BHLM, this saturday...anyone care to help?
Discussion in 'Southern California' started by Marioso, Jul 27, 2010.
  1. Jul 27, 2010 at 1:33 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    me and jefferson will be meeting up to attempt a bhlm on my truck. we were wondering if anyone experienced would like to help! if ray sees this, do u have a write up we can go by?
  2. Jul 27, 2010 at 7:42 PM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    I'd be interested in doing mine too ha. I just wanna take out the amber lenses but I'm nervous about the oven thing...
  3. Jul 27, 2010 at 7:49 PM
    KDogg311
    KDogg311 Well-Known Member
    K H I E M ™
    So Cali 626 ³²³ 818
    Gen² Impulse Red Access Cab
    Avid Offroad light bar (Black), Avid Step bar (Black), TRD skid plate (Black), BHLM w/yellow signals, Pioneer Avic-x930bt, OEM fogs w/ yellow H10, Magnaflow muffler, aFe drop in filter, Toyota Neoprene "Tacoma" seat covers, Shorty antenna, Tint, Removed secondary filter, LED interior lights, LED reverse, Bedlinered rear bumper, color match grill, Black emblems, Red rear signals, Bed mat, OEM bike mounts
    SD area thing? I wanna eventually do my ... i like the idea of just takin out the ambers. I wanna see the outcome. Good luck
  4. Jul 27, 2010 at 7:50 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    i was sketched out about the oven too, i used a heat gun and it came apart fine. little tricky to get it started, but once the lense starts to come off your golden.
  5. Jul 27, 2010 at 7:51 PM
    Cars0n`
    Carson
    Edmonton AB
    i just pryed it up in the corner by the bottom of the grill and bumper
  6. Jul 27, 2010 at 8:47 PM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD | THE RECHRUNNER
    2012 CONVERSION | TOTAL CHAOS & ICON DYNAMICS |
    Heat Oven 325 degrees.
    Remove the 3 screws, bulbs, & plastic covers on the back of the headlights.
    Turn off the OVEN and place the headlights inside. Cover the Clear Lens with a microfiber towel once in the oven to avoid exposure.
    Leave inside the Oven for 10-12 minutes (OVEN IS OFF)
    When you pry the lights apart. Make sure you kinda move the plastic tabs off the lens cover so when you pry, they don't snap.
    Start @ the bottom left corner of the headlights to pry
    Pry with a flat head phillips. Once you pry it apart, it should come off pretty easy. You can leave the flat head to keep it separated and use another to keep you pulling it apart.
    Once you have it apart. You can scuff up the chrome with a green brillo pad.
    Then clean it off with warm water. Allow it to dry. Then use alcohol to get all the oils off it and ready for paint.
    Apply 3-4 Very light coats of Black. Allow 15-20 minute Dry time in between coats.
    The final coat should have at least 2 days of dry time. That is how I do it and what happens if the paint is not "CURED". It will start to do it inside the headlights and start to fog/haze up the clear lens.
    IF you must install them together asap. Allow it to dry inside a closed box on a warm day for at least 5-6 hours. I recommend 2-3 Days to dry.
    GOOD LUCK!
  7. Jul 27, 2010 at 9:01 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    hey fellas,
    what time are you meeting? I have to take an exam early afternoon, then I work that night, but if you are working on them in the afternoon, around 3, I can swing by and help.
    I just did mine.
  8. Jul 27, 2010 at 9:24 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    What in hell, are you guys doing? Is this a recipe for baked 'tacos ?:D:D
  9. Jul 27, 2010 at 9:25 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    I was super nervous about the oven thing at first. But once the adhesive loosens up, its super easy.
    I took the reflectors off the sides, amber cover off the flashers, and am blacking out the main reflectors because I am doing a retro HID conversion.
  10. Jul 27, 2010 at 10:23 PM
    Marioso
    San diego Ca
    let jefferson name the time idk what time, i just know its saturday. im sure its in the morning. thanks ray!
  11. Jul 28, 2010 at 11:32 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    woah, it turned into a meet? BTW - i've never ever done one before... anyone wanna come who has experience??
  12. Jul 28, 2010 at 11:38 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Ive done it
    I can be there around 3 or 4
  13. Jul 28, 2010 at 11:38 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Rad. Shoot mario a PM. I think Ray there scared him off from it ;)
  14. Jul 28, 2010 at 11:43 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
  15. Jul 28, 2010 at 11:49 PM
    Marioso
    San diego Ca
    cancel this meet, i need to plan this out right because i need my lights sat night and i dont wanna rush this. i thought maybe it oculd be done in one day but from what ray said i wanna play it safe
  16. Jul 28, 2010 at 11:51 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Canceled!! Lock this shit down! Mario says its DONE
  17. Jul 28, 2010 at 11:52 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    DONE!!!
    see you fellas at fiesta
  18. Jul 28, 2010 at 11:55 PM
    Marioso
    San diego Ca
    ii wont be there:( bullriding at del mar, thanks guys for taking my project into consideration
