Bigger Dome Light Mod?
Discussion in 'Lighting' started by Vincent, Apr 1, 2009.
  1. Apr 1, 2009 at 11:11 AM
    Vincent
    Vincent [OP] Well-Known Member
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    Exterior: Debadged, color matched White grill surround, Custom Mesh Grill,BHLM,Clear Corners,Tinted Tail lights Black/Clear/Black, Tinted 3rd Brake light 5%tint driver/passenger windows, Limo tint Rear and back windows Interior: Black Leather Door Panels Engine: Deckplate Mod Hayden Transmission Cooler Exhaust: DynoMax Muffler with 2.5 piping after cats Lighting: 6k Headlights,3k Fogs Wheels and Tires: MB Razors wrapped up in 265/70/16 BFGoodrich All Terrain KOs
    i went to pep boys and bought a dome light that is slightly bigger than one meant for the 01-04 trucks..i think 3175. (correct me if im wrong)
    so i tweaked the supports inside the dome light housing and made it fit perfectly.....the only problem is that it only gets bright when i turn the map lights on...when it's left off, it flickers...i ended up touching the metal with the screw driver and blew out a fuse. i replaced the fuse. put back the stock dome light and everything works fine now.
    oh yeah, the radio, clock, map lights, and headlights all went out.:( i got scared for a second.
    if done correctly, can i actually make this bigger dome light work without blowing any more fuses.. like replacing the dome light fuse with a bigger amp?
  2. Apr 1, 2009 at 11:13 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Is it worth the hassel, I mean is the increase in light marginal? Have you looked into LED replacements for the stock bulb, that might prove to be a better result for you.
  3. Apr 1, 2009 at 11:18 AM
    Vincent
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    this dome light was an LED..increase was brighter. but only when the map light were on. otherwise, it just flickered. i want to know how to fix this..
    funds are going to an HID kit..
  4. Apr 1, 2009 at 11:20 AM
    Jester243
    Dan
    Spokane, WA
    Hmmm... I got nothin
  5. Apr 2, 2009 at 8:26 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
