BFG AT 305/65R18 with 6" Fabtech or Procomp lift
Discussion in 'Wheels & Tires' started by prodigy808, Jan 26, 2011.
  1. Jan 26, 2011 at 7:30 AM
    prodigy808
    prodigy808 [OP] Active Member
    TX
    2011 Tacoma DC, LB TRD Sport 4x4
    Would like to know if anyone here are running these tires with a 6" lift on a 2nd Gen Tacoma. Any pics would be greatly appreciated. Thinking about running these tires but would like to see how it looks on a Tacoma first. From what I've been hearing folks have had rubbing issues when running a 35" tire with a 6" lift. The 305/65R18 is closer to a 34" tire and may help with rubbing issues. Just don't like the look of a 33" tire on a 6" lift. Thanks again and hope I can get some help regarding this.
  2. Jan 26, 2011 at 7:47 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    You're gonna get shitty gas mileage, and your speedo will be way off. Wouldn't hurt to re gear if you're goin that big, and if you are doing any off roading, you're gonna rub a shit ton. But but for looks, good to go!
    There are tons of threads here, try searching for them.
  3. Jan 26, 2011 at 10:54 AM
    prodigy808
    TX
    Thanks Joben, i have looked through forums but havent seen any 2nd gen running this specific tire. Light wheeling, and looks is what im after. seen couple running nitto Trail Grapplers 34" metric size and looks nice. Just wanna run the AT for better thread life. Thanks again
  4. Jan 26, 2011 at 11:55 AM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  5. Jan 26, 2011 at 2:03 PM
    prodigy808
    TX
    Already looked through every page on that thread, Didnt see anyone running That specific tire, may be a fairly new tire size offered by BFG. Helluva thread started by Toku. Thanks for the post though.
  6. Jan 27, 2011 at 3:15 AM
    hamads
    hamads Member
    Hawaii
    05 Double Cab Sport
    i was running 325/60/18s on 18x10. It looked cherry but mileage dropped under 14 mpg​
  7. Jan 27, 2011 at 6:23 AM
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    How much rubbing???
    im told i will rub with 3in and 305-60-18 on a 18x9 wheel 4.5bs
  8. Jan 28, 2011 at 11:39 AM
    hamads
    hamads Member
    Hawaii
    05 Double Cab Sport
    you will probably rub a lot, I ended up trimming the inner fender lining and the fender with my dremel.
  9. Jan 28, 2011 at 11:45 AM
    hamads
    hamads Member
    Hawaii
    05 Double Cab Sport
    o yeah I have 6" lift and the rubbing only came at full turn, but when it rubbed it sounded like my fender was gonna get ripped off b/c my tires.
  10. Jan 28, 2011 at 11:50 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I think solus694 is running that size in a 17 W/4.5"lift and has no rubbing.
  11. Jan 28, 2011 at 12:01 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I have 305/65/17 BFG AT which is a ~33" on RCD 4.5" lift... about 1" smaller than the tires you want... I have no rubbing... so you'll probably have no rubbing with 6"
  12. Jan 28, 2011 at 1:21 PM
    Blkturbo!
    Sean
    Henderson, NV
    But you have a whopping 325 and only rubbed at full turn, correct?
    So i shouldnt be TOO bad off with a 305-60-18, dont ya think?
  13. Jan 28, 2011 at 1:25 PM
    Blkturbo!
    Sean
    Henderson, NV
    So, I shouldnt be rubbing much more than some plastic shit with a 305-60-18 on 3in lift if you're not rubbing at all on 305-65?
    Do you have any pics of your truck onthose tires??? Id like to see more pics of 305s on these 3in-4in trucks, but hardly see anyone on 305s
  14. Jan 28, 2011 at 1:26 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    i have 35's that measure out to 34.8x13.2 true size, and i only rub flexing off road.
  15. Jan 28, 2011 at 11:37 PM
    hamads
    hamads Member
    Hawaii
    05 Double Cab Sport
    im thinking you will rub a little at full turn with 305's and 3" lift. to me trimming the fender and lining is no big deal but I have no idea if that setup will hit the cab-body mount.
  16. Jan 31, 2011 at 12:47 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    I have 325/65/18 Nitto Terra Grappler on mine, apparently mine runs wider than normal 35. I had to do a few trimming but i ONLY rub on full turns at speeds higher than 10 mph. I can drive in a parking garage and lock my steering wheel at speeds less than 10mph without any bumps and not rub.
  17. Jan 24, 2013 at 7:38 PM
    PhAtBoI808
    PhAtBoI808 MaUiBuiLt
    BuBz
    I_LiVe_Hi
    ReD_LiFtEd_WiDe
    K&N Intake
