Biggest tire on stock taco??
Discussion in 'Wheels & Tires' started by sslongmuir, Oct 27, 2007.
  1. Oct 27, 2007 at 6:27 AM
    sslongmuir
    sslongmuir [OP] Well-Known Member
    Maine
    95 single cab 2.7 on 33's
    Custom rock sliders
    what is the biggst size i can run on a stock 95.5 taco? i have 31x10.5-15 but i want to go 33x12.5-15. will it work or rub a lil bit?
  2. Oct 29, 2007 at 7:58 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    From what I read, a 33X12.50, or even a 33X10.50 will rub the frame up front at full turn. I don't know about the body clearance, but it looks to me like the body would clear. I am considering the same thing, so I have been looking at the 2.5-3" suspension lift kits. I have read and been told that they will clear 33s. The problem with the lift, from what I gather, is that 3" lift up front is the absolute maximum without lowering the front dif, which ups the expense a lot. The limiting factor is the CV joint angle of the front axles. The lift causes excess wear, particularly if you have auto hubs, which are locked full-time. You can get away with it with the manual hubs, since you will only lock them in when needed, reducing the time factor on the wear.
    I look forward to reading opinions from some who are actually running 33s. TacoZilla has some good info on lift kits. Seems he has tried about all of them.
  3. Oct 29, 2007 at 4:16 PM
    sslongmuir
    Maine
    Custom rock sliders
    i wa sthinkin 33x12.5s but i can deal with a lil ru b @ full turn for the looks and the clearance
  4. Oct 29, 2007 at 6:27 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Keep in mind you'll also have to consider suspension movement. If it just rubs when you turn, imagine what happens when you hit bumps.
  5. Oct 29, 2007 at 6:29 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Some of the spacer/AAL kits offer diff. drops either included or at a minimal extra cost.
  6. Nov 3, 2007 at 10:16 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    thernie you can lower your front diff for $18 ez-lift on ebay had the kits...come with bolts washers everything.... 33x10.50 might not rub alot but they will rub I had 32x11.50 bfg's on astock taco with no problems.....another thing is the way the toyota wheels are made the tires may rub the upper ball joint if you go too wide on a stock rim $8 1/4" spacers will fix that
  7. Nov 3, 2007 at 12:52 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Will the 33x10.5 rub the upper ball joint on stock 16" rims w/o spacers?
  8. Nov 4, 2007 at 4:24 AM
    Rmorris
    Rmorris New Member
    07 Tacoma SR5
    None
    Yes. Just put 285/75/16 BFG AT on stock rims (2007 SR5) with 3" lift, and get a little rubbing. I believe the backset on those rims is 5.5", or so I hear. Rubbing is at full turn and worse in reverse. Installer tells me minimal spacers will solve that problem. Hope that helps.
  9. Nov 4, 2007 at 7:52 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    I think, but could be mistaken, that the 285's are an 11.5" tire. What I want is a 265/75/16.
  10. Nov 4, 2007 at 7:57 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    I plan on a 3" lift, keeping stock 16'" rims, and adding 33x10.5 tires (or the nearest metric equivalent). I'll probably be getting the lift soon, but the tires will have to wait til spring. I just want to make sure I have everything I need for everything to work. I don't want rubbing....that's unacceptable to me.
  11. Nov 4, 2007 at 8:00 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    I'm working on my "shopping list". Just trying to iron out the wrinkles and cover all the bases.
  12. Nov 4, 2007 at 8:10 AM
    Rmorris
    Rmorris New Member
    07 Tacoma SR5
    None
    From what I have read, you should have no problem with the 265's and stock wheels. I haven't heard anyone say that was a problem. Everyone seems to want to go to 33's though, and that's what I opted for. 285's are considered 33" tires and 265's are 32's. So seems like if you're at 265's you're not going to need spacers on stock wheels. If you go to 285, you would. That seems to be the answer. I'm going in for spacers at the 700 mile checkup (for the lift kit) and I'll let you know if that eliminates rubbing. Even then, I think if you're into hardcore 4x4ng, with need of severe articulation, etc., I think you'd want to stick with 265's from what I've read. I'm kind of new to this too, but have spent a lot of time reading and this seems to be the concensus. Good luck.
  13. Nov 4, 2007 at 8:17 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    Thanks. Let me know what you find out. I'll update my progress as soon as I make some.
  14. Nov 10, 2007 at 4:22 PM
    sslongmuir
    Maine
    Custom rock sliders
    so 33x12.5 on a stock 15 inch rim will rub slightly. and a set of cheaap spacers would correct that? tacozilla said he had 32x11.5 without a prob on a stock taco so i dont think an inch bigger both ways would rub severly. but stock gears might be taxed?
  15. Nov 12, 2007 at 8:02 PM
    thenrie
    Stafford, VA
    My stock gears are good: 4.30:1, 8" diffs. As a matter of fact, that's one reason I'm interested in 33s, or maybe I'll look at 285 metrics with a more road friendly tread (not much off-road stuff available here in PA anyway). I'm riding along at about 3000 rpm at 73 mph. About 2500 at 62. I'd like to get that down a bit. Wishing I had a 6th gear, or that my fifth was really an overdive at about .70 or something.
    Since all my driving right now is on the road, I'm not concerned about a little rubbing at full-lock turning, or during full articulation. I just want to be sure I can drive normally without body or tire damage. Maybe I'll go ahead and get some "All-Terrain" 285 metrics, for a little better ride, and see how it goes. If it rubs too much, I'll get the lifts or try spacers.
  16. Nov 14, 2007 at 4:26 PM
    350TacoZilla
    Hancock MD
    the inch wider is what gets you..lifting wont help how far the wheels set in on the stock truck... another option I have heard of it a set of stock 00-02 tundra 16" steel wheels... they have less back spacing than the tacoma ones and are cheaper too
  17. Nov 14, 2007 at 4:37 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i had to put spacers on after my lift the rubbed the ball joint after the spacers i had to do the pinch weld mod
  18. Nov 15, 2007 at 3:41 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    +1 on that.
    Seems like a lot of guys want to run the biggest tires possible with the least possible amount of lift, even if it rubs when they turn into their driveway. IMO with a 3" lift you shouldn't run anything bigger than 32x11.5" or 265x75's which you could run with no lift.
    If you want 33's and plan on every taking the truck off road or even pulling into your driveway and don't want to rub, do a 6" lift.
    I can't understand why some just do the minimum lifts so they don't rub while turning in a parking lot at 3MPH. If they do it because they don't take it offroad, then why buy a 4x4 with 33's in the first place? Just makes no sense to me. It's like putting 28" chrome on a Hummer.
    When I get my taco in 12 months, I'm going with a 3" lift front and 1.5" rear with 32x11.5x16's. I would go with 33's and a 6" Fabtech lift initially but it would totally void the factory warranty, so I'm just going to run smaller tires and a mild lift till those tires wear out.
  19. Nov 15, 2007 at 4:45 AM
    thenrie
    Stafford, VA
    There are other considerations besides clearance and looks, Chad. With 4:30 diffs, I'm looking for a 6th gear on the highway with 31" tires, and my speedo reads about 3mph too fast at 65. I figure 33s might correct my speedo and lower my highway rpm to a better level, possibly improving my mpg if I go with a reasonable tread. Right now I'm running about 2600 rpm at 65. Makes it loud and gives poor mpg. I'd like to see the rpm drop to about 2200.
  20. Nov 15, 2007 at 5:29 AM
    2003greenbean
    socaste,sc
    03 trd
    32s is what the truck comes with stock why put on a lift and not bigger tires i run 33s with no rubbing on or off road
