Big brake kit Tacoma ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CHMM, Aug 12, 2016.
  1. Aug 12, 2016 at 8:14 AM
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Anyone tried this? Does the FJ one work? Thanks
  2. Aug 12, 2016 at 9:17 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
  3. Aug 12, 2016 at 9:20 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
  4. Aug 12, 2016 at 9:26 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    '15 already got the larger brakes. I think it was around '09 that they went to the larger calipers. The aftermarket kit is your only option for bigger. However, I am going with centrix drilled and slotted to handle the larger tires and prevent warping
    Lord Helmet and ChadsPride like this.
  5. Aug 12, 2016 at 11:16 AM
    CHMM
    CHMM [OP] GTO
    Gabe
    Thanks for your help
    ChadsPride likes this.
  6. Aug 12, 2016 at 11:20 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    These people don't know what you are asking. You are asking if the BBK for the FJ fits on the taco's. yes, it does, but make sure the wheels clear.
    @Torspd is running a BBK, one of these i believe http://sosperformance.com/t/tacoma-2005-2015
    Lord Helmet likes this.
  7. Aug 12, 2016 at 11:26 AM
    CHMM
    CHMM [OP] GTO
    Gabe
    That's awesome. It's on the list.
  8. Aug 12, 2016 at 11:27 AM
    Pigpen
    Dan
    Northwest Montana
    There was recently a thread on this where the OP used OEM Toyota parts. He used larger diameter rotors and the calipers from the 4 Runner (LTD, IIRC) and some other OEM parts. Do some searching, the thread has a complete list of part numbers.
  9. Aug 12, 2016 at 11:28 AM
    Large
    Large Red
    you have any sources for this info? as far as I know 05-15 have the same brakes
  10. Aug 12, 2016 at 11:29 AM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    Or just click the link in my post. ;)
  11. Aug 12, 2016 at 11:33 AM
    CanadaToy
    Greg
    Toronto
    That is for 1st gen taco's, people run the 1st gen tundra calipers/rotors. The smaller set fits 16" wheels, the bigger set uses min. 17" wheels.
  12. Aug 12, 2016 at 11:33 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Yeah, sorry I got confused on the WG and WH models as posted in the link. They are from select older 4Runner and this was a conversion I saw a lot of guys doing on GEN 1 Tacos.
  13. Aug 12, 2016 at 11:35 AM
    Pigpen
    Dan
    Northwest Montana
    I remember it specifically being a gen 2 thread. I am getting old though...
  14. Aug 12, 2016 at 11:46 AM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    Crom and CanadaToy[QUOTED] like this.
  15. Aug 12, 2016 at 11:50 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There was a 4th gen 4Runner trim (sport or limited) with larger brakes that could fit 2nd gen Tacos, but needs 17" wheels.
    The StopTech BBK kit is better though, with a stiffer caliper by design.
    CanadaToy[QUOTED] likes this.
  16. Aug 12, 2016 at 11:53 AM
    Clearwater Bill
    Billy
    Largo Florida
  17. Aug 12, 2016 at 12:01 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I read those before, but I am too hard headed to believe it all. I can't help but feel Stoptech is pushing their brand while the automotive thinker seems to only speculate and assumes there is immeasurable data. I raced for about four years on a Road circuit and there was definite difference between the two (my opinion only and potentially all in my head). Will I be able to discern this between what my Taco does on the street? Perhaps not, but the racers today don't use slotted and drilled rotors because they use ceramic which cost upwards of 5k per rotor. I have had good results. Thanks.
  18. Aug 12, 2016 at 1:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct. Basically the Rotora equivalent to the StopTech ST60's in your link. Man do they stop the truck! You need at least an 18" wheel. The coolest part about the StopTech calipers, is that they are rebuild able and upgradable. Many manufactures make pads for them, unlike my Rotoras.
    Crom and Lord Helmet like this.
  19. Aug 12, 2016 at 1:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My front rotors are drilled, and I race my truck. :D
  20. Aug 12, 2016 at 4:31 PM
    KenLyns
    Belly of the Beast
    • Centric is StopTech, in case there's any doubt.
    • Carroll Smith wrote that article, not StopTech.
    Torspd likes this.
