Ben
    Not Beech Creek
    Those tires only have a max load printed on the tire side. Which it says 50 psi IIRC. I would recommend the chalk test.
  5. Oct 15, 2009 at 1:22 PM
    DadsToy
    DadsToy Active Member
    David
    Gainesville, Florida
    2001 Tacoma Double Cab 4x4 V6
    Snorkle, ARB Bumper, Warn Winch, Driving Lights, CB, 2 meter Ham,
  6. Oct 15, 2009 at 1:24 PM
    NraFan
    JT
    SoCal
    Whats the chalk test? Please ignore my total lack of any sort of inteligence.
  7. Oct 15, 2009 at 1:28 PM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    i used to run my 31x10.5 15s at 35 psi for general on road usage. had em on my 02 ZR2. at that pressure they wore evenly and had good grip, werent too squirrely. much lower psi and the sidewalls start flexing too much, at least for my preference.
  8. Oct 15, 2009 at 1:28 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
  9. Oct 15, 2009 at 1:45 PM
    Taco Guapo
    Taco Guapo Lurker
    Carefree AZ
    09 AC 4X4 2.7L
    Bone stock
    I had two sets of 31X10.50 AT KO's on my Jeep Cherokee 4X4, ran them at 32-34 PSI and got 50K miles out of each set. Never needed to air them down even in deep sand. Great tires...
  10. Oct 15, 2009 at 1:59 PM
    tacoterra
    tacoterra Batang SMB
    South NJ
    11 T4runner TE
    I hav mine at 32 PSI both front and rear right now.Just about right IMO.
  11. Oct 15, 2009 at 2:46 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I run mine at 35-38 PSI.
  12. Oct 15, 2009 at 4:08 PM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    I run my tires at 34 front, 32 rear 40 is a little high imo
  13. Oct 15, 2009 at 5:51 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    The Manual is referring to the stock tires.
    I run mine at 38 or so on the road. Air down to 30 when im out on a trail or hunting, Rarely have to go any lower than that with the locker.
  14. Oct 16, 2009 at 4:53 AM
    DadsToy
    David
    The caulk test is simple.
    Using a piece of caulk, find an empty parking lot or long straight section of road. Put a mark on the tire across the tread with the caulk, do it on all 4 tires.
    Driving slowly forwar for about 300 feet or so, get out and look at the caulk marks.
    Where are they marked and where are they missing?
    If it is still marked on the outside edges and missing in the middle, the pressure is too high.
    If marked in the middle and missing on the edges too low.
    If the mark is about tht e same across, that is a good pressure to use.
    Adjust and drive till you get the caulk wearing even and use that pressure.
    Sometimes the pressures are different front to back, it is a truck you know. :D
  15. Oct 16, 2009 at 6:39 AM
    NraFan
    JT
    SoCal
    Thanks. Thanks for making me feel like a TARD! Wow, that is so simple. Thanks for the information.
  16. Dec 5, 2009 at 4:35 PM
    USNROBERTS
    USNROBERTS Well-Known Member
    Jacksonville, FL
    06 PRERUNNER SR5 TRD SPORT
    I agree with the above for a good set up. Commonly tires are inflated to 35 psi (on the papers that came on my bfgs it stated 40psi max) go higher and you ride center tread. This can possibly give you better mpg due to lower friction. Air down below 35 to give more grip and full tread grip. I wouldn't ever overinflated what the bfg website recommends no matter what anyone tells you. Just watch your uneven wear down the road. No pun intended.
  17. Dec 5, 2009 at 8:20 PM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    WOW... very informative.. Thanks for the post. I truly learned something today now.
  18. Dec 6, 2009 at 12:49 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    BOOM! just set mine the same the other day. so far so good.
  19. Sep 11, 2010 at 1:46 PM
    macb15
    macb15 Active Member
    Mac
    Charlotte, NC
    04 SR5 4x4
    Does anybody know why Toyota recommends a lower pressure in the front? I just bought some BFG ATs from Discount Tire and didn't check the pressure til 2 tanks later. They set them at 26 front and 29 rear, which is what the door well says. It looked a little low to me so I set em at 32 front 31 rear. I plan on doing the chalk test tomorrow if it doesn't rain.
  20. Sep 11, 2010 at 2:39 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
