bigger tires less mpg? What's your experience?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yellowdotz, Apr 13, 2013.
  1. Apr 13, 2013 at 5:55 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I'm running 285/75/16 Duratracs. Negligible difference in mpg from stock BFG Rugged Trails, maybe 1 mpg difference if that. I have a suspicion that those who cite a more siginificant mpg loss from bigger tires are forgetting to make a correction for the added tire circumference in their mpg calculations. You just need to look up the spec charts of the tire manufacturers to find the true outside diameter. Using my Duratracs as an example, the difference in circumference between stock Rugged Trails and 285/75/16 Duratracs is 8%, therefore you need to add 8% to your odometer readings before you do the mpg calculation.
  2. Apr 13, 2013 at 5:56 PM
    yellowdotz
    yellowdotz [OP] Well-Known Member
    SiNNeR
    Pasadena, CA
    13 tacoma i42.7L 4x4 manual access
    when you say that you are taking into consideration the increase in the circumference in your tires and factoring that into your mileage calcs?
  3. Apr 13, 2013 at 6:02 PM
    yellowdotz
    SiNNeR
    Pasadena, CA
    is your odometer calibrated to guage the larger circumference of the tires? How do you measure your mpg after you upgraded your tires?
  4. Apr 13, 2013 at 6:16 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I should add that the 1-2 mpg loss I stated above is with 90% highway/5% city/5% OR driving. These tires are heavy (E-range Toyo OC M/T) and I do have to give it more go juice off the line than I did with stock. If I was doing more start/stop city driving then my dropoff percentage would probably be worse.
  5. Apr 13, 2013 at 6:48 PM
    yellowdotz
    SiNNeR
    Pasadena, CA
    guys you do have to keep in mind the circumference and factor that in to your readings. Otherwise you're misleading ppl. Odometer readings are not accurate if you up ur tires and do not tune your odometer to read the upgrade.
  6. Apr 14, 2013 at 8:51 PM
    DevL
    DevL Well-Known Member
    13 mpg after correction. 12.5 mpg without 17 before so almost 25% lost. Its worse on highway mileage since the rpms do not matter for fuel efficiency, contrary to the lies you will hear that say they do.
  7. Apr 14, 2013 at 9:03 PM
    DevL
    I knew it was no 4x4 just looking at the mileage. ;)
  8. Apr 17, 2013 at 3:20 PM
    Deanno33
    Deanno33 Member
    Green Bay, WI
    2013 Tacoma DC TRD
    I am torn on this topic and keep reading post after post. My new truck should be here tomorrow and I want to swap the BFG trails right away so the shop gives me top $. Really want the look of the 265 75 over stock 265 70 but prefer not make mpg less. BFG 265 70 stock weighs 38lbs and is semi aggressive tread. Firestone Destination AT 265 75 is 42 lbs and inch taller. Destination isn't too aggressive for an AT. Estimates on mpg loss? Anyone make same change?
    My new ride will be 2013 dbl cab trd or
    Thanks and nice to be back...been taco less since 2010 when I traded my 2007.
  9. Apr 17, 2013 at 5:10 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I get better gas mileage with a one size up tire I was running 265/70/17 on my last Tacoma and increased mileage on freeway cause it dropped my RPMs crusing at 75mph with stock tires I was sitting at 2300 rpms with the 265/70/17 I was 2100 rpms so made my mileage better, in the city I didnt notice a loss and this is with BFGoodrich All terrains 6 ply
  10. Apr 17, 2013 at 7:17 PM
    yellowdotz
    SiNNeR
    Pasadena, CA
    i can't wait to get bigger tires and trd rims...just gonna run my rubber till it wears. thanks for the info....good shit
  11. Apr 19, 2013 at 6:15 PM
    DevL
    You drive downhill both ways? Because your lifted truck is better than stock lol.
  12. Apr 19, 2013 at 7:40 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I lost approximately 1-2 mpg after calculating for size difference. Went from 265/70-16 to 265/75-16. I really notice a difference when I do more 'city' type driving.
