BGR's build thread......
Discussion in '2nd Gen. Builds (2005-2015)' started by brutalguyracing, Jul 14, 2012.
  1. Feb 2, 2014 at 2:26 PM
    #1081
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Between the top of the rear view mirror and the head liner.
  2. Feb 2, 2014 at 2:27 PM
    #1082
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    :cool:
    is there enough cable?
  3. Feb 2, 2014 at 2:29 PM
    #1083
    brutalguyracing
    F.U> GUYZ
    broken mods
    I found out i was being tracked today when i went to check out fuse box and idb2 port today
    Mr x save me some tinfoil
  4. Feb 2, 2014 at 2:30 PM
    #1084
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  5. Feb 2, 2014 at 2:31 PM
    #1085
    brutalguyracing
    F.U> GUYZ
    broken mods
    i knew you put it there ^^^^^:spy:
  6. Feb 2, 2014 at 2:46 PM
    #1086
    Delmarva
    Tucson, AZ
    :tinfoilhat:
    Those don't transmit, so just destroy it and toss it in the trash.
  7. Feb 2, 2014 at 3:01 PM
    #1087
    brutalguyracing
    F.U> GUYZ
    broken mods
    :lalala::infantry::help:
  8. Feb 2, 2014 at 3:13 PM
    #1088
    AK27
    AK27 Well-Known Member
    He's stepping it up a notch. The new Xtreme mall crawling
  9. Feb 2, 2014 at 4:19 PM
    #1089
    brutalguyracing
    F.U> GUYZ
    broken mods
    :wave::headbang:
  10. Feb 3, 2014 at 6:35 AM
    #1090
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That thing hasn't been beeping at you? I tried one once and it was goin off all the time. Accelerating to fast, turning too fast, stopping too hard... wtf I couldn't imagine that in a car that you can actually drive fast
  11. Feb 3, 2014 at 7:36 AM
    #1091
    brutalguyracing
    F.U> GUYZ
    broken mods
    wasnt mine
    looked to see where i was going to route my cable for the ultragauge and found it
    must have been the previous owners
  12. Feb 3, 2014 at 7:39 AM
    #1092
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Others on TW have mounted it there. I will do a quick measurement before I remove the "A" Pillar cover.
  13. Feb 3, 2014 at 7:42 AM
    #1093
    medic2230
    Murph
    Bama! Roll Tide
    You will get a bit more cable if you remove the A pillar to run it. Running it around it uses up more cable. Mine fits perfect above the right side of the mirror run like that. There is just enough cable BGR.
  14. Feb 3, 2014 at 2:40 PM
    #1094
    brutalguyracing
    F.U> GUYZ
    broken mods
    :thumbsup:
    :thumbsup:
    SO WHAT DO I HAVE TO DO TO RESTORE MY HEADLIGHTS
    THEY ARE LOOKING KINDA DULL.....
    BUY A KIT FROM THE STORE OR BREAK OUT SOME HOME MADE REMEDY?
  15. Feb 3, 2014 at 4:12 PM
    #1095
    Round II
    Round II Member #12005
    Store kits are bogus. I tried a few of them a while back and they looked ok for a lil while but then went right back to pooh. The only one I have seen that works and seems to last is the the complete 3M kit where you have to sand down then buff..
  16. Feb 3, 2014 at 4:14 PM
    #1096
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I'd go with store bought. Those lights are three times as much as a taco light if you screw them up. Stay away from abrasives. I got sealer but its to cold.
  17. Feb 3, 2014 at 4:18 PM
    #1097
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I used a Sylvania kit. Sand down in 3 steps, polish, then coat with a supplied UV protectant. Worked great, just took a while.
  18. Feb 3, 2014 at 4:19 PM
    #1098
    brutalguyracing
    F.U> GUYZ
    broken mods
    It turns out everything in a 4runner is mad expensive
  19. Feb 3, 2014 at 4:20 PM
    #1099
    JDMcQ
    Did I forget to mention that?
  20. Feb 3, 2014 at 4:20 PM
    #1100
    brutalguyracing
    F.U> GUYZ
    broken mods
