BHLM Odd Scenario
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ravnikar610, Apr 21, 2017.
  1. Apr 21, 2017 at 5:47 AM
    Ravnikar610
    Ravnikar610 [OP] Well-Known Member
    Minnesota
    2016 OR DCSB
    I will be starting the BHLM this weekend and need some specific advice on how to go about it. I had attempt removing the headlight lens (only one of the headlights) once before and only got it partially removed and stopped. I sealed the light with 3m window weld. Can I still bake the light with 3m window weld?
    Thanks!
  2. Apr 21, 2017 at 6:08 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Preheat to 350°, use butter not margarine and let bake for 20 minutes. Remove from oven and let stand for a half hour before serving.
    Ravnikar610[OP] and Ch78 like this.
  3. Apr 21, 2017 at 6:05 PM
    Ravnikar610
    Minnesota
    2016 OR DCSB
    Thank you, Rachel Ray!
  4. Apr 21, 2017 at 6:13 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    That's Guy Savoy to you buddy :D
  5. Apr 21, 2017 at 6:15 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    @mesojdm hes the retrofit headlight guru, hopefully he has some insight.
    I believe his numbers were quite lower than posted above.
  6. Apr 21, 2017 at 6:19 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    I was totally joking (hence the butter and serving reference.) His headlights would be completely trash if he went by my numbers lol.
  7. Apr 21, 2017 at 6:23 PM
    Ravnikar610
    Minnesota
    2016 OR DCSB
    Yeah I know. The highest number I've seen (hopefully I can remember this right) was 310° for 10 minutes. I am not dumb enough to butter my lights.
    1bad2k[QUOTED] likes this.
  8. Apr 21, 2017 at 6:25 PM
    Broccoli
    Airdrie Alberta
    I was just going with it, i think its around 210 for 6-8 minutes then pry gently, redo over and over till they pop off, take your time do not rush.
  9. Apr 21, 2017 at 6:28 PM
    Broccoli
    Airdrie Alberta
