BHLM tips or tricks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alex352, Sep 12, 2009.
  1. Sep 12, 2009 at 11:46 AM
    Alex352
    Alex352 [OP] Well-Known Member
    Alex
    Oregon
    07 Tacoma Dbl Cab
    http://www.tacomaworld.com/forum/2nd-gen-builds/281569-alex352s-build-thread.html
    hey guys me and 2 of my buddies r going to do the Bhlm to my taco today. do any of u no of any tips or tricks. anything i should be aware of while doing the mod?
    Thanks
  2. Sep 12, 2009 at 11:48 AM
    Reznor88
    Reznor88 Well-Known Member
    Northern California
    '06 PreRunner DC Off Road
    All the tips and advice you need to do the BHLM is right here.
  3. Sep 12, 2009 at 11:48 AM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    I did mine twice...the firs time I did it with a friend who couldn't care less how it turned out. My advice. TAKE. YOUR. TIME. Seriously. When you are putting the housing back together really take your time; this is where my friend screwed it up for me...he just slapped it together and the housing chipped like no other.
  4. Sep 12, 2009 at 12:10 PM
    Alex352
    Alex
    Oregon
    07 Tacoma Dbl Cab
    ok thanks guys. i will definetly take my time when doing this. and that link is perfect.
  5. Sep 12, 2009 at 1:04 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, TRAIN HORNS, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    When reassembling, it is super important to make sure and make sure the factory adhesive is soft again. If not, it is easy to push everything together and in the process break the plastic.
    To ensure this, put the headlight in the oven again @ 300 degrees for 5 or so minutes. Start in the corner of the headlight with a lip that you have to slip the clear plastic cover into (I think this is the top part closest to the parking lights) and work around.
    It doesn't hurt to cut some of the excess factory adhesive out with a sharp razor blade, but I would recommend putting some additional marine grade adhesive around the seal once reassembled.
    Good luck!
  6. Sep 12, 2009 at 1:10 PM
    Alex352
    Alex
    Oregon
    07 Tacoma Dbl Cab
    thanks for the tip TorenApart. ill remember to get some extra adhesive just incase.
  7. Sep 13, 2009 at 10:22 PM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    good luck just seal it really well because if you dont it will FOG like everyone else said take your time this is something that you cant do again and again or if you mess up its not easy to fix and if you do take your time and you do become sucessful ... man i tell you everytime you look at the lights you will rememeber how you did them and you will love em even more... thats the best part about BHLM
  8. Sep 13, 2009 at 10:43 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    update? pics? success?
  9. Sep 14, 2009 at 4:23 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    What I did was when I pulled them apart, I made sure to push the old hot glue back in the gaps, it gets kinda of stringy. Did this on both parts and also on the little tab things.
    I then when finished put it back in the oven, biggest thing I would do again is wear gloves, I burnt my finger tips :D
