Biggest improvement-suspension
Discussion in 'Suspension' started by Superhulk LB, Dec 18, 2019.
  1. Dec 18, 2019 at 1:02 PM
    Superhulk LB
    Superhulk LB [OP] Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Curious as to what would provide the most benefit from suspension upgrades. If you could only ad premium suspension to the front or rear, which would you do?
    Does an upgraded rear shock smooth out the ride more than an upgraded front coil over? thanks.
  2. Dec 18, 2019 at 1:05 PM
    su.b.rat
    su.b.rat broken truck
    preference. but if you want your suspension to do what's it's really for, then keep everything more or less in the ballpark of balance. I'd rather have the same cheap shocks on all four corners rather than premium front or rear with the other side sucking. that's horrible to drive... for me.
  3. Dec 18, 2019 at 3:18 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    You should consider saving up to get it both front and rear done at the same time. When customers contact us to have just the front shocks (or just the rear) revalved, we always recommend having them send both be done at the same time. Suspension systems (front and rear) work together for the best ride.
  4. Dec 18, 2019 at 3:21 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Best ride imho is a custom tuned setup for your application. Then for the rear something like a HD hanger and shock relocate for a 12-14 in smoothie shock.
    I’ve have this setup and it’s like butter compared to the old man emu setup I had prior...which it still rode good but I wanted more out of it.
  5. Dec 18, 2019 at 3:24 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    The biggest suspension improvement for me was front and rear sway bars.
  6. Dec 18, 2019 at 3:29 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I've read from members who raised the front 2" and left the rear stock. Levels the truck, and looks lifted.
  7. Dec 18, 2019 at 3:34 PM
    Superhulk LB
    Josh
    Oregon
    thanks for the replies. That helps. I like the idea of having something like King or ADS, but the thought of servicing them intimidated me. Was thinking I could “cheat the system” by putting Bilstein(5160?) up front and a higher end set up in the rear(I can pull the rear shocks pretty easy) Sounds like that is not the way to go.
  8. Dec 18, 2019 at 3:46 PM
    su.b.rat
    there are other ways and ideas that can help. one example is Hammer Hangers in the rear. that is one massive upgrade for strength & drive quality both. seriously improves the feel from the rear of the truck.
    https://www.tacomaworld.com/threads/tacoma-hammer-hangers-soa-sua-archive-garage.519625/
  9. Dec 18, 2019 at 5:59 PM
    Superhulk LB
    Josh
    Oregon
    su.b.rat[QUOTED] likes this.
  10. Dec 18, 2019 at 6:01 PM
    su.b.rat
    it's a big results mod with no associated maintenance, which is why i mention it here.
