big problem???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Feb 28, 2011.
  1. Feb 28, 2011 at 8:47 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    i cant screw on the bolt all the way in for my passenger seat ,seatbelt. I tried but it just get tighter and and tighter. it goes about half way before it stops. i tired switching bolts with the driver side and that didnt work either. I looke inside and nothing blocking it. Any help???
  2. Feb 28, 2011 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like the threads may be buggered up. Can you chase them with a tap?
  3. Feb 28, 2011 at 9:36 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Might help to pull the seat out and get a better look. its pretty easy to remove the seats too
  4. Feb 28, 2011 at 9:46 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    so you forced it at some point?
    Neither bolt works in that hole but both fit in the other? Yea, try to find the right thread chaser and fix that up. Maybe try a small wire brush (bottle brush type) to make sure there's not a bit of slag or something jamming the hole. I'd think you could force it in there if it were just a matter of gummed up threads, steel doesn't gall that bad usually.
  5. Feb 28, 2011 at 9:53 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    cross threaded bolt?
  6. Mar 1, 2011 at 4:37 AM
    fjrmurph
    fjrmurph Well-Known Member
    could be cross threaded could be messed up threads, either way you should see damage to the threads of the bolt, buy a tap and chase the threads and buy a new bolt
  7. Mar 1, 2011 at 12:17 PM
    pinktaco808
